Question about Quantum SDLT 320 External LVD (000003616772) Super DLT Tape Drive
Stops during boot
When installing SDLT 320 on a VMS (VAX DS20)system the boot process stops after the POST. Unplugging the drive allows the boot to continue normally.
  • Galen Tackett May 11, 2010
    Some additional information would help:
    • Is the system trying to boot automatically when turned on, or are you typing in a BOOT command yourself?
    • What is your default boot device? (Type SHOW BOOTDEF* at the >>> prompt to find out.)
    • What are the last two or three lines of output that you see when the SDLT is connected and the boot process stops?
    • What are the SCSI ID numbers set to on the SDLT and any SCSI disks on the same SCSI bus as the SDLT?
    Something else that might be helpful:
    1. Power off DS20 and SDLT.
    2. Connect the SDLT to the DS20.
    3. Power on the SDLT, then the DS20.
    4. At the >>> prompt enter "SHOW CONFIG" and press return.
    5. Repeat steps 1 to 4, except disconnect the SDLT which you can leave powered off.
    6. Compare the output of the two SHOW CONFIG and respond back with any lines that are different or missing between the two.
  • 4,234 Answers
First of all the DS20 is an Alpha box not a VAX. The problem here is usually an adress conflict. These tape drives are usually device 500. Try placing the drive onto a different controller card. That should resolve the problem.
Dan
Posted on Sep 05, 2009
Windows logo error mesage
Press windows button and in the search type msconfig go to startup tab and uncheck those you dont want to start.
if this fails to fix the problem
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope this helps
Aug 14, 2012 | Western Digital (WD3200JS) 320 GB Hard...
How do I find the scanned photos on my PC after scanning on an HP110
You can always try to do a system search
F3 brings up search on Windows.
Select images/Photos for the type
Select the date of the scan, or scan one then do this search.
The default naming may be SCAN#####
Also if you look in the preferences or options in the scanning software, it should say the path to where it will save your photos
Apr 11, 2011 | HP 110/220GB (for SDLT 220) 160/320GB (for...
I Get 2 GB WD harddrive and copy around 15o gb of files & folder and now I can't write because it shows disk is written protected i trieed 1 unplug and re install 2 restart pc 3 try to format but i...
you have to format your hard drive using a third party disc to erase everything on your hard drive
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to
cmos to restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
???????????????????? hope this helps
Feb 08, 2011 | Western Digital (WD3200JS) 320 GB Hard...
HP StorageWorks 1/8 Tape Autoloader SDLT 320 - tape library - Super DLT - SCSI Displayed Error! Code: A0 When you try to import or export are displayed error code 90
The library picker arm cannot move to the home position. There could be something blocking it. Try the Reset option from the Configuration menu. This is detailed in the library user guide.
Jan 11, 2011 | Quantum ValueLoader SDLT 320 Super DLT...
How do I physically remove stuck tape from valueloader SDLT 320
If the mechanism is physically damage, then I think disassemble the drive unit is so make sense.
Jul 09, 2010 | Quantum ValueLoader SDLT 320 Super DLT...
Using SDLT cleaning Tape
When the drives Clean LED comes on, install a "Universal" LTO Cleaning tape, as these drives do not need routine cleaning. Only ever clean a LTO drive when it's requested, as the cleaning media itself is more abrasive than a standard tape.
Sep 18, 2009 | Dell PowerVault 110T LTO-2 Ultrium Tape...
Will not boot
With limited information, this could be many things, however, I can try to explain what is happening. The computer runs several tests before it boots. This process is called POST (power on self test). During POST, all critical systems are analyzed, albeit a short test. When the system comes to something that does not pass the test, it usually puts up a warning allowing you to either continue or shut down and fix it. Sometimes, it comes to a test that creates a "loop" of instructions for the computer. When a loop happens, the computer does the same thing over and over and cannot stop. A loop can occur during POST if an instruction is not followed correctly. The most common cause for this in your type of computer is a problem with either the boot sector on the hard drive or the hard drive itself. Try disconnecting the hard drive and boot to a floppy or a cd. If the computer boots, you know where your trouble is. If on the other hand, with the hard drive disconnected and the same problem occurs, change your memory to fix the problem. Good luck tony
Jun 07, 2009 | Compaq Presario 5005 (470014-507) PC...
During extracting files from DLT tape to the local disc it gives input/output errors
Go to driver dectective and check to make sure your drivers are up to date.
May 20, 2009 | Quantum SDLT 320 External LVD...
Installation stops
Jonags,
NTLDR is the NT Loader basically the instructions the bios needs to start your Operating system.
If it is not finding the NTLDR it could be due to a couple of things.
First thing I'd do is to check that the install disc is a full install disc for the OS and not an Upgrade disc.
If it IS a full OS disc then we need to enter the BIOS (Basic Input Output System) Usually done by hitting <Delete> or <F12> during boot up. Once in the BIOS there should be an option for "Boot order" we need to set it so that your optical drive (CD/DVD) is listed as the 1st entry in the boot order. press <F10> to save and exit. Put the CD/DVD in your drive and boot up your computer.
this should get you started with your installation.
If it does not, you likely have a faulty optical drive.
Please post your results so we can further assist you.
Thanks
Dave
Nov 09, 2008 | Compaq Creative Sound Blaster PCI 128...
Quantum SDLT 320 External LVD (000003616772) Super DLT Tape Drive Logo
97 people viewed this question
Top Quantum Computers & Internet Experts
SirEbrum
Jax Planet
Jax Planet
Alun Cox
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
