Question about Indesit WA 125 Front Load Washer
Indesit W 125 X Washer Handle Broke Off and Door Will Not Open
My Indesit W 125 X front-load washer handle snapped off the door and I cannot get the door to open.  I have removed the top of the washer and can see the lock mechanism but cannot seem to locate the manual release.  My clothes are in the washer...please help!
Use something lopng and thing, a thin screwdriver operhaps. Pull the metal bar ( part of the spring) to the left. When this is fully to the left push the white plastic part in and jiggle about util the door comes off. Might be easier with sumone to help you pull the dor out as you uch in
Posted on Mar 29, 2008
SOURCE:
After fwashing, I tried to open the door. Unfortunately I broke the door handle. Now I hope to open it, and get the washed clothes out. But I can not open the door.
no easy way to open
disconnect from mains
take top off. feel down the front to where the door lock is and see if you can feel the door peg sticking thro the door interlock. force this with your fingers and with luck the door will open
if can't do this way, break handle off and lever peg with a small screwdriver
you can buy a handle kit complete. fitting this is not difficult - split the door and all will be revealed advise you make a carefull note of where springs go etc before you start stripping it down or take a few fotos if you have a digicam
Feb 14, 2011 | Indesit W 123 Front Load Washer
Need a new door opening handle?? the handle broke
You should be able to order one from Splendide. In the meantime, try using a screw driver to manually push the door release button.
Michael Lee
Thor Appliance Company
www.thorappliances.com
Sep 22, 2010 | Splendide 2000S Front Load Washer / Dryer
Door wont click shut the handle on door wont engage in slot
The spring is probably broken in the door hnbdle, you will need to seperate the 2 door halves to check if this is the case#Hope this helps.
Jan 02, 2010 | Indesit WA 125 Front Load Washer
Suspect door handle is broken on Indesit Washer Dryer WD12x
yes u can open door from the inside,take the top off (take plug out first)put your arm down to near the door latch and you will feel the mechinism there just gently push down or up until the door opens,if water is still in the washer then take drain pipe out of the waste pipe and place a bucket on the floor then put the pipe in that to manualy drain it,hope this helps you,ps you can buy a new door handle from any washing repair shop and they are easy to replace just see how the old one comes off,rgrds,paul
Jul 07, 2009 | Indesit W 123 Front Load Washer
Broken door handle for a Thor washing machine
there r 2 ways to get the door open 1)use a normal knife and place in front of the door handle push it in and it should open 2)pull the plug out take the lid off now place your hand down to where the catch goes into the washer using your fingers u should be able to pop it open with a bit off fiddling
Dec 15, 2008 | Hotpoint Aquarius WD640 Front Load...
Change grip/handle on a indesit washing machine w105tx
Undo any screw that you can see on the inside of the door frame, and then prize the two halves apart,
This should give you access to the door handle assy.
Hope this helps.
Dec 02, 2008 | Indesit WA 125 Front Load Washer
Hi, the handle has broken off my Indesit WA 125 Front Load Washer. I cannot open the door to get my clothes out, any suggestions? Also, would it be possible to buy a door (part of the plastic on the door...
I don't know where you live but in St. Paul and most other cities, there are appliace parts distributers, adn they sell to the public. If you can figure out how to get what is left of the handle off of the machine, you can probably put a new one on.
Sep 05, 2008 | Indesit Washing Machines
Fixing broken door lock of Indesit W123X washing Machine
no easy way to open
Jul 10, 2008 | Indesit W 123 Front Load Washer
Indesit WA 125 Front Load Washer Logo
692 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
