Question about Lands Phones
How to you listen to your voice mails
How do you hear your voicemails
  • Steve Williams
    Steve Williams May 11, 2010
    what kind of phone do you have? Cell phone or home phone. If home phone.. whom is your provider or do you have an answer machine built into your phone unit?
Press Play
Posted on May 31, 2009
I have a tracphone. How do I clear my voicemail box? No messages can be left on my voicemail. Thank you.
Delete voice mail by going through the keypad on your cell phone. The actual procedure depends on the kind of cell phone that you own. For example, on the Nokia 1100, hold down the "1" key while you are on standby. Tracfone connects you to your voicemail, where you can follow spoken menu instructions to listen to your voicemail. After you hear the voice message, you're asked if you want to delete your recordings.
This is not recommended, because connecting in this way uses up your minutes even if you just want to listen to them.
Use your landline phone to delete messages if you want to avoid using your Tracfone minutes. Turn off your cell phone so it doesn't ring and then call your cell phone number from a landline.
Press the "*" (star) key as soon as you hear your voice mail greeting. Then enter your password number and press the "#" (pound) key.
Listen to the instructions for accessing your voice mail, which can vary slightly depending on the phone you have. You are told the number of new and old messages you have, how to listen to them and how to store or delete them. Press the number for listening to the message to hear it, and then the number for deleting.
Sep 08, 2017 | Lands Phones
I need to change my password to hear my voice mail
PHONE YOUR NETWORK PROVIDER WHO WILL REMOVE THE PASSWORD OR RESET VOICEMAIL SETTINGS SO YOU CAN SETUP AGAIN.
Mar 15, 2016 | Samsung Galaxy S GTI9000 Smartphone
How to listen to voice-mail box ?
Press the voice mail button or dial the pilot for the voicemail, enter the password or ID your own extension (9+ext) on really old voicemails, then password, listen to the prompts or use the active buttons in the display.
Jun 16, 2014 | NEC Dterm DTP 16D-1 Corded Phone
Dont know how to set voicemail and directory
1.Press the "Menu/Select" button.
2.Use the up or down arrows to navigate to the "Voicemail Setup" option and press "Menu/Select."
3 .Navigate to the "Access Number" option and press "Menu/Select."
4 .Use the number pad to enter your voice mail access telephone number provided by your telephone company. Use the "Mute/Remove" button to delete any numbers entered by mistake.
5.Press "Menu/Select" to hear the confirmation code.
6 .Program the "Password," "Play," "Erase," and "Skip" options following the above steps, substituting the "Access Number" option in step three with the option you desire to program.
7 .Dial your voice mail by using the "Voicemail" button on the telephone.
8 .Listen and follow the prompts provided by your telephone company to set up your voice mail's greeting.
9 .Use the "Voicemail" button any time you wish to dial into the system to listen to voice mail. Use the programmed "Play," "Skip," and "Erase" options to navigate through your messages.
Apr 15, 2011 | Vtech Lands Phones
A voice mail has been trapped in the voicemail inbox of my motorola w180 handset. I cant delete it even after a master reset and a master clear. Pl info me how to solve this problem.
have you tried calling your voicemail inbox and deleting it there? normaly a voice mail is not saved on your phone, but at your provider. so you have to call your mailbox as if you want to listen to your voicemails, and there you can choose to hear, to save or to delete it.
Oct 16, 2010 | Cell Phones
Motorola RAZR V3:Can't delete each and every voicemail (new or stored) when directed to press #7. Also can't prevent hearing the date and time for each voicemail. What is the solution?
hearing the date and time for each voice mail is adjusted using your carriers voice mail options. as for deleting each voice mail, it usually requires that you push 7 to save a voice mail and 9 to delete
Sep 07, 2010 | Motorola Mobility RAZR V3i Cellular Phone
New Voice Mail message
You received a message on the voicemail system provided by your telephone company. To hear the message, dial the voicemail number provided by your service provider (in many cases, this will be your own phone number), and follow the voice instructions for listening to your messages. You need to store the voicemail access # by pressing [MENU], [#] [3],[3],[1] on the handset. To access the voicemail, press [TALK], then softkey [VM]. Depending on your service provider, you may need to clear your voice mailbox to remove the notification.
Apr 12, 2010 | Panasonic KX-TGA101S Cordless Handset
Change night message
the night mode message that is being used is the main phone's (phone with lowest Ext. number) night mode message that was customized through it's voice mail.go on the main phone and listen to its voice mail. (voice mail ext. usually 165)continue listening until you hear some options.select the voicemail management optionthen select the change personal greeting optionthen select the after hours greeting optionhope this helps!
Feb 19, 2009 | Toshiba DKT-2010 Corded Phone
Voice Mails won't go away
If you don't want to waste minutes listening to vm:
Just call your cell phone and let it go to voicemail. When the voicemessage comes up click the pound sign. It will ask you to enter your password, then you can listen to and erase voicemail for free.
Jul 16, 2008 | Motorola Mobility TracFone® V170 Cellular...
Voice mail is full do not know how to empty it
Many people confuse voice mail with answering machines. Most of the time if you have voicemail that is provided by your phone company you will hear a stuttered dial tone when you pic up the reciever. If this is what you hear you should call the service provider and they will explain how to retreive your messages and delete the old ones. Are you able to listen to you messages? If you have voice mail, you do not need the answering machine turned on on your phone.
Jan 23, 2008 | Uniden TRU8885-2 Cordless Phone
Lands Phones Logo
406 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
