Just had electronic control panel replaced (due to manufacturer's
Upgrade)...now keeps showing ''LF'' and won't work in any cycle other than rinse, drain & spin...didn't have any problems before they did this yesterday!!!
  • 56 Answers
Sounnds like you need them to come bback they may have left the hot water connection loose.
Posted on May 30, 2009
Normal + rinse light flashing on dishwasher
it sounds like something has came loose. you have to take the control panel apart and you should find a grey flat plastic cabel about 2 1/2 to 3 inches wide.hook it back up and maybe use some electrical tape to keep it in place and that should fix it.
Apr 15, 2014 | Whirlpool 24 in. DU1100XTPS Built-in...
Frigidaire Gallery Series Dishwasher - unit stops near the final rinse cycle without draining - "ER" on front display, all led indicators on front display also lit (e.g. low rinse agent, etc.),...
the problem is within the electronic control. Steam leaks in, due to an improper seal ring. Humidity stay in the compartment and eventually, the contact on the wire ribbon corrodes.
it can also be the new electronic module.
If the electronic module is ok, then the only working solution require that you order and install a "fit kit" from Frigidaire.
Some models even have a recall made form Frigidaire. Better check with them.
Apr 03, 2008 | Dishwashers
Whirlpool LF Error code
LF = Long Fill
LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change.
Is water supply connected and turned on?
Are hose screens plugged?
Is water entering the tub? If so check pressure hose connection to machine/motor control.
Oct 19, 2012 | Whirlpool WTW6400SW Cabrio Washer
Maytag_lse7804ace: washer won't fill with water. If I fill it by hand, the cycle works fine (until it gets to the rinse cycle, when it won't fill again).
Hello John,
The most probable reason the washer is not filling is because of a blown fuse that is part of the lid switch asm. By UNPLUGGING THE WASHER and removing the 2 INNER screws on the the control panel and the control panel can be rotated down to see the fuse in the lid switch asm. Here is where the fuse is on the switch asm. its circled in red 11_4_2011_1_39_54_am.jpg
Nov 03, 2011 | Washing Machines
When heavy duty laundry is done it washes and rinses,but when light washes are done it washes but doesn't rinse, LF comes on the controll panel.
LF Error code: LF stands for long fill and occurs when the water level does not change for a period of time after the valves are turned on. Make sure your water supply is turned all the way on and that you have good line pressure. If all that is ok, then I would replace the water valve on the machine.
Here is a link to the part you need.
Nov 25, 2010 | Whirlpool WTW6600SW Top Load
Washing machine displays an LF error code. Started last week during whitest whites cycle in rinse. I cancelled and just did rinse to finish my load. All other cycles worked and yesterday all started...
LF = Long Fill
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 07, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Oasis Elite auto temp control does not allow cold water
Ok, often the actual inlet Solenoid/Valves get "Gummed Up" and need to be "Stripped Down" and put in a bath of solvent for a bit, But, sometimes a couple of good "Whacks" with a suitable tool, will "Free Up" the jammed valve. I wouldn't wonder if this wasn't your problem all along? Anyway try that...
Mar 15, 2010 | Kenmore Oasis HE 27082 Top Load Washer
My washing machine keeps stopping on the rinse cycle and then i have to skip the cycle for it to keep working.
at any stage have you interchanged the hot and cold hoses due to a valve failure unless programmed the washer will call for cold water on rinse cycle but usually will fault if no fault occurs possible control board problem let me know how you go
Nov 05, 2009 | Fisher and Paykel GWL11 Top Load Washer
Kenmore Elite Oasis Model# 110.27087603
I had a very similar problem with my Oasis He Washer 110.27087603. The machine was randomly cycling through different water temperature indication lights. It would repeatedly beep and not allow a wash cycle to complete. Fixya.com alerted me to the "upgrade" to the electronic control W10112112 to W10189966. My machine was scheduled service and a Sears tech replaced that board. My problem with random cycling continued and the tech stated the touch panel electronics; part # 8564392 would fix the problem. He said one of the microswitches on the panel was probably stuck and not allowing the machine to enter a wash cycle. I found the 8564392 panel at http://www.prosupplyco.com/search.aspx?find=8564392 for a very reasonable price. Realize that Whirlpool parts are Whirlpool parts and Sears doesn't hold the only key to them.
Oct 29, 2008 | Washing Machines
LF Code
Why not just clean the screens to increase the fill pressure and spend not 1 cent on the repair.
May 08, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
