System will not turn off
I installed the honeywell RTH7500 and it works but my outside and inside units will not turn off....they run continously
  • rick194 May 11, 2010
    What brand is the system?
    Heat pump or straight air?
    Furnace?
  • 142 Answers
Call the honeywell technical service number listed on the instruction sheet for the thermostat.
They can verify if you have the correct stat for your application and the wires are connected to the right terminals.
Posted on Jun 01, 2009
AC unit is running, but the house doesn't get cooler.
a/c is either on or off,there no in between.check air filters make sure they are clean.also keep in mind a/c will only bring temp down about 15 degrees from outdoor temp
Jun 23, 2009 | Honeywell Electronic Programmable...
Installed a honeywell rth7500 series thermostate, no air
Heat/cool wires crossed. RC- is red cool make sure the batteries are good and room temp is higher than cool setting. good luck
May 29, 2009 | Honeywell Electronic Programmable...
System fan does not come on.
if the out door unit has been working carefully jump red to green the fan should come on if not problem is bad fan motor or capicitor or fan relay hope this helps
May 24, 2009 | Heating & Cooling
Heat pump -> installing digital thermostat.
sounds like the thermostat is not energizing the reversing solenoid , unless you have some experience with electrics i recommend that you call a trades person, to check this problem a multi meter is required and requires the user to know how to work with power , please do not attempt it yourself ...
May 10, 2009 | Heating & Cooling
My heat pump won't cool my house. I have a honeywell rth7500 programmable therostat. It is blowing cool air out of the outside unit and the lines are normal temp.
Warm air should be blowing out the outdoor unit. Have a technician evaluate if the compressor is functioning. There are many reasons why the compressor is not working. One of them being a start capacitor not working. Another being out of Freon due to a leak. Good luck
Apr 25, 2009 | Honeywell Electronic Programmable...
Have a near new panasonic cs-e28hkr split system air conditioner and the outside condensor fan continously runs even with inside unit is turned off? Thanks
Sir/madam,
If the inside unit (evaporator) is turned off absolutely.
The condensing unit must be turn off outside because the power
are derived comes from the evaporator.
Possible it seems on the cut out stage inside and remain the power still on
Otherwise theres somebody tamper the connection?
Fan cable consist of 3 wires
1 Common line
2 Start /stop line***Change the connection of this wire where it located, To On/ Off switch of the
evaporator inside unit
3 Ground green line/Earth
note: you can get all that wires inside the power supply in evaporator area.
If still under warranty inform the manufacturer
r_ic7
Nov 29, 2008 | Panasonic Heating & Cooling
Honeywell Thermostat RTH 7500
Assumed all the wiring are correct,
to change from manual switching from heat to cool, press [system] button ( left ) to go into system setting.
then press and hold the [fan] middle button untill option display 120
use up down button to select option 300 ( Manual/Autochangeover) ,
select 0 for manual, 1 for automatic. ( read caution in page 22 of installation manual )
Good luck
Sep 30, 2008 | Heating & Cooling
Compressor shuts down when warm outside
make sure you provide shade for your unit. It may help keeping it cool.
Aug 27, 2008 | Honeywell Electronic Programmable...
Replace Carrier tstatccshp01 builders standard thermostat with Honeywell rth7500 series and wiring not matching Does O wire go to Aux..? fan working but no cool air.
No... Aux. is auxiliary heat strip. This is usually a white or black wire its up to the choice of the installers preferance. O or orange wire. is used to the reversing valve on a heat pump. If you do have a heat pump there is a programing section inside the Honeywell t-stat. which should say heat pump or straight cool, then another section that will ask if you want the reversing valve to energize in heat or cool. most Heat Pump brands energize in cool the exception is Rheem and Ruud they energize in heat.
May 17, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
114 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
