Question about Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D
Spring hook-ups throttle free design carb.
Throttle free design carb. 3.5 h. p. spring hook-ups I can't figure out how to reconnect the spring and the Briggs and Stratton manual doesn't help either (http://www.briggsandstratton.com/maint_repair/manual_and_more/)
  • 3 Answers
Spring goes from throttle air valve to plastic lever under flywheel. Cooling fan on flywheel provides pressure to open/close throttle. As engine (fan) speeds up, pressure on lever causes throttle to close. As engine slows, throttle will open. System achieves an equilibrium very quickly.
hope it helps!
Posted on Sep 17, 2010
I hook up the throttle and it rus wide open how do I hoo it up right so it will work right I need help my e-mail is wootenray 35594@gmail.com my phone number is 205-528-1248 plz help me
Posted on Mar 28, 2012
Need a throttle linkage diagram for a briggs & stratton engine model 9S502 type 0620-B1
David, This is what I found in google search for B&S carb. linkage diagram, you can also do a search because there are lots more.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Linkage Spring replacement on Briggs Stratton Quattro 4 HP Murray Lawn...
Repairing Lawnmowers For Profit Part 61 Governor Spring Help
briggs and stratton governor linkage diagrams Google Search
briggs and stratton carburetor linkage diagrams Google Search
Jun 10, 2016 | Briggs & Stratton Garden
I have a Briggs & Stratton 10 HP engine, model 220707 that I could use some help with the governor spring on?.
Should see a bracket with holes in it .and a small throttle bracket that has a hook shape the spring locks on to it.
May 20, 2014 | Briggs & Stratton Briggs Stratton Intek V...
How to hook up governor spring and throttle linkage on a briggs and stratton 8hp
From the governor 'vane', on end with a small hole in it is for one end of the spring........the other end of the spring goes to the throttle arm on the carb. YOU MUST HAVE THE CORRECT SPRING WITH THE PROPER LENGTH AND TENSION!!!
Sep 21, 2013 | Garden
Carburator linkage
The governor link hooks on the top right of this carb and the throttle linkage is on the left all this is you standing in front of engine looking toward the steering wheel with the hood off
Sep 03, 2012 | Briggs & Stratton Briggs Stratton Intek V...
I need the linkage diagram for a 20 hp briggs and statton model 407777-0167
Besides the service manual you can view parts diagrams at a dealer like www.arcolawn.com. You can purchase the service manual at a dealer and it will show you how to hook it up.
The throttle linkage hooks up to the throttle shaft closest to the engine. the governor spring attaches the governor arm to the throttle linkage.
The choke cable attaches to the shaft farthest from the engine. I hope this helps.
PS your engine has two factory service bulletins on it.
Joe
Feb 15, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Motor runs wide open when set @ slow speed
It could be that the governor spring has become disconnected or has broken on an end where it hooks onto the throttle linkage. If the spring is OK & throttle linkage is not binding it could mean the governor drive inside the engine has failed preventing the governor from operating correctly. You may need to take the engine to a mechanic to fix the problem.
Sep 15, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Throttle linkange spring connection
goe to briggs and stratton .com and put your model type and code it will bring up your diagram and that will help.
Jun 27, 2009 | Garden
Briggs & Stratton Quattro lawn mower engine. Runs rich and unevenly. Suspect carb and have used sprey carb cleaner. Any suggestions??
A lot of time when the small motors on these push mowers surge it is a governing spring that is weak or broke. It does not hold enough tension and causes the valve to fluctuate. I have fixed this many time for a relatively cheap amount (under $5).
Jun 05, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Throttle control not operating.
Need more information. Is your cable hooked up to the carb or broken? Try checking that. Rick
Apr 06, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D Logo
798 people viewed this question
Top Briggs & Stratton Hammering Experts
Dan Webster
Dan Webster
John Trevino
JOHN LAPIER
Are you a Briggs & Stratton Hammering Expert? Answer questions, earn points and help others
