How do i replace my thermal fuse?
SOURCE: either the thermal fuse or the ignitor on my kenmore elite gas dr
Remove the lower front cover - it has spring-loaded keepers that can be gently pryed and the panel should either hinge down or pop off. The thermal fuse and ignitor are behind this panel.
SOURCE: WHERE IS THE THERMAL FUSE LOCATED ON MY KENMORE GAS DRYER?
It should be on the flame tube , small round part with 2 wires , it may be hiding toward the back of the tube or built on a bracket close by it.
Phil
SOURCE: dryer won't heat
The back panel doesn't come off for service!!! Most heating and control components are available behind the kick panel below the main dryer door..
With electric dryers my normal train of thought in diagnostics is to start with source of power. Do I have 220 volts available at the terminal board where the electric cord is connected??? Quite often I find a blown fuse, etc to cause it to stop heating as the motor will run fine on 120 volts as thats all it requires, but the unit will not heat with out 220 volts to the element..
best of luck, and have fun,
ttfn
SOURCE: need to disassemble a kenmore elite oasis dryer
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
SOURCE: kenmore elite oasis dryer model #110.6708
not much more than a service call for 1 hour work.
Rates vary depending on location.
Expect $60-$80 plus parts.
Hi
I
believe that everything else is fine rather it is the thermal fuse that is
located inside the rear panel to the exhaust duct that is bad and should be
replaced. If you want you can test this fuse for continuity and if it is bad
then it should be replaced, as it cannot be reset. If the fuse is fine then it
can be due to the control board that is bad and should be replaced.
Hope this helps...please post back for further assistance.
Daniel
Hi
I
Daniel
