Question about Minolta Maxxum 5 / Dynax 5 35mm SLR Camera
Sony Vaio S3VP/B laptop power switch problem
Power switch flashes on an off on my Sony Vaio laptop when I put my finger on the power button to switch it on, but nothing else happens, means laptop cannot be switched on. What could have gone wrong?
  • 5 more comments
  • Amar Verma May 30, 2009
    Thanks for further questions. Yes when I put my finger on the power switch the the display lights flash on for about half a second then go off then come on again, nothing else happens, the laprop cannot be switched on at all
    Do you think it is not a power supply issue?
    Yes the laptop is connected to the power adaptor. Anything I could do to repair this? I have opened these laptops before and changed the CPU once with success, shall I try this as I do happen to have a similar CPU from a different similar laptop?
    It will be a long job, I was trying to avoid. But, I will have a go at it later as I have nothing to lose. Lappy is dead anyway! Thanks for your input. With Best wishes...av
    Not yet but good input
  • meteshadow May 11, 2010
    any lights on ?
  • 489 Answers
Ok. it doesnt look like you have problem with heat.
mainboard or Cpu issue that you have. need to get service.
Posted on May 30, 2009
  • 1 more comment
  • meteshadow May 30, 2009
    mainboard or cpu is cuttuing the power. i am assuming the laptop connected the adapter.
    if you are able to open, you can change the cpu that makes sure if the cpu or mainboard issue. use smililar Cpu. anyother may not been supported.
    pls rate this solution.
Sony vaio PCG-61211M wont turn on and the power button starts flashing on and off
This can be a sign of a discharged battery, and this may be due to a faulty adapter or the connection in the laptop.
Dec 13, 2013 | Computers & Internet
Sony Vaio E series laptop not turning on
check your ram slot.check your bios setup.or reset it.remove your battery press power button 3/5mnt and connect ac power now power on.
May 30, 2013 | Sony VAIO EB Series White Notebook...
My sony vaio cannot open, even battery is charging or plug in, i cannot power on the button? what is the problem please help... thank you
*Take out the battery,
*Remove main supply,
*Hold power button down for 30 secs,
*Put only power supply in, do not put battery in
*Turn laptop on
*Put the battery in.
Jul 16, 2011 | Sony VAIO VGN-FJ180P Notebook
I have a sony vaio v505bx when i pres the power butten the boot led and the power led flash once then nothing. When i plug the ac adapter in the power led flashes like it is charging the battery but thats...
I had same problem with my HP dv9922us. it is ether the power switch or the motherboard overheated and cooked. wish i had better news but there are not much to laptops.
Nov 04, 2010 | Sony VAIO V505 Notebook
I have a Sony Vaio laptop, model PCG-384L. It will not power up. My wife indicated that she push some button that lock the power. Can seem to find the button that controls or locks the power button. ...
Typically that flashing light means low battery. Which makes sense, as you probably have an issue with the AC Adapter that you plug into the computer to charge it, or the DC Jack that this adapter plugs into on the laptop. Either of these things will cause your computer to not charge the battery, and if there isn't enough power it won't turn on.
Aug 10, 2010 | Sony VAIO Notebook
My sony vaio vgn-fs285e will not switch on since this morning. Even if the AC adapter is plugged-in it still won't come on. None of the lights come on, it won't run with the battery pack or just AC power....
To check if the problem is the power adaptor or the Vaio, just have a look at the charger itself and see if the green light on the adaptor itself is on?If yes, then more likely it is working fine. If no light, change the fuse in the plug and try again.
You can also try a static discharge on the Vaio. Please remove all external devices, unplug the adaptor and remove the battery. Put your finger on the power button and hold it for about 30 seconds. Then connect the power adaptor again and try to boot.
Regards,
Purito
Oct 17, 2009 | Sony VAIO NR Series Notebook VGNNR460EP
My Sony Vaio RX624's power buttone flashes orange
Is your pc not giving display? What are the number of beeps?
Jun 24, 2009 | Sony VAIO PCV-RX624 PC Desktop
tipycaly this is motherboard power problem, but not always. remove battery and try again. if not, find someone who knows electronics, he can help you.
May 30, 2009 | Sony Computers & Internet
Minolta Maxxum 5 / Dynax 5 35mm SLR Camera Logo
228 people viewed this question
Top Minolta Photography Experts
Greg Cann
Greg Cann
TC CAMERA REPAIR.Com...
Are you a Minolta Photography Expert? Answer questions, earn points and help others
