Question about Sony PlayStation 3 40GB System
Trying to connect to internet wirelessly but when i scan for a network it says "The access point was no detected". it used to work but for some reason it doesn't now.
My wireless use to work but now when i try to scan for any networks it says "The access point was not detected"
  • 136 Answers
U should restart your modem
Posted on May 30, 2009
Network adapter hp6505f
If your computer has a wireless network adapter, Windows will automatically detect wireless networks in range of your computer. You can see a list of wireless networks that Windows has detected in Connect to a Network.
  • Open Connect to a Network by clicking the network icon (eff2d36c-9e0d-4d1a-9859-3af14fa4ccfc_73.jpg or da12251d-1e9a-4032-afae-009876c6c5a3_80.jpg) in the notification area.
If Windows doesn't detect a network that you think is in range of your computer, it could be because of one of the following reasons:
  • The wireless switch on your computer is turned off.
    Many laptops have a wireless switch on the front or side of the computer. If your computer has a switch, make sure it's turned on. Some computers also use a function key combination to turn the switch on or off. Check the information that came with your computer for details on locating the wireless switch.
  • Your computer is too far from the wireless router or access point.
    Move your computer closer to the router or access point. If the computer is portable, try moving it around to determine the range of the wireless signal and the best place to use the computer.
    If you can't get closer to the router or access point, consider buying and installing an external antenna for your wireless network adapter. Many wireless network adapters are set up so that you can attach an external antenna to them, which provides better reception than a built-in antenna. Check the information that came with your wireless network adapter to see if you can install an additional antenna.
  • The wireless router or access point is turned off or isn't working properly.
    There are two things to try:
    • Make sure the router or access point is turned on and that the wireless signal light is illuminated.
    • Reset the router or access point by unplugging it, waiting at least 10 seconds, and then plugging it back in.
Sep 10, 2012 | NEC Computers & Internet
Trying to connect my ps3 to my wireless router. Error code after automatic access connection says no connection.
PS3 is not finding your router.
Make sure you choose wireless network under network settings and choose scan for wireless network.
Make sure SSID on router is broadcasting and not hidden.
Make sure router is broadcasting in G or MIXED mode.
Try removing wireless security on the router (open mode) and testing to see if connection can be made.
If connection can be made without security then try with security on.
Place ps3 closer to the router or connect with ethernet cable to verify connectivity.
Verifiy router is working by connecting a laptop or other device to the internet/router.
Mar 05, 2011 | Arris SURFboard SBG900 802.11g/b...
I am having a Compaq nx6325 and recently inside my office we had setup a wireless access point. When I try to view the list of available wireless networks (after enabling the wireless system on my...
Could you connect to the network when hard wired? If not then check the D-link and make sure the LAN set up is correct. If you could then you know the problem is with the wifi only.
When to look under Device Manager does it show that the wireless adapter is working?
Do you see any other networks available? If so you have a mismatch between your router set up and your computer network settings.
Go to NETWORK CONNECTIONS, Right Click on Wireless connections, PROPERTIES. Look to see if Microsoft Client, File and Printer Sharing, and Internet Protocol (TCP/IP 4) is checked. Then click on TCP/IP , PROPERTIES and look at the settings. The GATEWAY must be the same IP as your D-Link, The default IP for the router is 192.168.0.50. If it was set up with a different IP address make sure the wifi gateway is that same address.
If you put in a "KEY" when setting up the wireless router, WEP or WAP make sure you use same when trying to get on the network. You won't get that far if you're not seeing the network on list at all.
Try setting the machine in the same room with the D-Link. Will it detect the network now? If so consider interference with the signal ie metal in the wall such as a furnace.
These are the most common reasons for problems so try these first.
Feb 18, 2011 | Compaq Computers & Internet
How do you get internet on a PSP?
Hi ana01,
Connecting your PSP to the internet is just like connecting your computer to a router. First to consider is having an access point. So what is an access point? Access point is your router. If you wanted to get started going online using your PSP I suggest trying the following steps below:
1. Just turn on your PSP as well as your WLAN/wiresless.
2. Use the left and right directional button to find "Network Setting".
3. Now look for "Infrastracture Mode".
4. Please select "New Connection" and name it.
5. Go to "WLAN Settings" then select "Scan".
6. Your PSP will now detect your router.
7. Navigate to "WLAN security setting". Just leave the option "NONE", If you dont have an encryption in your Router set up.
8. But if have an encryption in your Router. Then put your WEP or WPA security key.
9. Go to "Address Settings". Select "Easy".
10. Navigate to "Setting List". Check if your setting is correct.
11. Go to the next page then save your setting by pressing x. Then press x again once you get a message that says "Save Completed. Test Connection".
12. Next message would say "connecting to access point." The next should say "obtaining IP address".
You already established a connection and you can now browse the net using your PSP.
Hope it helps.
Thank you for using FixYa.
Nov 15, 2010 | Sony PlayStation Portable (PSP) Slim...
How can i take internet in my psp
The PSP is more than a gaming platform. It has WiFi connectivity, and that means that setting up PSP Internet is possible, just like on any computer. The WiFi feature is intended primarily to be used for upgrading software and for downloading games. But you can go several steps further than that, and it isn't difficult to do either.
You need to have access to an Internet connection first and foremost. This can either be at home where you really need a wireless router, or use you can try accessing a public WiFi hotspot like your local Starbucks or wherever.
The most common home set up is an Ethernet cable running from the computer to the DSL or cable modem, which in turn is connected to the telephone line. By installing a wireless router between the computer and the DSL or cable modem, you should be able to connect your PSP to the Internet too.
Of course, setting up PSP Internet isn't just as easy as that! And if you don't have a home Internet connection of any kind, then you'll have to find a WiFi access point that will allow you to connect. This should be reasonably easy in most medium to big cities. But if you live in a small one-horse town way back in the sticks, then maybe, maybe not.
The PSP also needs WiFi access that is the 802.121b wireless networking protocol.
Hmmm... I know what you're thinking. You're thinking, that's it! Way too technical for me! But hold on, it isn't.
This protocol is, thankfully, the world's most popular one. So the chances are excellent that if you find a suitable public WiFi access point, it will be the good old 802.121b wireless networking protocol.
Most people find problems when they come to the more technical bits. Finding the Network Settings, choosing a New Connection, making sure it's Infrastructure Mode - it's all too much for many who try it. Then there's the WLAN Settings to access, a scan to implement for an SSID of any access points nearby, hoping it's not using WEP encryption!
Time to think again...
This isn't rocket science, though some may think it is.
You need, in this order:
1. To have some kind of a proven Internet connection.
2. Select the Infrastructure Mode in Network Settings and start a New Connection.
3. Access the WLAN Settings and initiate a scan to search for suitable access points.
4. Select a suitable access point that is not encrypted.
5. Test the Connection and enjoy!
Sep 10, 2009 | Sony PlayStation Portable (PSP) Console
PS3 can't detect access point
i have some solutions..
1. if there's lots of walls between the router and your ps3 it may not detect the signal. i had a very weak signal until i moved some stuff around.
2. you can manually type in your wireless name and i think it should at least reconize it, and maybe connect.
3. make sure theres no firewalls or anything to block other connections from entering your signal.
thats all i can say, sorry im not a tech guy-only 17!
Dec 27, 2008 | Sony Playstation 3 (PS3) Console
PS3 Wireless issues
Network settings vary depending on the network environment and the devices in use. The following procedure describes a typical setup when connecting to the Internet using an Ethernet cable.
1. Connect an Ethernet cable to the PS3™ system.
2. Select (Network Settings) under (Settings) in the home menu.
3. Select [Internet Connection Settings].
Select [Yes] when a confirmation screen is displayed stating that you will be disconnected from the Internet.
4. Select [Easy].
After you confirm the network configuration, a list of settings will be displayed.
Depending on the network environment , additional settings for PPPoE, proxy server or IP address may be required. For details on these settings, refer to the information from your Internet service provider or the instructions supplied with the network device.
5. Save your settings.
6. Test the connection.
If you select [Test Connection], the system will attempt to connect to the Internet.
7. Confirm the connection test results.
If a successful connection has been made, information on the network will be displayed.
Internet Connection Settings (wireless connection)
This setting is available only on PS3™ systems that are equipped with the wireless LAN feature.
Set the method for connecting the system to the Internet. Internet connection settings vary depending on the network environment and the devices in use. The following procedure describes a typical setup when connecting to the Internet wirelessly.
1. Check that the settings for the access point have been completed.
Check that there is an access point connected to a network with Internet service near the system. Settings for the access point are typically set using a PC. For details, contact the person who set up or maintains the access point.
2. Confirm that an Ethernet cable is not connected to the PS3™ system.
3. Select (Network Settings) under (Settings) in the home menu.
4. Select [Internet Connection Settings].
5. Select [Easy].
6. Select [Wireless].
7. Select [Scan].
A list of access points within the range of the PS3™ system is displayed.
Depending on the model of PS3™ system in use, you may have the option [Automatic]. Select [Automatic] when using an access point that supports automatic setup. If you follow the on-screen instructions, the necessary settings will be completed automatically. For information on access points that support automatic setup, contact your local retailer.
8. Select the access point that you want to use.
An "SSID" is an identification name assigned to an access point. If you do not know which SSID you should use or if an SSID is not displayed, contact the person who set up or maintains the access point for assistance.
9. Check the SSID for the access point.
10.Select the security settings that you want to use.
The types of security settings vary depending on the access point. Contact the person who set up or maintains the access point for information on which setting to select.
11. Enter the encryption key.
The encryption key is displayed as a series of [*]. If you do not know the encryption key, contact the person who set up or maintains the access point for assistance.
When you have finished entering the encryption key and have confirmed the network configuration, a list of settings will be displayed.
Depending on the network environment, additional settings for PPPoE, proxy server or IP address may be required. For details on these settings, refer to the information from your Internet service provider or the instructions supplied with the network device.
12. Save your settings.
13. Test the connection.
14. Confirm the connection test results.
Internet Connection Settings (advanced settings)
If you are unable to connect to the Internet with basic settings, change your settings as necessary. Adjust each item as necessary for your particular network environment.
1. Select (Network Settings) under (Settings) in the home menu.
2. Select [Internet Connection Settings].
3. Select [Custom].
Adjust each item as necessary for the network environment in use. The items displayed vary depending on the settings you have selected.
Connection Method
Set the method for connecting to the Internet. This setting is available only on PS3™ systems that are equipped with the wireless LAN feature.
Wired Connection
Make a wired connection using an Ethernet cable
Wireless
Make a wireless connection via a wireless LAN
WLAN Settings
Set the SSID of the access point. This setting is available only on PS3™ systems that are equipped with the wireless LAN feature.
Scan
Scan for a nearby access point.
Select this setting when you do not know the SSID of the access point. The system will detect nearby access points and display information on the SSID and security settings.
Enter Manually Specify the access point by entering its SSID manually using a keyboard.
Select this setting when you know the SSID.
Automatic U
Use the automatic setting feature of the access point.
This setting is available only in regions where PS3™ systems that support this feature are sold. Select this setting when using an access point that supports automatic setup. Follow the on-screen instructions.
WLAN Security Setting
Set an encryption key for an access point. This setting is available only on PS3™ systems that are equipped with the wireless LAN feature.
None Do not set an encryption key.
WEP Set an encryption key.
The encryption key can be entered on the next screen. The encryption key is displayed as a series of asterisks.
WPA-PSK / WPA2-PSK
Authentication Setting
These settings are available only on PS3™ systems sold in Korea and are available only on PS3™ systems that are equipped with the wireless LAN feature.
None Do not set authentication information.
EAP-MD5 Set authentication information when using public WLAN services.
Enter your user ID and password on the next screen. For details, refer to the information supplied by the public WLAN service provider.
Ethernet Operation Mode
Set the Ethernet data transfer rate and operation method. Usually select [Auto-Detect].
Auto-Detect Automatically set basic settings.
Manual Settings Manually adjust the Ethernet data transfer rate and operation method.
IP Address Setting
Set the method for obtaining an IP address when connecting to the Internet.
Automatic Use the IP address allocated by the DHCP server.
You can enter the DHCP server host name on the next screen.
Manual Set the IP address manually.
You can enter values for the IP address, subnet mask, default router and primary and secondary DNS on the next screen.
PPPoE Connect to the Internet using PPPoE.
You can enter your user ID and password on the next screen.
DNS Setting
Set the DNS server.
Automatic Automatically acquire the DNS server address.
Manual Manually enter the DNS server address.
MTU
Configure the MTU value used when transmitting data. Usually select [Automatic].
Automatic Automatically set the MTU value.
Manual Specify the maximum size of data packets (in bytes) that can be sent in one transmission.
Proxy Server
Set the proxy server to be used.
Do Not Use Do not use a proxy server.
Use Use a proxy server.
You can enter the proxy server address and port number on the next screen.
UPnP
Set to enable or disable UPnP (Universal Plug and Play).
Enable Enable UPnP.
Disable Disable UPnP.
Nov 09, 2008 | NetGear WGR614 Wireless Router
DNS error
try this at DNS # 4.2.2.2 and 4.2.2.1
Oct 18, 2008 | Sony Playstation 3 (PS3) Console
I cant get my ps3 to work with my wireless broadband
Settings > Network Settings > Internet Connection Settings (wireless connection)
Internet Connection Settings (wireless connection) This setting is available only on PS3™ systems that are equipped with the wireless LAN feature.
1.
2.
3.
Select in_networkset.gif (Network Settings) under in_setting.gif (Settings) in the home menu.
4.
5.
Select [Easy].
connectwired002.jpg 6.
Select [Wireless].
connectwireless001.jpg 7.
Select [Scan].
connectwireless002.jpg 8.
connectwireless003.jpg 9.
10.
connectwireless004.jpg 11.
connectwireless005.jpg When you have finished entering the encryption key and have confirmed the network configuration, a list of settings will be displayed.
12.
Save your settings.
13.
14.
Hints
  • If the connection fails, follow the on-screen instructions to check your settings. Also refer to the information from your Internet service provider and the instructions supplied with the network device in use.
  • If you test the connection immediately after selecting [Automatic] > [AOSS™] in step 7, the router settings may not be completed and the connection may fail. Wait approximately 1 or 2 minutes before testing the connection.
Mar 12, 2008 | Computers & Internet
Not detecting any wireless networks
You have not mentioned having a wireless router or access point to serve as the hub on an infrastructure network. I you have a router please let me know -- the instructions for the solution changes.
The following is an article to create an ad hoc network between wireless cards without a wireless access point or a router. If you ignore the steps about connecting to the internet with a wired connection and the internet sharing instructions. This will allow your machines with wireless adapters to communicate with each other (assuming the operate on a common band). The article goes on to indicate one machine with a wired connection can act as the "router" for the other two when it is on to allow them share internet access with the wired machine (the wired machine also needs a wireless card for this to work).
Ad-hoc networking access point
Jan 03, 2008 | D-Link AirPlus G DWL-G510 802.11g/b...
Open Questions:
Sony PlayStation 3 40GB System Logo
71 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
