Question about Nintendo DS Lite Console
Ds top screen half normal half green tint
Hey. I recently put in a description of this problem, but i have more info on it now. On startup the entire top screen is normal colour but after a few seconds you can just detect some green writing appear on the right centrally. After another second or two the entire right half (exactly half) of the screen fills in with a green tint (same as the writing that appeared first). Is this a memory error or is there something i can fix myself
Regards
M.
  • mooseman2 Oct 30, 2007
    Already replaced screen, but it was noticable when i had a cracked screen as well. After new screen installed it was exactly the same.
I had the same problem  but it was blue tint shortly after the ds would turn on flash then turn off turned out to be the wire ribbon to top screen:: needed new top screen!!
Posted on Oct 27, 2007
SOURCE:
My daughters DS Lite has an issue with the upper screen. One of the kids actually "bit" it !? so now the LCD screen has an area where the colors blur and bleed down. Is this repairable or do I...
you can get this repaired, should cost around 50 bucks either find a playntrade video game store, they do repairs, or find a place in your area where hey do repairs on systems
Jan 25, 2011 | Nintendo DS Console
Blank top screen
This is one of those things that I regret to say but the only way to repair this would be to order a new Flex cable. the flex cable is a small flat ribbon cable that connects the bottom half with the top half. It would be easer to replace the entire thing instead of just the ribbon cable
May 20, 2009 | Nintendo DS Console
Can"t find white or comfortable background screen other than a light green that is hurting my eyes
If you have a screen that gets "tints" of various colors on a corner or edge, check that the monitor plugin cable is not near or laying on top of a power cable, the magnetic field around a power cord will cause a monitor to get strange tints or lines in the screen. Option two if the entire screen has a tint equally all over it is possibly the color is out of adjustment or failing - a technician should be able to adjust it internally.
Apr 29, 2009 | AOpen A75PF Monitor
Reddish tint on the screen
LG 700e
power suply is dad
resistanc is black not show it ohom
plz help
Dec 21, 2008 | LG Studioworks 700S 17" CRT Monitor
Over Heating
It is problem of green CRT (picture tube) in TV and needs to be replaced.
Need further help / info, let me know please.
Nov 01, 2008 | Sony KP-57WS500 57" Rear Projection...
My Screen!!!
hi
restatrt your system and press F8 KEY UNTILL U GET MENU.
then go to best configuration or safe mode.
then if u get normal window change your display resolution to 800x600 or 1024x768.if u get differ reso.
restart in normal mode u get good display in original content.
pls notify this solution
Mar 23, 2008 | Toshiba Satellite R10-S802TD Tablet PC
Green Tint on half of the screen
This is most likely a defect in the optical unit (about $1500.00 part). If out of warranty probably will just have to live with it. Those op units are also hard to get.
Jan 15, 2008 | JVC HD-61Z575 61" Rear Projection...
DS broken in half
I recommend you to change the broken case, you can choose to change only the hinge and keep the good case parts or change the entire shell. By the way stores usually sell the entire shell so you can choose. As your screens are still working you are lucky because so often the brown flexible conductor to the top screen get broken so be careful.
You can also use a silicon or hard plastic case to put over your broken NDSL to keep it in place just as the fast non technical option.
Here are some links and you can find text and video guides googling around.
Shells in ebay
Other stores items
Good Luck...
Nov 09, 2007 | Nintendo DS Lite Console
Green and purple tv picture.
this is degaussing problem
keep tv off for half an hour and if you have changed the direction keep it as it was.
if any magnetic thing is there near to tv remove it like speaker or headphone etc.
hope this will help.
Oct 15, 2007 | Toshiba 32AF43 32" TV
Green tint on screen
Is it a green tint at some areas alone, oris the entire image having a green tint? If it is a color patch at the corner or other areas of the screen, in all likelihood it is a degaussing problem. Color patches happen when the TV is moved from one location to another, or if some magnetic source is placed close to a CTV. Did you put a radio or Tape recorder or Walkie talkie toy or any magnetic source near the TV? if yes, remove it. And the automatic Dregaussing circuits in the TV will resolve the problem in a couple of days. But if there is an overall Green tint on the picture, it signifies a problem in the Video output stages, and there is nothing you can do, but call the technician (unless you know solid state servicing?)
Aug 07, 2007 | GE 27GT619 27" TV
Nintendo DS Lite Console Logo
639 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
shevantha perera
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
