Question about Xerox Phaser 8400DX Thermal Printer
Start Up red light error 37,004.40:35596
Powered on my Xerox Phaser 8400 this morning and it faults to a red light condition with the above error code. 37,004.40:35596 I would like to fix this myself if possible. Thank you Mark MacKenzie
    Novelist:
  • 125 Answers
Hi mjmackenzie2:
Here is your problem.
37,004.4x - PEST_FAULT_RESERVOIR0_HEATER_DISCONNECT
PEST - Reservoir0 Disconnect Reservoir0 is not drawing the expected power from the supply.
1. Run the printhead Reservoir Heater test.
2. Verify printhead wiring.
Entering Service Diagnostics by Rebooting the Printer:
1.
Turn the printer power OFF.
2. Press and hold the Back and Info buttons.
3. Turn the printer power ON while continuing to hold the Back and Info buttons
for approximately 30 seconds until the front panel indicates Diagnostic Menu.
Service Diagnostic Front Panel Button Descriptions
Button Function
BACK
Returns to the prior higher level menu structure, if available. Cancels the display
of test results on the front panel.
If help text is displayed on the front panel, pressing BACK will restore the current
menu item and remove the help text.
CANCEL Cancels certain functions of the printer.
INFO Provides help information, if available.
Press any key to advance through the help text.
UP Scrolls up one menu item within a menu list. This control does not ‘wrap’.
Used to increment data in tests requiring user input.
DOWN Scrolls down one menu item within test results.
OK Enters the highlighted menu. Executes the current test item.
NOTE: Pressing any key may cause an abort if allowed by the test being performed. A power
cycle is used to arbitrarily stop a test.
Hidden Service Menu
The Hidden Service Menu provides access to a large group of information pages and
functions usable for diagnosing and correcting printer malfunctions and accessing
special features. Display the Hidden Service Menu as follows:
1. Press OK and Cancel buttons at the same time to display the Service Tools
Menu.
2. With the cursor at the top of the Service Tools Menu, press both the Up Arrow
and Down Arrow buttons to display the Hidden Service Menu.
You may have to call a certified Xerox pro to service this printer. Hope this helps you.
Posted on May 30, 2009
    President:
  • 2,072 Answers
That is a Jet Heat error. Most likely a bad print head. Could be the electronics module.
Either the print head heater has failed, or the supply voltage to the print head heater.
Either one is very expensive to replace.
What is the Xerox Phaser 8400 printer error code 07.010.43:43923? Much appreciated. Thank you.
Try this:
The printer has encountered an error state without the benefit of a code. Turn the printer off for 30 seconds, then power back on.
If the Printer Error message returns, press the i button on the printer's front panel. The actual error or fault number should be displayed. Note the error or message and search the knowledge base for the error.
Also:
Based on the problem description provided, we have determined that your printer needs service.
Please turn your printer off and use one of the methods below to make arrangements for service:
If using the local service provider website, please perform the following steps:
  1. Enter your zip code in the space provided.
  2. Choose a mileage distance. The search will locate a Service Provider within the specified range if available.
  3. Click Go. The web site will return a list of Authorized Service Providers (ASP) with their company name, address, phone number, and fax number.
Feb 12, 2011 | Xerox Phaser 8400 Laser Printer
Hi i have phaser 8560, it gives me a error 09,038,46:62248, plese who can solve me the problem.
Hi there
The onlty thing I can find close to this is.
Acording to the manual its a ink loader error like your loading the wrong type of ink like the puzzles pieces arent matching and hitting the sensor flags right. Yours by the 8 is referring to the black ink. Anyway go to troubleshooting on the control panel. then to service tools. when in service tools press and hold the up arrow while still pressing the up arrow press the down arrow. the display should say hidden menus. go to diagnostic mode press enter go to funtion menu. then go to clear ISC fault and enter. ISC=ink stick count fault. I hope that helps. Just to let you know Ive had nothing but problems with third party ink and once its in the system its hard to get out so I would watch what im doing with my expensive equipment
Feb 18, 2010 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8400 Fault 37,008.44:9490
this is a Preheater error 37,008.44 I will put the link below so you can see how to fix it the repair for that error is on page 105
https://www.office.xerox.com/partners/products/Phaser8400/SQRG/8400_85XX_Service_Manual.pdf
Jul 23, 2009 | Xerox Phaser 8400N Thermal Printer
Xerox Phaser 8400 error code 37,004.40:27697
The majority of the time that code means the print head has failed.
That is a print head heater error.
You can find some places that sell print heads for about $150 , you would have to google the model number for that.
Xerox would charge $750 for a new print head, uninstalled.
Apr 24, 2009 | Xerox Phaser 8400 Laser Printer
Error in xerox phaser 8400
37,004.40: PEST - Printhead Reservoir 0 disconnect. Reservoir 0 is not drawing
One of the printhead cables may have come partially unplugged. Also, an ink spill on the circuit board could lead to this problem.
Apr 13, 2009 | Xerox Phaser 8400 Laser Printer
Xerox phaser 8400 error
That is a print head tilt error. Either the print head pivot block is contaminated with ink or the wiper blade is tacked to the print head.
Let me know if you want to try to resolve it yourself, I will send you directions.
Feb 17, 2009 | Xerox Phaser 8550DX Laser Printer
Xerox phaser 8400 error code
That code is a jet heater code.The most likely problem is a bad print head, the second most likely bad item is the electronics module that supplies the 40-50 volt source to the print head heater.
Sep 22, 2008 | Xerox Phaser 8400 Laser Printer
Fault code
well..it's a system error code..is this an older machine, by chance?
Aug 20, 2008 | Xerox Phaser 8400 Laser Printer
Xerox phaser 8400 fault
I have the same problem. Xerox says they need to send someone out and can not tell me what this code means.
Prior to the error I have having light streaking on the page. Took everything apart and cleaned and it worked OK for 2 days then returned to streaks.
If anyone knows what to look for please offer assistance.
Jul 24, 2008 | Xerox Phaser 8400 Laser Printer
Xerox printer error code (04,025.46)
This is a print head position issue.
TRY FIRST (Solutions without parts):
1. Check that the wipe mechanism has homed. 2. Check the printhead position and verify that it has initialized properly / manually home the printhead and power cycle the printers power and check for the error to return. If not then the error was most likely due to non-process function (something out of sequence).
Part likely to be the cause:
GEARBOX AND MOTOR,PROCESS DRIVE - PL 4.0, Item 14.
Jan 19, 2008 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8400DX Thermal Printer Logo
240 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
