Question about Whirlpool GS6NBEXRB Side by Side Refrigerator
Can't change filter without water pouring out
When I try to replace the filter on my Whirlpool GS6NBEXRB, I push the button next to the filter it immediately starts leaking water. The water isn't shutting off so I can replace the filter. I have replaced the filter many times over the past three years
  • johngleason2 May 30, 2009
    Thank You. That was very quick.
    President:
  • 1,136 Answers
Hi, If you can't shut the valve off to the water source, you will need to shut the water off to your house and change both the filter and the valve to the refrigerator.
When changing the filter, you will get a little water while removing the filter but, not very much. I hope this helps you.
Please let me know if I can assist you further.
Vic
Posted on May 30, 2009
  • Victor
    Victor May 30, 2009
    You are welcome. I have another question. Does the water shut off at the dispensor in the door?
    Might be a inlet valve hangin up as well.
    We can get you through this. I just to make sure the area of the problem for sure.
    Vic
Keurig B70 won't stop cycling water. it just keeps draining the resevoir. Water is cold, not heated.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Feb 02, 2011 | Keurig B70 Coffee Maker
Looking for water filter to be replaced. The red light is on and I can't find filter.
On a Whirlpool you can check the bottom front black vent piece, filter cover looks like a half-moon shaped cover. Its under the freezer side. There is a thumb-sized black push button next to it which will 'eject' the filter. Push on the black button and the filter pops out
Dec 31, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker is not making any ice, what is the problem?
Whirpool ice maker not working I was told that I need it to replace the ice maker part but still not working ...what can I do next?
Dec 28, 2010 | Whirlpool GS6NBEXRB Side by Side...
How do you get the water filter out of refrigerator so you can replace it
Without knowing your particular model number, I checked and most 25 cu.ft. side by sides have the water filter in the grille. You just push a release button and it pops out. There is a cap on the filter, do not through it away as you will need it on a new filter. Also ensure the O-ring protective covers are removed on the new filter prior to installing. You can run the water dispenser without a filter as well. Here is a link to the PDF for one type of 25 cu. ft. Whirlpool side by side.
http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/GS5VHAXWA_Use%20and%20Care_EN.pdf
Jul 17, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water filter won't come out when I push the button
Push button? It should be a turn to the left to remove if it is a whirpool located at the bottom. These are twist out not push to release. The only push to releases are made by electrolux.
Mar 07, 2010 | Whirlpool ED2FHEXN Side by Side...
I need to change the water filter on my refrigerator
Since I didn't have the service manual, I had to play around until I stumbled into a way to remove the filter. To remove the filter: 1. locate the filter (bottom front under the refrigerator door). 2. push the button next to the filter cap until the filter is released. 3 remove the fillter and take that filter to the local home supply store to make sure you have the correct match. 4. replace cap on new filter, remove inlet protecting caps on new filter, and push the filter into place.
Mar 19, 2009 | Whirlpool 21.7 cu. ft. Side-by-Side...
Where is the release button for the whirlpool gold conquest water filter?
your filter either has a release button directly next to the filter within the kickplate. teardrop shaped button you push, or the only other filter hpusing requires that you twist teh filter out by turning counterclokwise it to is located within the kickplate under the refrig door
Mar 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
How to remove water filter on Whirlpool ED2VHEXVQ00
the filter is located in the front of the unit just below the freezer door whirlppol has 2 filter options one has a push button next to the round filter cartridge that whne pushed releases the filter. the other option is a twist out filter simply turn 1/4 tun counter cloclkwise and the filter will come right out.
after replacing filter run aprox 1/2 gal of water to clear air and remember to reset filter monitor according to your owners manual
Jan 21, 2009 | Whirlpool ED5VHGXM Side by Side...
Whirlpool GS6NBEXRB Side by Side Refrigerator Logo
187 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
