Question about Husqvarna 28cc Gas Line Trimmer
Gas ratio and string load
Need to know the gas ratio for a 323L and how to put the string on correctly, please. Thank You
Replace string on 323L tap out line terimmer
I'll send you a link to the online manual.
Mar 22, 2012 | Husqvarna 28cc Gas Line Trimmer
I have a troy bilt string weed cutter 27cc TB21Ec and need to know the oil gas ratio. I just read that it takes straight gas but my cap on the weed cutter where you put the gas says gas/oil mixture
Don't know that exact trimmer, but I always run 40:1 in all my trimmers, chainsaws, etc. That is 3.2 oz. of 2 cycle oil to one gallon of gasoline. I rebuild these machines daily and run that mix in everyting, except when it's actually specified on the machine.
Aug 11, 2011 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
I have inherited a Homelite UT20680 (1997?) string trimmer in reasonably good shape. I need to know what size string to use, & how to install it, & also what gas mixture to use. Any help would be...
ratio is 32:1, You need .065 trimmer replacement line. here is a thread on how to string it, Good Luck Tim:
http://wiki.answers.com/Q/How_do_you_install_new_string_on_a_homelite_weed_trimmer
Apr 24, 2011 | Garden
Troy built 27cc string trimmer Model TB21 EC. What is the gas oil mix ratio?
4 cycle engines do not run on mixed fuel. Run on straight fuel. They have a spot to put oil in just like a lawn mover, and should be changed regularly. @ stroke engines run on mixed fuel.
Sep 27, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
No Owner's Manual Came with My P2500, 17" Gas String Trimmer
Hello, It would appear that manuals were not included in this model :) Here is the link you have requested. The page should show four choices for download by year of manufacture - click accordingly. If the selection does not show and the search parameters are blank, simply type P2500 into the "Type your search query (i.e. product name)" box and you will get the same results.
http://www.poulan.com/node7925.aspx
Hope this helps!
Jul 30, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Correct gas to oil ratio for Homelite Mighty String Trimmer Model
most trimmers are 50:1. or 40:1. i would use synthetic 2 cycle oil and use the 50:1 ratio. i know guys with trimmers that require 50:1, and they use synthetic at 80:1 with no problems for years. they say the engine runs cleaner. i am a part-time lawn care operator.
Jun 18, 2009 | Homelite Mighty Lite Lawn Trimmer
Craftsman chainsaw ps00376 2.0 cubic inch oil/gas ratio
Hi rbv1222,
40:1 is the ratio.
40 parts Gas to 1 part oil.
3.2 oz of oil per gal gas.
Glad to be of assistance. Please rate the solution because I can learn from your rating.
Thank you
Nov 08, 2008 | Garden
Husqvarna 28cc Gas Line Trimmer Logo
144 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
