Question about Pentair Mastertemp Pool & Spa Heater Dual Electronic Ignition 400,000 Btu Lonox Propane 460737
I also Have a Master-Temp that shuts off after the Heat runs for about 30 secs. I've checked the LEDs on the back of the control board and have a SFS light on, In addition to the E05 code on the main display. I've checked the Flu sensor with an Ohm meter and heat gun. Resistance decreases as I apply heat so I'm thinking the sensor is OK. I checked best I could for obstructions in the Flu and heat exchanger. I figure that the Air Flow Sensor (AFS) should illuminate if that were a problem. I've checked both water temp Hi Limit sensors both show continuity cold. I haven't checked them hot thinking I would have a Hi Limit LED if they were the problem. Any ideas about what I may be missing other than replacing the main control board? Unit is 1 yr old and just out of warranty of course.
  • 952 Answers
Hi!
The mastertemp E05 error code is related to the stack flue sensor and the NT is, like posted, the flame sensor code. The NT will give this code for other reasons also, such as low gas pressure, blocked orfices or inadequate air flow.
The MasterTemp stack flue snsor trips when exhaust temps reach more than 350 degrees. This is usauly caused by a flow issue or a bad thermal regulator causing the water to remain in the exchanger and over heat.
I sure hope this helps. Thanks for using Fixya
Posted on May 30, 2009
Dryer heats but only runs for about 30 secs
Inside the back and the bottom of the dryer are several ( from 3 to 7) "overheat thermostat switches" that are there to prevent your dryer from catching fire from overheating.
I suspect one of of these has failed, and it "tripping".
Someone with a good electrical meter and a set of tools can check each one and find the bad one.
Be blessed.
Apr 16, 2013 | Maytag Dryers
I have a McCulloch Model FR 2.3 18 in. chainsaw that will fire up and run for approx 30 secs. and then shut off. If I pump the primer bulb twice, it will fire up again for approx 30 secs. I'm ve
This is oviously fuel starvation, the first thing to do before speding too much time on it is to replace the fuel filter in the fuel tank, hook the hose out with a piece of bent wire, pull the filter off and replace, as a quick test pull the filter off, let the fuel hose go back into the tank, make sure the tank is full, now try. Do not leave like this you must fit a new filter.
Mar 30, 2013 | Garden
My Sta-Rite poll heater doesn't work. The heater comes on when every time I restore power to the unit, the membrain buttons only work to change the temp. ont to shut off the unit, I use the service...
This issue sounds tricky. I recommend you callthe Sta Rite technical support at 888-782-7483 and they should be able to helpyou figure this issue out.
I hope this helps.
Sep 12, 2011 | Sta Rite STA-RITE CONTROL BOARD KIT -...
My dishwasher clean light keeps flashing and wont run. it flashes 7 times and pauses then repeats. whats the issue?
This is an error code.
The error indicates that your dishwasher is failing to heat the water in an allotted time. The error can be caused by numerous issues but the first thing you want to do is reset the control board.
-To reset the control board press: high temp wash, heated dry, High temp wash, heated dry, high temp wash, heated dry, high temp wash, heated dry, high temp wash. If you don't have a "heated dry" button, use the "air dry" or "energy saver dry" button instead.
-All the lights will go solid at which point you press cancel to reset the board.
-If the control board doesn't reset, it's likely that you've just got a faulty control board and the control board will need to be ordered and replaced.
The next step in this process is to start a new cycle and see what happens. If the error code returns, then you'll want to reset the board again and check several things. The most common reasons for this error is because the water coming from your household is just too cold. The dishwasher is expecting 110 degree water to enter your dishwasher, so if your pipes are cold, the water may only come in luke warm. To correct this issue, just run your faucet next to the dishwasher until the water coming out is hot. On another note, make sure the dishwasher is washing with good water pressure. You can put a cup in the upper rack facing upwards and run a cycle to see if it will fill within 10 minutes of starting the cycle. If it doesn't fill with water then you know that the dishwasher isn't producing enough pressure which, in turn, will cause the water to not heat. You'd want to take your pump and motor assembly apart to clean inside if you had a loss of pressure.
You could also have a failed component including a faulty heater, control board, or high limit thermostat. You'd need to uninstall your dishwasher, disconnect power and lay it on it's back to check the resistance of the heater as well as the resistance of the high limit thermostat to confirm if they were bad or good. You should get tangible reading of between 5 and 30 ohms on the heater if it's good and less than one ohm on the high limit thermostat. If both of those devices check good, then replace the control board because that's the one device you cannot test.
Jul 05, 2011 | Maytag Dishwashers
It doesn't want to shut off and we have no heat?
when you say it doesnt want to shut off i'm guessing you mean the fan. the fans run on a timer when the thermostat calls for heat it will come on 90-120 sec.later. turn your t stat down below room temp and it will shut off in 30-60 sec.your ignitor is most likly bad. turn your t stat back up and look at it. it should glow. furnace will try to light 3 times,you may hear the gas flow for 3 sec.during this cycle. if no glow good chance that is your problem and you will need to replace it.be carefull it is very brittle and breaks easy if tapped. be sure to turn the t stat down again or the fan will start running again.
Jan 26, 2011 | Coleman Propane Forced Air Heater...
FREEZER ERRATIC. Will work for 6 to 12 hours and
You will have to remove the inside rear freezer panel .The # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off due to temp setting .
May 02, 2010 | GE PSC25SGSSS Stainless Steel Side by Side...
Code E05
E05 and E06 is the error codes for a faulty stack flue sensor. try changing the sensor first is the cheapest. if that doesn't work check for corrosion on control board in which case will have to change out board.
Apr 20, 2009 | Pentair Mastertemp Pool & Spa Heater Dual...
The only button that will respond is
with controls unlocked, you can not power on or start? ck to see if you can get to diagnostic mode.
old duet(red leds) -select drain/spin cycle, no spin (modifier), press prewash 4 times in 5 secs. all lights come on then displays codes, f code are faults
new duet/sports(green leds) - press and hold any one modifier button 4 sec on 4 sec off 4 times.
control boards are common on whirlpool.
Mar 15, 2009 | Washing Machines
Pentair Mastertemp Pool & Spa Heater Dual Electronic Ignition 400,000 Btu Lonox Propane 460737 Logo
716 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
