No cold water
Kenmore elite washer. Cold water just dripping in. Switching to warm or hot water seems to work fine, just cold water is the issue. Can I fix this myself?
  • 864 Answers
Check the strainer in the hose where it connects to the faucet.  If it is clogged it will slow the water flow.  There may also be a strainer at the end of the hose that connects to the washer.
Posted on May 30, 2009
I have a Kenmore washer model 110.98762792 and im having a problem with the cold water. When the water temperature switch is set to the cold/cold position the washer does not fill with cold water. W
Since U get warm water that tells you that the cold and hot water solenoids are both operating. Ergo the anomaly has to be with the device that controls temperature.
Apr 10, 2017 | Kenmore Washing Machines
Hot water seems to not enter tub during washing cycle. all connections are correct and the hot water hose is hot up to the back of the washer, im baffled ? does the unit start with cold water on the first...
They start with hot or warm ,what/ever the setting and rinse with cold water. Check the temperature adjustment and the cycle it's on as some do different things on different cycles.
Dec 22, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Cold water drips in instead of fills. Hot water
Inlet screen in the hot water hose is clogged (check at both ends) or the solenoid valve has failed.
Oct 30, 2009 | Kenmore 22422 Top Load Washer
Hot water coming out on cold setting
try switching the hot and cold valves on the back of the machine and see if it works if it does just the oppiste then it's the water valve in the back where the hoses hooks up.
Jul 23, 2009 | Kenmore Elite 45986 Front Load Washer
Getting only cold water to my washer; hot water is not there
Hot water solenoid valve on washer not working. Test resistance across connectors. No resistance equals bad solenoid. Their not expensive and easy to install.
Mar 29, 2009 | Kenmore 20722
My laundry comes out hot to the touch. I used the warm/cold setting....
Check to make sure your Hot and Cold water lines from your supply are correctly attached to your Washer. They are labeled on the back of the machine, if you reverse them you should have a cold water rinse.
Jul 16, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE 5t
Low or no water supply, hot or cold side or water pressure switch not switching over to indicate fully filled though if this happens drain motor will continue to run continuously while f-20 flashes
Jan 15, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
63 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
