Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
I HAVE A MODEL775R RYOBI GAS TRIMMER 31CC IT HAS NO SPARK.
COULD IT BE THE ON AND OFF SWITCH OR THE MODULE. I ALSO HAVE A PROBLEM WITH NO SPARK ON MY MACHINE. IT RAN FINE THIS SPRING (EVEN WITH LAST YEARS FUEL) THEN JUST QUIT. I REPLACED THE PLUG AND IT RAN FOR A FEW MINUTES THEN QUIT. I PUT A NEW PLUG IN AND FRESH GAS, TOOK OFF THE PLASTIC COVER TO MAKE SURE THE SWITCH WAS NOT GROUNDED OUT AND STILL NO SPARK. ANY IDEAS ON HOW TO TROUBLE SHOOT?
  • 37 Answers
You probably made the mistake of leaving it in the shed over winter with gas in it.
in the carb there is a diaphgram that oumps this fuel in via the motor vibrations.
said diaphgram had been ruptured due to drying gas in the carb. the solver to this is to either have a small engine mechanic replace it or the whole carb or get a new one, and i would suggest you get the cs26 model instead. i have a cs30 and cs26 and i have had less problems with 26. it only has two chokes.
you prime it.
you push lever to start, closing all but a little bit of carb,giving engine much richer mixture.
you squeeze trigger, opens halfway/full, as there are two chokers in the carb, on controlled by lever and another by throttle.basically now you haave half choke.
you release trigger, goes back to 7/8 choke to keep at idle but not running. your ready to go.
on the cs30 its much more complicated:
ful choke
prime 7x.
pull 4x
half choke
pull till start.
wait ten seconds of running at idle rotate to run
good to go. but these guys have porr design. if you take off the back cover and look above fuel tank on cs30, the crank is RIGHT SMACK THERE and not better secured like in the '26 model.
that's what the little circular hole is in it.
anywho, the diaphgram is ruptured, and you probably haven't noticed that in addition you have gas leaking out the carb's air intake.
Posted on Jun 01, 2009
Oil and gas mixture
Mixture is typically 40 or 50 to 1, gas to oil. The exact mix should be stamped on the gas cap.
Apr 10, 2010 | Ryobi 15" Electric Factory Reconditioned...
My 31cc ryobi gas trimmer won't stay running or easily dies why?
turn the high screw to the left just a little on the carb it is the first screw you see one has a H and the other has a L
Jun 22, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Blowing gas out the air intake
Eight years is great for a weedeater! Blowing out can mean something is stuck in the reed valves, or one may be broken. They are just under the carb, usually. Be real careful with the gaskets. If you mess up any, silicone will do. Use good car gasket silicone.
Apr 30, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
No spark At sparkplug Gas blower mod.#Ry08544
first check to make sure the on/off switch isnt shorting out anywhere. try resetting the gap between the flywheel and the igniton module. you can use an index card or manilla envelope to set the gap. if it still doesnt work try replacing the module
Nov 12, 2008 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How do I connect the fuel lines on the Ryobi 31cc petrol edge trimmer.
I have a Ryobi 31cc 17inch cut with gas line problems and this answered my questions. Thank You
R Green
Oct 18, 2008 | Garden
Ryobi 725r 31cc
Ryobi is Japanese for "Piece of ****" My suggestion is to throw it out!
My 767r has had fuel line and carb trouble from day one. I'll never buy another Ryobi or Craftsman tool again.
Jun 13, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
718 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
