Question about Plumbing
Humming pump throws beaker
I have a shallow well pump. This morning when I turned on the tap I noticed that I had no water I went to the basement to see what was wrong the pump had thrown a breaker. So I reset the breaker and the pump made a humming noise and threw the breaker again. I checked the power going to the pump thats good. I cleaned the connections and checked power through the connections on the pump works good. I then took off the filter it had a fair amount of dirt in it more then I would expect so I cleaned it out and replaced it. When I replaced it it seemed to fill with water fine. So why is the pump humming it has power and water?
    Sergeant:
  • 293 Answers
It's because you may have a defective starting capacitor or a stuck-up motor or pump. If you know how to check a capacitor, do so. If not try replacing the old one. If the problem still persist, try to turn the shaft with your hand. If you can't turn it. You might have a defective motor or pump bearings.
Posted on Jun 11, 2009
Shallow water pump keeps stopping
new pump --not big enough for the job
old pump --motor windings problem, faulty start run capacitor
I suspect that as the motor is 1/2 hp if will run good when there is a need for water but under pressure the pressure switch is set to high so the motor overloads and gets hot
Mar 24, 2017 | RTO Wayne 1/2 Hp Shallow Well Jet Pump
Machine won't turn on
That sounds like the pump is jammed and did not pump all the water out.
May 10, 2013 | Fisher and Paykel WA37T26G Top Load Washer
I have a Mastercraft1/2 HP self priming Shallow well jet water pump, the water fell below the intake in my well and I quickly noticed and turned off the pump. We had water delivered and I'm not su
If water is back up above the intake, it should prime itself in a few minutes. As long as you don't let the case get hot to the touch it should be okay to run dry.
If it fails to prime and pump up pressure, you may have to prime it.
Oct 20, 2012 | Plumbing
Went to prime my FP4022 Shallow well pump and the mottom was seperated at the joint line. It did not get exposed to freezing and was drained for the winter and stored. Can you replace just the pump body ?...
Yes, you can, although it might be half or more of what you paid for the pump. First you have to make sure nothing is cracked, it separated for a reason. My gut is telling me that there was some water hidded in there and it froze. If that is the case, throw it away. I found this website that has most of the parts for it. http://www.pumpagents.com/partpages/FlotecPumps/FP4022.html
Hope this helps. Good luck.
Apr 19, 2011 | Flotec Corrosion Resistant Shallow Well...
Hello, Our Flotec Shallow well Jet is installed in our basement a distance ( perhaps 50 feet or so from the well casing outside in the yard. The pump was installed as a replacement for a worn jet pump...
Hi, Tom, W/D here.
You shouldn't really need a check valve as the foot valve is in effect a check valve.
Next time that you are near the pump when it kicks on and you are using no water, let it achieve full pressure and kick off. Close the discharge valve, isolating the pump and suction line. Watch the pressure gauge. If the pressure falls, you either have a leak in the suction line, possibly a leak at the well head (sucking air), a leak in the casing riser pipe or bad foot valve.
If the pressure holds steady, open the discharge valve and note the pressure. If it falls immediately upon opening the valve, the leak would be on the house side if the pump. Look then for any sources of water usage (ice maker, drips in the tub, water from the pop-off valve at the water heater, etc.).
Best regards, and good luck.
If I can be of any further assistance, please post back.
--W/D--
Jan 22, 2011 | Flotec Corrosion Resistant Shallow Well...
I have a Polaris PB4 booster pump, installed late July 2006, vacuum was running for an hour tonight but I noticed it wasn't moving across bottom of pool normally--wheel was skipping. I shut things down...
The click is the internal thermal overload. Since the pump wouldn't start it overloaded and opened the circuit. Either there is something jammed in the impelller locking the pump up or you have a motor problem. IF it a capacitor start motor, you could have a bad capacitor. Or if it has a starting switch it may not be operating. Start off and be sure the motor turns freely. If you replace capacitor be sure it is same voltage and MFD as the old.Check all wiring connections.
Aug 18, 2010 | Polaris Pb4 - 60 Booster Pump
1/2 hp shall well pump. set at 30/50....seems to hesitate around 48 for an extra amount of time....have to shake the hose or tap the pressure plate to get pump to cycle off. also....noticed the pump...
50 PSI for a 1/2 HP pump is approaching the upper limit for that pump. Many things can affect the upper limit. How far the pump has to pull water up the well pipe, is there any air leak what so ever on the input. If the pump lost its prime because it could not attain the 50PSI, I would suspect it may be just outside the limits of the pump at this point in time. If this pump is on a shallow well, it may be that the shallow well point is beginning to plug and not allowing as much water in which would cause a harder pull for the pump. I would turn the high pressure side down to maybe 45 and see if it operates properly at that pressure.
I hope this helps.
Jun 22, 2010 | Flotec Corrosion Resistant Shallow Well...
When you turn hot tap on nothing happens to the boiler just cold water out of tap when heating switched on pump starts but does not ignite
I think you are working on a RV water heater.
Check the reset on the unit and turn your beakers off and on.
If you are working on a gas water heater is the pilot lit.
If you can get us a little more INFO we can help you better.
May 16, 2010 | Heating & Cooling
I have a flotec jet pump for a shallow well. It keeps throwing the GFI and shutting off after only 10-15 seconds. I have replaced receptacle, water level is fine (has a float).
If this is a new problem that has just started
The GFI mite be bad or the motor mite be going bad Need to check the amp draw of the motor this will tell you witch is the problem
Jul 11, 2009 | Flotec Corrosion Resistant Shallow Well...
Plumbing Logo
366 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
