Question about AudioBahn A8000T Car Audio Amplifier
The thing thats burned is like 6 black squares with three wires comin from it..
I have a audiobahn a8000t and it powers on but no audio come out so i opened it and there were some things in there that was burnt,,idk the name of them but i was wonderin id some can gudie me on how to fix them.. I have a similar problem, I brought the amp second hand so don't know how it was used before hand. I'm hoping when i open it its something simple cos if its the amplifier IC's then i'll be throwing it in the bin - costs too much!
  • Perry Babin May 11, 2010
    They are likely the power supply FETs. They may have failed alone or their failure may have been due to another fault like shorted audio output transistors. Since you're new to this, read through the following page then ask any other questions that you may have.
    http://www.bcae1.com/repairbasicsforbcae...
  • 578 Answers
Audio put burn out
Posted on Jun 26, 2009
Amp powers up,but get no sound,and protection light comes on
wire are not corrected properly or it touches each other
Apr 27, 2011 | AudioBahn A8000T Car Audio Amplifier
I have an a8000t amp with the protection light on, is the amp broke?
Disconnect the speaker wires then the power and ground completly. Then power up the amp and if the protection light turn on the you have an interanl problem if not then you ohm is problably to low and causing the amp to go into protections.
-david
Nov 09, 2010 | AudioBahn A8000T Car Audio Amplifier
Where can I find a cooling fan for a Audiobahn a8000t amp?
Hello fornda,
The fan looks very similar to a 3" muffin fan. The fans from most computer cases would probably fit. You may have to modify how it mounts, and perhaps the connector, but the voltage is the same.
Here's an online retailer. I'd look for the highest CFM at the lowest fan speed to keep the noise down.
Hope this helps.
Aug 07, 2009 | AudioBahn A8000T Car Audio Amplifier
Amp keeps cutting off
Do you have heavy enough gauge wire supplying B+ to amp.Big amps draw a lot of current and require very heavy gauge wire. The longer the run the heavier the gauge needed.
Apr 20, 2009 | AudioBahn A8000T Car Audio Amplifier
I conect the amp but its not on
make sure your ground wire is connected securely to bare metal
Mar 22, 2009 | AudioBahn A8000T Car Audio Amplifier
Audiobahn A8000T has power but is not hitting
Check your cap, it prob went bad. That could be restricting the power flow now. Try it with out the cap. that just might be the prob.
Jan 15, 2009 | AudioBahn A8000T Car Audio Amplifier
Hey the amp audiobahn a8000t turns on then burns out the fuses
Audio output transistors are shorted. Time to see a technician.
Dec 01, 2008 | Audio Players & Recorders
Audiobahn a8000t problem
If the protect LED is lit, the amp probably has shortedoutput transistors. To eliminate other possible causes, read throughthe following page:
Amp in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Nov 23, 2008 | AudioBahn A8000T Car Audio Amplifier
Protection Light On
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you didn't fry speakers as well. Please check speakers impedance. A thumbs up would be greatly appreciated if this answer is helpful to you
Nov 26, 2006 | AudioBahn A8000T Car Audio Amplifier
AudioBahn A8000T Car Audio Amplifier Logo
158 people viewed this question
Top AudioBahn Car Audio & Video Experts
Professor_V
Professor_V
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
