Question about Panasonic KV S2026C Path-Through Scanner
Scanner does not showup in scanning programs
Went to control panel and is says that the scanner is working properly. When I go to Scan properties it says it does not detect a scanner
    Sergeant:
  • 145 Answers
The scanner is absolutely working if connected
your problem is on the "ultra side bus"
it's not connected....
try to update your USB driver, maybe it's not support the old version
Posted on May 30, 2009
Cannot scan a document. error 017 988 ?
To resolve this:
Step no 1:
Check the cable of your USB that it is connected correctly or not.
Step no 2:
Check the driver of a scanner that it is completely installed
Start -> Control Panel -> Scanners and Cameras.
Step no 3:
Check the 'Scan Button Manager' whether it is installed or remove
Start -> Control Panel -> Add or Remove Programs.
If not installed then install it by CD.
Step no 4:
Now click on "Scan Button Manager" and check the settings.
Scan Form/Image Type/ Resolution/ Paper size/ Output Destination.
Step no 5:
Check that the software selection is correct or not:
Start -> Control Panel -> Scanners and Cameras -> Right Click on Listed Scanner and click on Properties -> Events
If all requirements are correct and still the problem remains then contact the Dell Technical Support.
Piracetam Racetams
Jan 16, 2016 | Office Equipment & Supplies
The pdf button does not work
Make sure Epson Scan and the Epson Creativity Suite are installed correctly. See the Start Here sheet for instructions.
  • Make sure your Windows system is set up for scanner events as follows.
  • Windows Vista:
    Click sw_startbutton_1_er.gif > Control Panel > Hardware and Sound > Scanners and Cameras, or click sw_startbutton_1_er.gif > Control Panel and double-click the Scanners and Cameras icon. Click your scanner's icon, then click Properties. (When you see the User Account Control window, click Continue). Click the Events tab in your scanner's Properties window and make sure Take no action is not selected. Also, make sure the desired button is selected in the Select an event list box, and Start this program is selected.
    Windows XP:
    Click Start > Control Panel > Printers and Other Hardware > Scanners and Cameras, or click Start > Control Panel and double-click the Scanners and Cameras icon. Then right-click your scanner's icon and select Properties. Click the Events tab in your scanner's Properties window and make sure Take no action is not selected. Also, make sure the desired button is selected in the Select an event list box, and Start this program is selected.
    Windows 2000:
    Click Start > Settings > Control Panel, double-click the Scanners and Cameras icon, then select your scanner and click Properties. Click the Events tab in your scanner's Properties window and make sure the Disable device events check box is not checked. Also make sure the desired button is selected in the Scanner events list box, and the desired application is selected in the Send to this application list.
  • In Mac OS X, make sure you did not install the scanner software in Classic mode.
  • Epson Perfection V500 Photo Scanner
    Sep 17, 2013 | Epson Perfection V500 Flatbed Scanner
    Brother control center 4 won't open on my computer
    This may help others with scanning issues:
    I just bought a Brother MFCJ6510 printer/scanner and was nearly driven cracked trying to get the scanner to work as it was not talking to the PC, even though as a printer it was working fine. Realised eventually that it was just the Brother Control Centre 4 it wasn't talking to. After hours of re-installing software and updates, etc, nothing worked.
    The solution: I went into Control Panel on my PC (I use Windows XP), to the Scanners and Cameras section, and in there the Brother Scanner was visible and could be used from there, Click on it to open the Windows Scanner and Camera Wizard and use that. Further, by right-clicking on it and going to properties I choose the software to start when it talks to the PC. I abandoned the Brother CC4 and set it up to start the Scanner and Camera Wizard if I choose 'Scan to Image' on the scanner control panel, and to open Photoshop if I 'Scan to File' on the scanner. Works fine either way, just make sure you choose the right dpi setting to suit your needs.
    Hope this helps somebody else as frustrated as I was.
    Apr 17, 2013 | Brother DCP Office Equipment & Supplies
    Brother mfc-j6510dw will not scan
    I just bought this and was nearly driven cracked trying to get the scanner to work as it was not talking to the PC, even though as a printer it was working fine. Realised eventually that it was just the Brother Control Centre 4 it wasn't talking to. After hours of re-installing software and updates, etc, nothing worked.
    Aug 09, 2012 | Brother MFC J6510DW - Multifunction fax /...
    As I want to scan a paper, scanner does not work properly. I tried many times but the scanner cut the paper from diffent areas as I tried over and over for several times. I got the exact scan maybe ten...
    the drivers for the scanner might have been corrupted
    you might have to uninstall the scanner restart your computer then reinstall your scanner
    if your printer/scanner came with an installation disc the drivers could be on it
    you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
    click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also have option to troubleshoot
    lift the lid on your scanner lay the photo face down then select scan document/photo it will ask what format you want to scan it then it will ask where you want to save it browse select the file/folder where you want to save it (my pictures) most common
    hope this helps
    May 02, 2011 | Computers & Internet
    I have just bought a HP Photosmart plus B210 printer. I have installed it ok and it is wireless connected. everything seems ok for printing but when I try to scan to Paint shop Pro 7 or from Word 2003 it...
    Hello Carol,
    The first thing you want to do is check to make sure the scanner driver is installed properly and working.
    If you are running Windows XP or Vista; go to Start Menu \ Control Panel \ Scanners and Cameras
    NOTE: For Vista user you must select "classic view" in control panel to see scanners an cameras.
    For Windows 7; go to your Start Menu, in the "search programs and files" section (found below "all programs") type in "scan". You will see a result for View Scanners and Cameras.
    Now you should see the HP scanner here. If it is not here then you need to reinstall because the scanner was not installed properly. If the scanner is here, right click on it and select Properties. (For Windows 7 you do not have to right click, you will see Properties at the bottom of the window).
    In the properties select "test scanner". If this test fails, the driver is not working and you should uninstall and reinstall the HP.
    If this test works then the driver is properly installed. HP should have provided you with some sort of scanning software, try scanning using that. You can also try scanning using Windows Fax and scan (for windows 7), Windows Photo Gallery (Windows Vista) or the Windows Scan wizard (Windows XP).
    Thanks,
    Pat
    Nov 07, 2010 | Office Equipment & Supplies
    Perfection 1670 Flatbed Scanner: When I try to scan I get a message saying: "Can...
    Do the following:
    Uninstall the scanner from your computer
    Restart
    Re-install all software and drivers with the original CD * if you dont have the drivers check the manufacturars website *
    Restart again
    And then it should work fine. If this fails use the scanner wizard in Windows Control Panel and follow the step by step instructions.
    May 18, 2010 | Epson Perfection 1670 Flatbed Scanner
    Cannot scan
    you must be install your scanner driver or scanner software. If you see your scanner properties then you can get scane
    Oct 23, 2009 | HP DeskJet F4280 All In One Printer InkJet
    I am trying to scan a document on the C7200. Last time I went somewhere on my computer, but can't find.
    Try Control Panel, Printers and other hardware, Scanners and cameras..............or, your scanner program such as Scansoft or some other program that came with the computer or is available at the Scanner company website..........or, Scanner and camera wizard program in Accessories........or, free programs you can download like Open Office (a great program) or Picasa.
    Aug 21, 2009 | Office Equipment & Supplies
    Computer can't connect to scanner
    If you are using Win XP there's another way of testing it with your computer for to check if your scanner is damaged or just a simple
    software issue:
    Usually for Epson it came with an Application called "Epson Scan"
    > with the scanner connected to your Computer try to scan using a diff Application like PhotoShop or MS Paint
    > to scan using Paint
    Click on Start / All Programs / Accessories ( click and open "Paint" )
    > from Paint click on File / and click "From Scanner or Camera" and it will open a scanner wizard., just follow the step by step procedure on how to scan.
    note: if you have a diff. imaging devices ( like web cam ) it may ask you which one to use., make sure to select your scanner.
    > if it can acquire an image using paint or diff application., there's no issue with the scanner unit.
    > if it cannot acquire an image using paint or diff application., your scanner is broken / damaged.
    To fix the issue with Epson Scan
    > Uninstall "Epson Scan" from Control Panel / Add or Remove Programs / disconnect the scanner unit "USB cable"
    > Control Panel / Administrative tools / Services ( look for Windows Image Acquisition < WIA > click on it and restart the service.
    > Close all the windows and restart your computer.
    Download the Twain Driver from the Epson Website
    http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=88043&prodoid=63070037&infoType=Downloads&platform=Windows
    downlad > TWAIN Driver and EPSON Scan Utility v3.12A
    epson12526.exe )
    note: if you don't have internet you can use the cd that came with scanner...
    > after it is installed your computer might restart and then:
    > click on Start ( right click on My Computer / left click on Properties ) on the Properties window click on Hardware Tab / Device Manager / on the device manager window look for "Imaging"
    under Imaging look for your scanner ( right click on it and click on update driver., select this time only hit next / select Install the software automatically ( recommended ) hit next and it will update your scanner driver.
    > Close all windows and Launch Epson Scan
    Mar 22, 2009 | Epson Perfection V200 Flatbed Scanner
    Panasonic KV S2026C Path-Through Scanner Logo
    132 people viewed this question
    Top Panasonic Office Equipment & Supplies Experts
    CheckitRight
    CheckitRight
    Norman  J Weimar Jr
    Norman J Weimar Jr
    Mitch S
    Mitch S
    Level 1 Expert
    Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
