Question about Danby DKC646BLS Full Size / Pony Beer Keg Cooler
Loud humming noise from unit
I have a Danby kegerator that makes a loud humming noise for a few moniutes at a time and the temperature control doesn't allow me to contol the temperature. Any ideas
  • 24 Answers
SOURCE: There's a loud humming in
Your symptoms are classic. What you are hearing is the starter relay trying to start a warm/hot compressor by supplying it with an extra jolt of electricity, but because of the faulty compressor (or if you are lucky a faulty relay) that's warm (cool ones start more easily often) is refusing to budge into motion and compress the freon. When it doesn't run, the fridge and freezer don't cool.
Posted on Nov 08, 2009
  • 619 Answers
SOURCE: new danby kegerator - tastes like rubber hose
you may report the problem of taste of beer the store where bought it , byu the when it new smell strange but it better clean in second time by flushing of water before you attache the beer tank, for the time the fume of rubber connection still inside on that machine , (in purified water need to back wash in order to make a purified water good taste and clean, ) the term use of that machine is "flushing " .
Posted on Jan 01, 2008
huuum
  • 750 Answers
SOURCE: Temperature - Is fan supposed to constantly run or is it controlled by thermostat
You said ,Top half of Danby DKC645BLS refrigerator 10 degrees warmer than bottom half. Bottom half cooling to approx. 34 degrees.
Is it running all the time without cycling off and on as it should be doing?
Sorry to have to tell you this news.
But this would mean a bad thermostat or insufficient freon in the cooling system.
The same issue with the fact that one compartment is warm and the other is cool!
Let me know that service tells you!
Thank You
Huuum
Please remember toleave a rating
Posted on Oct 19, 2008
There is a check valve inside the coupler of the danby kegs that cause this problem. The valve is mainly there to prevent beer from back-flowing when changing the keg. Next time you change your keg check for a little black plastic retainer and also a small white plastic ball inside the coupler. Remove those (or just smell it) and you should notice that this is the taste/smell your beer has. I removed mine after this discovery, and there isn't any issues with the taste/smell since. I've heard this is a common issue with the Danby D coupler systems. Also, you won't have any issues with beer backflow when you change the keg, provided the line going to the tap is empty (which usually is if keg is kicked).
Posted on Feb 18, 2009
SOURCE: wine cooler noise
Had same problem. cooling fan was going out.Replaced fan about a year ago and now it is going out again. Am ordering another fan now
Posted on Apr 30, 2009
I have a danby kegerator and the code LE keeps flashing
Sounds like a faulty temperature probe or faulty temperature control circuit. Some modify their unit with an external temperature controller. It does require knowledge of wiring to perform the modification. There are detailed notes, images, etc provided by psychodad at
Thread Danby Kegerator Improvements Part II
Aug 27, 2014 | Danby DKC645BLS Compact Beverage Cooler
My kegerator out of the blue starts making noises?
Good chance the compressor is going bad. It will likely die shortly.
May 03, 2014 | Danby DKC645BLS Compact Beverage Cooler
My dodge stratus is making loud humming noise
Have the wheel bearings been checked?
Apr 25, 2013 | 2001 Dodge Caravan
I have a danby premiere model DPAC10071 & the dehumifier now wont fill external tank. every 2-3 minutes it makes a noise kind of like a fog horn way off in the distance(as if its trying to run again,...
it sounds like your compressor is failing to start ... that usually means a bad starting capacitor ... if thats the case it will hum loudly for a few seconds periodically .. thats the compressor trying to start but it cant if the capacitor is bad .. it will stop humming when it gets too hot .. a thermal breaker will turn off the power until it cools back down .. dont let this continue since it will eventually damage the unit ... replace the capacitor .. the capacitor is usually mounted on or near the compressor .. it often has two sections .. one for the fan motor and one for the compressor ... since they are both in one case you have to change them both ,...
Aug 15, 2010 | Danby Heating & Cooling
Motor making loud humming noises and kicks out. Could this be a capacitor on the motor going bad ? This doesn"t happen all the time, but frequency is increasing.
this is the motor overheating and, the overload shutting down the motor: check to see if the motor belt is binding
Jan 23, 2010 | Washing Machines
Danby microwave does not heat food and makes loud constant noise
IF the noise is a sound coming from the oven area, its the megatron tube. Typically, replacing the megatron tube is more expensive than replacing wiht a new unit and a new warranty.
Nov 06, 2009 | Danby DMW112 Microwave Oven
Periodically cycles through a loud humming noise.
Hi, these are the early signs of compressor failure. i would put in a service call before it completely fails.
Mar 09, 2009 | Refrigerators
Danby DKC645BLS Kegerator not keeping beer cold
insulate the tower with pipe insulation, there is a hole in the bottom of the tower. don't over insulate or it will freeze.
Aug 12, 2008 | Refrigerators
Wine cooler noise
Mar 25, 2008 | Danby DWC513BLS Wine Cooler
Danby DKC646BLS Full Size / Pony Beer Keg Cooler Logo
366 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
