Normal
0
Double click on this site
http://www.logitech.com/index.cfm/support_downloads/&cl=us,en
Then
Search by Image (Match what yours looks like)
or
Search by Name
and
Product Name.
This will then take you to the next window where you need to select
your
Operating System. Then you will get your download driver.
Then do this:
Disconnect the Camera from the USB port and reinstall
the CD or Downloaded softwareprogram. When the program asks you to
connect the camera to theUSB port, do so and it should work.Then to
use it on the Web, do this.
Web Camera’s have to besetup on the program they are to be used with.
Just installing the cameraon your computer
does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order forthe Audio and Video
to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/)
set it up as follows:
The camera and audio should function properly. Yourfriends
and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html)
Hope this helps. Bud
SOURCE: webcam drivers
Select your camera on this page, click 'Get Software' and from the next page, select your OS and download.
http://www.logitech.com/index.cfm/405/&cl=us,en?prodcrid=405
Dont forget to rate this as Fixya if it helped.
Thanks,
ID
SOURCE: Driver for logitech camera v-uap42
Normal
0
Did you install the software with the camera connected to
the computer? Disconnect the camera from the USB port and reinstall the
software. When the program asks you to connect the camera, do so, and it
should work. Hope this is of some help.
Bud
Below is info for setting up Audio & Video to chat on
line after you install , either Skype or a messenger program.
Just installing the camera on your computer does not set it up to broadcast
the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
The camera and audio should function properly. Your friends and Family will now see and
talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up
as follows:
C. Windows Live
Messenger:
NOTE: You audio and
video shoud work. Enjoy.
When done both the Audio and Video will function properly so
you can chat and see family or friends you are connected to.
SOURCE: logitech webcam driver v-uap42
Normal
0
Then
or
Search by Name
and
Product Name.
your
Then do this:
A. Skype Setup:
B. Yahoo Setup:
Hopethis helps. Bud
SOURCE: I LOST MY LOGITECH M/N V UAP42 WEBCAMS DRIVER
Download from vendors site
You will need to install driver BEFORE you plug n webcam or will not work at all.
Only plug it in when told to.
drivers for logitech webcam v uap42
