Question about Westinghouse 22" Widescreen LCD Flat Panel Monitor
Has power but a black screen lcd monitor
How can i fix a lcd monitor
  • terrysilvers
    terrysilvers May 17, 2012
    I need your help on a 24" westinghouse email me plz terrysilversjr@gmail.com
  • 748 Answers
I have repair many Westinghouse monitors. You'll need a set of hardened plastic pry bars to remove the bezel. You'll need an ESR meter to test the capacitors in the power supply. You'll need an static isolated soldering iron the replace the capacitors. The capacitors you can get at a local radio shack. I do these repairs daily and they're not as hard as it seems.
Posted on May 30, 2009
  • terrysilvers
  • terrysilvers
    Help me with a 24: westinghouse power but black screen thanks terrysilversjr@gmail.com
Dealing with a Planar PL1700-BK computer monitor. When power is supplied, the "no signal" box flashes, then the screen goes black. When hooked to laptop, screen shows desktop, then goes black.
Planar PL LCD Monitor Fix - MarsBox.com
marsbox.com > Blog > Howtos
Nov 3, 2008 - Planar PL LCD monitor has flashing power led with no image. ... You will know it worked if the monitor diplays "No Signal" message when ...
What is the method to reset the Planar 1910m monitor?
superuser.com/.../what-is-the-method-to-reset-the-planar-1910m-monitor
Apr 6, 2010 - My monitor (a Planar, apparently model number PL1910M) is not working. (It is flashing a green / orange sequence which I believe to be an error code. The sequence, in ... I wasn't even seeing a "no signal" message and I couldn't turn it off using the power button. ... Computer resets when put under load.
ViewSonic VX922 monitor - black screen - green power light flashes ...
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Feb 1, 2008 - 50 posts - ‎27 authors
Repair ViewSonic VX924 LCD Monitor Blinking Green power Button ... cant switch back & forth to desktop out of some games without the monitor going .... Nothing else on the board looks bad, the power supply board is dark brown ... to this madness we are unfortunantly dealing with daily with our monitors.Missing: planar ‎pl1700
Jan 05, 2016 | Planar PL1700 17" Flat Panel LCD Monitor
Monitor says no signal an go's black
clhndr2, The display may have bad internal main ac to dc power supply which goes into "shutdown-mode"!! You or qualified electronics technician will need to investigate/evaluate unit to make decision on fix or trade for new. Do some reading in the fixya profiles of :budmrtn" "buddymc" "12fixlouie" and follow links you find there to understand "lcd black screen" or "lcd blank n black screen" problems and how to fix them. 12fixlouie
Aug 05, 2010 | Gateway 19" Flat Panel LCD Monitor
Hp f1703 lcd monitor has no power at start up, bla...
guest, First thing to do will be to visit this web blog:
http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ Do some reading to see if anything seems familiar to your problem of BLACK screen. If it helps you out a little then come back here and rate this response and tell us what action you will take to fix your unit. 12fixlouie
May 19, 2010 | HP Pavilion F1703 17" LCD Monitor
Samsung lcd le27s7 screening problem
The problem with your lcd monitor is that the picture board of your lcd monitor is faulty that is why it power on for one second goes gray and finally black with only sound.
Since the power led button is on and it still give sound but no display, it means the picture board of your monitor is bad.
All you need to do is to take the lcd monitor to any local repairer or any service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix all alone in other to complicate issue.
Take care
May 02, 2010 | Computers & Internet
Black screen
At this point I believe there are failed caps in your monitor.
http://www.badcaps.net/forum/showthread.php?p=73310
This is very common in all LCD monitors. Did the tech just push the power switch off and on?
From my experience at fixing broken monitors of all brands, I think it is the power supply problem.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
You can get second help from repair shop also.
Apr 20, 2010 | Gateway FPD2275W LCD Monitor
My Dell E176FP 17" LCD monitor keeps cycling colors -red green blue black then colors again... (More) My Dell E176FP 17" LCD monitor keeps cycling colors -red green blue black then colors again during...
well that could be because the screen is going bad. you might want to get another one or take it in to get it fixed, no more than 100 to fix your screen.
Feb 13, 2010 | Dell E176FP 17" LCD Monitor
On power on, screen comes to life for 1/10th sec, then dies. Power supply seems to be from Benq.
i just repaired a HP1955 monitor,the symptom was: when you power up the monitor,it shows on screen a desktop,but after a sec is screen going black..this repeats continously...
i just resoldered the AC cord connector on power board and also the impulse transformator...now the monitor is running good..
sry for my english,im from Slovakia
Dec 22, 2009 | HP L1955 19" LCD Monitor
Viewsonic vg700b lcd monitor screen turned black
there's an internal hardware problem in your lcd monitor - cold soldered / defective electronic part/s. I suggest to bring the unit to an authorized service center for proper diagnosis & fix the problem. best regards
May 21, 2009 | ViewSonic VG700b 17" LCD Monitor
My lcd hp vp15 monitor cannot power on,when i push power swich it then power swich flashing but screen does not anything screen is black.please help me
Its a problem with the monitors power supply ,you will have to take it to an HP support center and ask for a quote.
if it's under warranty then you won't pay to fix it.
May 06, 2009 | HP f2105 21" LCD Monitor
Monitor black screen dark picture when power on then black. power button flashing
I'm having the same problem, my power button just flashes now, and it seems like the screen tries to turn on over and over again.
I'm pretty sure its the backlight for the LCD.
If your very handy, go to inventgeek.com and type in LCD backlight fix.
Dec 16, 2008 | Computers & Internet
Westinghouse 22" Widescreen LCD Flat Panel Monitor Logo
417 people viewed this question
Top Westinghouse Computers & Internet Experts
Matthew Spark
Matthew Spark
Paul Bade
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
