Question about Zyxel P-334WT (P334WT) Firewall
P-334wt router was working fine, but tried to use and now it says i need to imput a network key??? where do i find that
    Problem Solver:
  • 6 Answers
First, go to ur Router Configuration Page. There are 2 pg into related WireLess Configuration Settings. So u find ur problem into the WPA security configuration is under the wlan Security section, and then you select WPA PSK (Pre Shared Key) and TKIP encryption for Lan security. As well as changing the WPA Mode to enabled, u will need to enter a WPA Pre-Shared Key. So u found, which is a Network key and why to need.
Posted on Oct 24, 2007
I have a belkin wireless router it works fine but i dont know how to get the laptops to work as wireless, i also dont know how to change the password or any keys to get the other laptops to works, thanks...
is it a wireless computer or the wired computer?
I believe the main computer is online.
Check the settings on the router.
You will need to open the router set up page.
here you will see the settings of the router.
If you are trying to connect to the wireless network then make sure that you are typing the correct network key.
Click here for more information about routers and network
Aug 13, 2010 | Belkin Computers & Internet
Can I completely delete the memory from my Zyxel P-334WT router?
Hi there, in short yes. the reset button on the back will delete all the info on the router however a short press will not. What you will need to do is hold the button down for a good 20 second.... if this does not work then pull the power lead out and push it back in with the reset button pushed in, again for a good few second. Now to view all setting on the router before hand open your web browser up and in the top address bar type or the access code for your router varies on the make but can usually be found in the manual.when asked for a user-name and password just enter those (usually the user-name is ADMIN & the password is PASSWORD or also ADMIN. anyway you shold then be able to view the log and all settings.... hope this help ....Tony A
Dec 13, 2008 | Zyxel P-334WT Router (91003155003)
Problems with forwarding on the Zyxel P-334WT router!!!
You didn't say what game or what router. Can't get much help unless you give us something to work with.
Jun 17, 2008 | Zyxel P-334WT Router (91003155003)
Unsecured network shows up as secure
The person who has the router attached to there computer must enter the IP for the router and you will be able to reset the password to enter the router. If you need Help doing this I can solve this issue with you through my computer.
Hope This Helps
All The Best,
May 28, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Linksy router lem....!!!!
Try the following to reset it to the factory defaults.
Warning! This will reset all the settings in the router! Including any custom setup stuff, like WPA key, etc.
Turn the router on. Press and hold the reset button on it for 30 seconds. The reset button is usually a small recessed button on the back of the unit depending on which model you have.
Now you should be able to connect to it through your browser at Depending on your model, the username is blank and the password is "admin" (without the quotes) OR both username & password are "admin". Note that you will need to connect your computer to the router with a network cable to go through the setup process - you can't do it wirelessly.
Dec 13, 2007 | Zyxel P-334WT Router (91003155003)
Cannot connected to my router
once u went to teh remote login u can see port and u need to change it to 8080 and reboot the router and try
Oct 08, 2007 | Zyxel P-334WT (P334WT) Firewall
Not working with Vista
May the router is not compatible with vista. Just try to use it with xp.
Aug 23, 2007 | Zyxel P-334WT (P334WT) Firewall
P-334WT Router Freezing
Your first step is to upgrade the firmware. OR re-install the firmware. Do you mean freezing like, lights lock up and stay on regardless of the activity? Which that would point to firmware. Or do you mean that your internet just cuts out? Which I would look more towards your computers browser, possible background applications or even the NIC.
Jun 14, 2007 | Zyxel P-334WT (P334WT) Firewall
Router Not Working
First of all Reset by pressing a reset button or with the help of a pen. turn if off and restart ur computer Once you connect ur computer with router.. go to start-run- type ipconfig. if you are getting an ip address in range of to, 1.Launch your web browser(IE). Enter ? as the web site address. 2.The default password (?1234?) in internet access setup choose "Encapsulation as ethernet and there should be nothing in username or password.incase you have been provided with username and password from ur ISP then enter those with ip address assignment setting as dynamic. See if you can open the routers settings page. once you open it follow the instructions given on this link in .PDF format to SETUP ur router for ur internet connection. To learn about ur router n setup more visit: I am also using the same router and i did the same thing with the help of *** support team. i got it fixed in just 15 minutes. u can contact them on *** Just try it out and let me know or call *** team. i am sure they will help you out. Cheers!!
Dec 14, 2006 | Zyxel P-334WT (P334WT) Firewall
Zyxel P-334WT (P334WT) Firewall Logo
193 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
