Question about Sony Handycam DCR-TRV17 Mini DV Digital Camcorder
Won't close I ejected a tape, put in a new one, and now it won't close at all. The tape carriage goes in a bit, then the mechanism ejects it. Same thing happens with no tape in: I close the tape carriage, the motor runs, the carriage goes in just slightly as if it were getting stuck, then comes back out and opens. No error codes.
  • 169 Answers
SOURCE: Eject is flashing with fast beeps. Won't eject tape or open compartment.
sad to say that the problem of your camera is the timing gear is already damage....it need to disassembly the camera to fix the timing gear....go to the qualified service center for fixing or replacing the timing gear..
Posted on Aug 21, 2007
SOURCE: Ejection Door won't Close
I had the same problem with my 360X.
I took the camera apart and found two screws loose that hold the tape carrier to the rest of the chassis. The unfortunate thing is that I had to pretty much disassemble the entire camera to get to those two screws. It's working again. I'm assuming those two loose screws were the problem.
Posted on Feb 10, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony Handycam DCR-TRV19E Pal do not eject tape
I think, your camera requires new DV Mechanism replacement.
Posted on May 28, 2008
SOURCE: Sony Video 8 TRV30E Handycam keeps ejecting tapes
I was having the same problem. I just gave it a few gentle smacks from every angle possible and it quit acting up.
Posted on Sep 16, 2008
SOURCE: can not eject tape
I had same problem, while transferring media from TRV-16 to DVD, tape would not play, then would not eject. This after transferring several tapes to DVD. I tried several things over the last couple months that did not work before finally getting it open today. It did me no good to remove several of the outer panels that were each held by two "tiny" phillips head screws each. Went to the internet, found your post, also found a post that referred me back to SONY page which follows.......
Follow this procedure to troubleshoot if the cassette compartment will not open or the tape is stuck and will not eject.
IMPORTANT: If your camcorder model has a RESET button, first try pressing this button. If there is no RESET button, or pressing the button does not resolve the issue, continue with the troubleshooting steps below.
  1. Turn off the camcorder.
  2. Remove the battery from the camera.
  3. Remove the AC power supply from the camera.
  4. Slide the power switch on the camera to the VTR , VCR or CAMERA mode for 15 seconds.
  5. Slide the power switch back to the OFF position.
  6. Connect the AC power supply to the camera.
  7. Attempt to open the cassette compartment.
"NOTE: If the issue is still unresolved after completing all of the troubleshooting steps, service may be required."
After I did this, I could hear a whirring sound when I hit eject, although nothing came out. While the whirring was going on, I pulled up and out with constant pressure and the cassette holder opened. The tape had jammed apparently as the little protective plastic tape guard was jammed partially open when I pulled the cassette out. Good Luck and don't be afraid to put a little pressure on the door if you can hear the door trying to open.
Now I turn to recovering the tape, but having grown up with cassette decks, don't believe it will be a problem.
Posted on Jan 23, 2009
My Panasonic VHS Player Model PV-V4020 is locked up so I cannot insert a new tape.
This will be some form of physical damage to the carriage mechanism, that holds the tape. Sometimes it's a simple thing like the flap getting stuck. But often it's a broken piece of plastic.
Apr 21, 2013 | Televison & Video
Canon XL2 - eject button issue
Yes, it seems a loose contact on the button's circuitry. The only way to repair this is to take it in for servicing, unless you're willing to live with it :)
Oct 12, 2008 | Canon XL2 Mini DV Digital Camcorder
I have a used Sony SLV-920HF VCR that I am trying to set up. Every time I insert a tape it ejects it after a few seconds. Any idea why this happens?
There are two things that could be wrong. First damage to the carriage unit that holds the tape, which to me sounds most likely. The other a faulty or out of place mode switch, which could also could be caused by internal damage to any part of the mechanism.
Jan 16, 2013 | Televison & Video
The problem that I am dealing with is that my vcr keeps ejecting my cassette 3 seconds after I put it into the system. I don't know why its ejecting the tape. I have tired old and new tapes.
It could be a number of things. The most obvious one is some kind of damage to the "carriage" which holds the tape. However it could be damage elsewhere. VCR's have a thing called a mode switch. This tells the electronics what position the mechanical parts are in. Any damage can throw this out of position. Also dirt inside the switch can do the same and a faulty switch also. All these things can lead to rejection of the tape.
Mode switches come in all sorts of shapes, but I will post one if you want to hunt around for it. For instance a spray of Servisol Video 40 will clear any dirt out of it.
Jan 30, 2011 | Toshiba W603 VCR
Tape doesn't eject all the time
This probably indicates a problem with the mechanicals. The tape carriage mechanism might be out of whack/bent/or broken. You might take the top cover off and see is the mechanism is sticking somewhere.
Unfortunately, modern VCRs (last 10+ years) are very cheaply made, and disposeable, unlike the machines of the '80s which were built like tanks in comparison. Thus, unless the problem is minor, repair is doubtful.
May 05, 2008 | Televison & Video
Denon Dual Cassette Deck DRW-660 will not eject either tape. I put a tape in right side, played a bit, stopped, will not eject. I put another tape in left side, closed, cannot eject. Cannot eject either....
Some dual decks use a common drive belt. It may have become too slack (due to age) to drive mechanism. I am sure its time to change all belts in both decks. This will solve the problem
Apr 05, 2008 | Audio Players & Recorders
Loading tapes
I had a similar issue where the tape bay would not lock in and engage the motor mechanism to load the tape. I removed the battery from the unit and let it stand for approximately a minute then reinserted the battery. The tape drawer closed first without a tape then reopened with no issue. I then inserted a new tape with no issue. I guess it needed a hard reboot.
Mar 23, 2008 | Sony Handycam HDR-HC3 HDV Digital...
Can't insert tape into deck
Remove the cover again and move the tape carriage all the way towards the front (the carriage is not fully in the locked position). Once that is done you should be able to load a cassette again.
Sep 27, 2007 | JVC SR-V10U S-VHS VCR
SLV 940 HF
Is it having trouble either loading or ejecting the tape? If so, then something is probably awry in that mechanism. Take the top cover off and watch a load or eject operation. If tape isn't fully loaded, and tape threaded, then an error condition will result, as will be the case if it won't eject. Causes include a broken piece of the load mechanism (also called cassette carriage or carriage mechanism), broken or cracked gear. If the mechanism is gear driven, timing is critical, just being out of time one tooth will foul things up. There are often marks on the gears which must line up exactly in a particular mode as specified in manufacturer service literature. Most VCRs since the early '90s are disposeable, very prone to breakage, in contrast to early units which were made like tanks, costing $400 plus.
Aug 26, 2007 | Sony SLV-940HF VCR
Sony Handycam DCR-TRV17 Mini DV Digital Camcorder Logo
54 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
