Question about Toshiba TP55F80/81 55" Rear Projection Television
I have a toshiba TP55C81 projection TV. The red The red vertical adjustments stopped working. The adjustmnet knob in the control panel does not effect the adjustment and none of the vertical adjustmen
The red vertical adjustment on my tv does not work..... I hear that there is an amplifier that needs replaced? Would I be able to get the service manual from you? I'm sure I can fix this myself, if I had a schematic of the circuitry. thank you...... I have a toshiba TP55C81 projection TV. The red The red vertical adjustments stopped working. The adjustmnet knob in the control panel does not effect the adjustment and none of the vertical adjustment on the board have an effect on the red. All other adjusments work even the red Horizontal.
    Problem Solver:
  • 13 Answers
You need to replace the vertical STK convergence chip but I would recommend that you replace the horizontal chip at the same time as this is likely to fail soon.
The following relates to the repair I have recently carried out to my Toshibal 40WH08B rear projection TV but shuold be very similar to your model. Replace the STK chips with the same type on your model:
On the convergence board PB 9487 (the one with the 2 large heat sinks that the r, b & g guns plug into) you will see two STK392-110 ics connected to the large heat sinks. Replace both of these and readjust convergence in service mode if necessary.
I obtained the replacement ics from Charles Hyde & Sons Ltd (see link below). I ordered the general ics not the Toshiba ones as these are identical as far as I could see and they cost £17.19 each instead of £36.68 each.
http://www.chsinteractive.co.uk/search.html?query=stk392-110
You will need to desolder the heat sinks as well as the ics as access to the ic mount screws are obstructed by the conv.dig board (metal cased). Buy a good quality desolder pump if you dont have one.
One last thing I should mention. The white paste between the ics and the heatsink is silicon thermal compound. Without this the heatsinks will not take heat from the ics effectivly and the ics will burn out! I recommend that you clean all of the old paste off the heatsinks and apply new to the whole of the metal plates on the back of the ics before you screw them to the heatsinks. You can get the thermal compound and the desolder pump from the same supplier I recommended for the ics.
Let know if your are having any problems.
Posted on May 30, 2009
My picture is doubled on my toshiba TN50V71 as if there is a shadow behind everything? Please help!
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
    good luck!
  • Feb 02, 2011 | Toshiba TN50V71 50" Rear Projection...
    I RECENTLY PURCHASED A 1994 bIG SCREEN TV ( mODEL # TP55C81 ) THE PICTURE IS PURFECT BUT IM SEEING THE RED GREEN AND BLUE LIGHTS . THE CLOSER I AM TO THE TV THE SMALLER THE LIGHTS ARE AS I BACK UP THE...
    You have a projection TV - basically a red, green, and blue spotlight is shown onto the back of an opaque screen that creates the color picture you see. The spotlights you are seeing is common for a TV of this vintage and type.
    According to the user's manual, you should ideally be sitting no closer than 10 feet to the screen.
    Sitting closer to the screen may enhance the phenomenon you are experiencing.
    Nov 19, 2009 | Toshiba Televison & Video
    Toshiba TN61x81-- after convergence IC's replced
    Please don't be offended by my suggestions if you are experienced at circuit repair.
    You may have a cold solder joint or bridged joint. Check and re-check your connectors for placement. It is normal to have to adjust the convergence and focus after replacing the IC's. There should be a row of focus knobs (ususally covered by a piece of black tape) with the screen controls.
    The convergence IC's won't affect the visibility of a color only the alignment.
    Sep 21, 2009 | Toshiba TN61X81 61" Rear Projection...
    Faint lines show up when i get dark screens in movies
    First check what color of faint lines comes then reduce Screen Volts in TV of that CRT (tube)
    Take off lower front cover, speaker grille of TV, there you will see focus control block that has 6 control knobs, upper 3 knobs are focus adjustment of red-green-blue CRTs and lower 3 knobs are screen volt controls for red-green-blue CRTs. Turn screen volt control knob CCW to reduce screen volts of desired CRT.
    Put TV on any free AV input so screen will be dark enough to adjust screen volts.
    Thanks.
    Aug 28, 2009 | Sony KP-57WS500 57" Rear Projection...
    NEEDS VERTICAL/HORIZONTAL HOLD ADJUSTMENT
    Their is no more you can do.
    Their are no "hold" controls on TV's anymore.
    Power Supply failure.
    NO YOu can not buy a "Powers supply"
    You need a professional.
    Stop using the TV until it is repaired.
    Call the manufacturer to find you nearest authorized service center.
    MR. TV Sales & Service Inc
    Milwaukee, Wisconsin 53405
    (414) 762-8600
    Established 1974
    Mar 24, 2009 | Sony KP-51WS520 51" Rear Projection...
    Toshiba projection tv three colors
    Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
    This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
    Common Symptoms include....
    • Screen looks 3D
    • Colors don't line up
    • One or more colors can't be adjusted when using the convergence menu.
    • Screen is bowed or warped.
    • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
    Here are some photos of convergence problems.
    Here is a quick test....
    Using your original remote go-to the settings menu then goto the convergence section.
    Try to adjust the red and then the blue convergence.
    You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
    If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
    Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
    69189a5.pngCONVERGENCE SOLUTION
    You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
    This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
    Mar 23, 2009 | Toshiba 55H70 55" Rear Projection...
    My colors all of a sudden went out of wack
    Is there an advanced convergence setup anywhere in the menu where the screen displays a grid? If so, you might want to get into that and move along the grid to each section that looks off. Adjust until the color falls behind the gridline, and move on to the next. It can be a time-consuming process, but should take care of your convergence issues.
    Jan 20, 2009 | Toshiba 55H70 55" Rear Projection...
    Mitsubishi WT-42313 42 in. rear projection tv
    I guess I have to pay money for a solution, which is not what this website says. The only answer I got was pay money and we'll tell you. Is that true/
    Sep 16, 2008 | Mitsubishi WT-42313 42" Rear Projection...
    Convergence problem with Toshiba TV 42H83
    I am still working on it! Need a technician in Alacante Spain!
    Jul 25, 2008 | Televison & Video
    Toshiba tv-model tz55v61
    If the red,green and blue mixture adjustment is what you want...
    remove front lower speaker grill & access panel..locate RGB
    adjust on Screen / focus block.......slightly adjust screen controls for best mixture....do not adjust focus controls.....T.
    Jan 10, 2008 | Toshiba TZ55V61 55" Rear Projection...
    Televison & Video Logo
    246 people viewed this question
    Top Toshiba Televison & Video Experts
    Jaime Hernandez
    Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
