Question about Nintendo DS Lite Console
SOUND ON MY DS
RECENTLY THE SOUND COMPLETELY QUIT WORKING ON MY DS LITE.  I HAVE THE SPEAKER SET THAT PLUGS INTO THE HEADPHONE OUTLET, THE SOUND WORKS THROUGH THOSE SPEAKERS BUT IS NOT COMING OUT OF THE DS ITSELF...
  • Anonymous Jul 20, 2008
    my ds has no sound but has sound with the head set
Replace the ribbon to the top screen. Look for "ds lite top screen" on ebay
Posted on Oct 28, 2007
Problem with my headphones. If they are completely in the ds the sound is different from what it should be. Some background sounds disappear for example. If they are half in and half out ir works right. I...
Your DS has probably suffered from slight water damage. You might want to buy a new one, seek to fulfill the warranty from Nintendo or the store you bought it from, if they offered a warranty.
Oct 10, 2013 | Nintendo DS Lite Console
My Nintendo DS quit playing sound through the speakers. It only has sound through headphones. One minute it was working then the battery went dead. After I plugged it to the charger the sound does not...
Try leaving the DS on until the battery dies, then charge it all of the way with the DS off. If that doesn't work, I would call Nintendo customer service. They are excellent at helping people with problems just like this. Here is the 800 number I got off of their website. 1-800-895-1672
May 03, 2011 | Nintendo DS Lite Console
DS Lite Console: the speaker keeps making a crackling sound...
use headphones. the speaker just isnt good anymore
May 07, 2010 | Nintendo DS Lite Console
Problem with Motorola S9 Wireless Headset.
Check:
  • Your sound card's Mixer Panel to ensure you have left/right adjusted properly
  • Your sound card may have a speaker-test function, my RealTek tests with "Left" "Right" speech
  • Check your connectors (head phone & speakers) to ensure they are compatible with your sound card
  • Make sure the plug is FULLY inserted in the speaker card socket, it doesn't take much NOT to be fully inserted
dont forget to rate me.......
good luck......
Apr 15, 2010 | Motorola Mobility S9 Headphones
My nintendo ds lite as no sound but it works fine with head phones in can you help me please
It works well with the headphones?
Well.. That's odd.
Check the left side of your DS volume.
there's a toggle button that says
- VOL +
toggle it rightly,as the volume will get higher. Maybe your headphones can adjust the volume. So either contact www.nintendo.com or call Nintendo 1-800-255-3700. Or if you like your DS with headphones,keep it that way.
Mar 06, 2010 | Nintendo DS Lite Console
Nintendo DS Sound Not Working
You might have a wire of some sort out of place as you suggested. I would not try to take of any part of the DS, because if you hit something wrong, or can't get it back together, them you may have to get a new DS. Did your daughter spill something on her DS, or drop it?
If you don't know what happened to the DS, then it may be the companies problem. if your daughter recently got the DS, then you can return it to the store, or send a direct complaint to the company. Even if she got it a long time ago, if it suddenly starts not working at full efficiancy, send it back to nintendo. If you still have the repicet, then send back to the store and tell them what happened.
Hope it helps~
Jan 11, 2009 | Nintendo DS Lite Console
Nintendo DS Lite dropped in puddle breifly, speakers don't work
Well you do know the ribbon cable that connects the two screens is in the left hinge right? You will need to get it repaired eventualy. You many need to check if the ribbon cable is damaged in any way, if it is you will need to repair it or get it repaired. If you choose to do it yourself i'de suggest following this guide. Good Luck!
Jan 07, 2009 | Nintendo DS Lite Console
Volume is not working
You may have something wrong with the speakers themselves. The unit might need to be replaced or repaired.
Dec 27, 2008 | Nintendo DS Lite Console
Nintendo Ds Sound Problem
This option is only suitable for out of warranty devices as opening it violates the warranty.
Open the device and look for loosen or unplugged cables in the main bottom board. Usually this dont happen though opening and closing the unit whe it was not assembled correctly may cause the wires and conductors to loosen or even worst to get cut by the moving parts. So as you say nothing else was done with the unit between plays that is the only explanation I can guess from it.
The headset plug is in the bottom main board so no cables are required to get the audio there, though as the speakers are in the top, these require some flexible cables and conductors running throught the hinges to the top part.
Hope to this info to be helpful: How to dismantle an Original Nintendo DS.
If yours is the NDS Lite, just find this video in youtube:
"Disassembling Nintendo DS Lite"
Good Luck...
Nov 29, 2007 | Nintendo DS Lite Console
Stylus tip stuck in headphone jack(no sound!)
Yes, here is a guide to dismantle an original Nintendo DS:
How to dismantle a Nintendo DS.
And after opening it you may need to replace or try to repair the audio plug. In case you cant, then you must take it out (desoldering it with the stuck stylus tip and the mute switch, which is embeded in the headphone jack) and you can have your audio back.
As the audio switch and the jack only work to mute the speakers audio usually when you plug a headphone then you can lack of it almost all times.
Nov 15, 2007 | Nintendo DS Console
Nintendo DS Lite Console Logo
443 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
