Replaced film, unit say's "Check film, Cover open". Film is fine, cover is closed, can't figure ths out?
  • horsladi May 31, 2009
    Tried it didn't work??? Thanks
    Problem Solver:
  • 4 Answers
I had that problem once and I unplugged it for 5 minutes and then replugged it in and it was fine.
That's what worked for me.
Posted on May 30, 2009
How do you load it
To open back cover lift knob on top of camera ( this knob has a small arm that unfolds - used in rewinding).
Once open you will see which side is the film side ( under this knob) and the take up side. On the film side raise the knob again in order to insert film case, the top of this should flip over later used to rewind film. with film trail out toward back of camera. Now push the knob down. Film should only be loaded one way so the knob can be lowered into film canister. Lower knob and Film canister is now secure.
Next thread film leader onto take up spool. Some times these have a slot , but most Just have the teeth that fit the film edge.thread the film into slot then unto teeth. You will need to use film advance arm (There should be an arm on the top opposite side of film knob) you would move that would advance film.
as you move this arm ( with cover open ) film holes should engage the teeth on bottom and top. ( if you can't advance after 1 or 2 advance arm swings) press take picture button ( releases springs).
continue until film is captured top and bottom. Use the film spool knob gently wind film back into canniester until snug don't over wind. Close cover, take a picture with lens cap on, repeat that. As you wind ,the film cartridge knob should rotate.
You are not wasting pictures film was designed for this waste.
you should know how many photos were on film 12/24/36 pictures.
you may have a knob to set to that number.
When your ready to remove film ,push silver button on bottom and use winder handle ,rotating until free and easy. Open cover mention earlier.
wow can't believe I remembered all that and hope that helps.
Sep 23, 2016 | Photography
I have a 660 sharp fax . when I 2turn it on its display shows. check cover,check film, check paper. how can I solve it ?
Replace the film, replace the paper(properly installed)and check all covers re-seat them, also check to make sure that the tab that goes into the machine for each cover is not broke if one is then copier thinks that cover is not closed. buy new film.
Mar 12, 2015 | Sharp Office Equipment & Supplies
The flash sometimes doesn't work and prints out white film
Hi, once you insert the new pack of film, first shot is without flash as it's eject the film cover which is a useless film cover that cover the film protect the film being exposed. after first shot, camera will have flash. but do not open the film cover again. if you open and take out the film it will expose to light and film turn out to be white.
http://www.passiongadgets.com/
Apr 13, 2014 | FUJIFILM Instax 210 Film Camera
My canon lide 700f will not calibrate to scan a 35mm film
For those having the "Executes calibration. Pull out the film and place the Film Adapter Unit at Frame 1." issue and cannot calibrate the scanner for NEGATIVE FILM, it took me ages to figure out how to solve it.
Solution: calibrate the frame, WITHOUT any film, adapter plug and placed in frame 1, and proceed to do the calibration WITH THE SCANNER COVER OPEN.
Before I tried everyhing, install new drivers for Windows 8.1, MP Navigator, and nothing happen. Now it works like the first day. Hope it helps! it certainly helped me.
Jan 29, 2013 | Canon CanoScan LiDE 700F
Check Film and Cover Open: KX-FPC95
Check for slack in film between supply and take-up rollers. Manually advance take-up roller to remove slack before closing cover.
Dec 18, 2009 | Panasonic KX-FPC95 Plain Paper Thermal...
I just rebuilt my Canon PC850 toner cartridge and when closing the unit after installing the cartridge it would not latch like usual. I tried several times and finally got it to latch properly. Once...
Exists much reasons the film could be damaged.Most often of them - is mechanical damage.This can be use fine or thick paper, which rumpled in termo unit. To Install the new film you must required the special knowlege of the service. Do Not advise you to proceed this work without preparing. Good luck
Oct 31, 2009 | Canon Office Equipment & Supplies
Have replaced film and unit keeps saying "cover open" or check film. I replaced film correctly twenty times.
On some units it is possible to install the film upside down( backwards) but since you've done it multiple times it is more likely that the sensor that sees the film is broken or blocked. Look for a small block with two little lenses. They don't usually break per se but can get blocked by debris like scraps of paper.
Good luck
Jul 27, 2009 | Panasonic KX-FPG378 Fax
Opening the cover
This model print on Thermal transfer technology: there is a black film inside the fax.
Open the cover from the rght side with the green or grey button.
You can then see the black film.
Usually, the top part is the new, the lower is th used.
To know if the film is near empty, you can remove the film from its place and see which side is bigger.
Good Luck.
Mar 13, 2009 | Panasonic KX-FP101 Plain Paper Thermal Fax
Disney princess camera
trentshoffne,
bottom of camera open battery cover with a pen point, insert one AA battery close cover.
film door is opened with pen point left side of film door. load film & bring film leader to take up spool, close film door. rotate advance to # 1 counter on bottom.
turn camera on with sliding switch on front of camera, this opens lens cover and turns on flash .( if wanted ) second click.
at end of film roll pull rewind lever up and rotate clock-wise to rewind film.
open film door and remove film.
remember to turn camera off when not using.
Aug 05, 2008 | Photography
154 people viewed this question
jasbo
jasbo
