Question about Goodman CACF048B2A Air Conditioner
Goodman CACF048B2A Air. need to know the location of the replacement filter
    Problem Solver:
  • 6 Answers
The disposable filter is always in the return air of an a/c unit. If your unit has a furnace attached in an upright position then the filter is under the furance blower wheel. You will have to remove the bottom access panel to see and replace it. If your unit is horizontally installed in an attic then the filter will most likely be up in that return air duct or possibly in the return air grille possibly mounted in a hallway or someplace like that.
Posted on Jun 02, 2009
Trouble locating the air filter in the Goodman heating unit. CAPF036A2A
it will behind return air grille either in the room, ceiling, & i have seen them in attic in return plenum.
Feb 10, 2015 | Goodman Heating & Cooling
Goodman SSZ140481AG, what is it? is it 14 seer or 15 seer? I paid for 15seer but the unit has a decal on it reading 14 seer??? Thanks
It is federal law that each new piece of A/C equipment have the yellow SEER rating.
The higher the SEER, the less electricity the system uses to operate.
You need to follow up since it appears your contractor installed a less efficient/expensive system than what you paid for.
Good luck.
Sep 15, 2013 | Goodman CACF048B2A Air Conditioner
Air handler blower keeps blowing after compressor shuts off and thermostat is satisfied.
Of course the simple question is to make sure your thermostat is set to auto and not fan on. Also if that is the case, then either there is a wire touching somewhere on th low voltage side. or te fan relay or fan manager has a problem.
Jul 30, 2011 | Goodman CACF048B2A Air Conditioner
The product which is described is not blowing out cold air i would like to know how to correct this situation?
the most likely problem is a blown compressor. this is unfortunately a very costly repair usually ($1000-$4000), but it might be covered under the warranty.
Jul 23, 2011 | Goodman CACF048B2A Air Conditioner
I set the tstat to cool everything ok i set tstat to heat it blows the fuse on pc board
Check for wires rubbing together from the thermostat to the furnace. More than likely there is a short somewhere in the low voltage wiring. Check the wires on the thermostat also to make sure none are touching together.
Apr 11, 2011 | Goodman CACF048B2A Air Conditioner
I Have a beige goodman furnace (old ones) gmp... i replaced the circuit board..it worked fine..then once it reached its desire temprature from thermostat.. fire goes out then 2 min following is the...
Check the pleum high limit switch. Jump this control out and see if the furance runs until the call for heat is satified. Do mot leave the high limit jumperd.
Jan 26, 2011 | Goodman CACF048B2A Air Conditioner
Unit shut off fan running outside
Remove the capacitor and take it to a service parts and let them check it. Be careful the capacitor can have some elect after it is
removed
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 22, 2010 | Goodman CACF048B2A Air Conditioner
Cold air comes out but doesnt blow
The filter in a Goodman unit is in the Air Handler located at the bottom of the unit. Screw on either side take them loose and the filter pulls out. Now trun of fan first so the filter will come out easier. You may ahve other problems like stopped up coil or low on refrigerant. Russ
Jul 20, 2009 | Goodman CACF048B2A Air Conditioner
Do I need to change a filter? Where is the filter located?
Yes,The is a metal strip that is about 1.5 inches wide and held on with one screw,Just remove that and the filter is located there.
May 29, 2009 | Goodman Heating & Cooling
Goodman CACF048B2A Air Conditioner Logo
210 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
