Question about Garden
Engine Dies and will not start when PTO is off, brake depressed.
I have a John Deere STX38 lawn tractor, and yesterday when I was mowing my lawn my tractor just quit running. A few minutes lator it started up again and I started mowing again, then it did it again. Only this time I couldnt get it started. Can you tell me what is wrong?
    Scholar:
  • 47 Answers
Let me guess, as soon as it sets still for a few hours, it fires straight up again, like there was no problem? :D
If you have one with the Kohler 12.5 Command Pro Engine:
These have a known issue with the ignition pickup/coil assembly. If you feel confident in your skills, removing the upper engine shroud will reveal the coil pack. Loosen the bolts and adjust it's width from the flywheel using a business card as a feeler gauge to set the gap. The card should just *slightly* bind between pickup and flywheel. If it STILL stalls and stumbles and eventually quits AFTER it is hot as you describe, likely the coil pack is tired and worn. Heat will make them short out internally as internal windings expand from heat. Replacement is the only cure. About $40 from Kohler, about $60 from John Deere.
Posted on May 09, 2010
  • 3,600 Answers
Try this guys web site he can help you http://www.jimsrepairjimstractors.com/allequipment.htm
I don't know if it's a diesel or gas rig and if it has electronic ingtion or not so this guy has the parts and know how.
Posted on May 30, 2009
Where is the neutral safety switch on a John Deere STX38 lawn tractor?
there isn't one...check your brake switch and your PTO engagement switch
Oct 29, 2014 | Garden
John deere 325
could be a couple of things... fuse? switches? bad clutch?
Sep 07, 2014 | John Deere Pto Clutch For Stx38 And Stx46...
John deere troubleshooting
I have model 917-276900 tractor starts fine but when I engage the mower deck it blows the fuse and dies.
Aug 31, 2014 | John Deere Pto Clutch For Stx38 And Stx46...
I have a john deere stx38 and it has no spark and wont fire but engine turns over
Check the shear pin in the flywheel, replace if bad, should cure your no spark problem
May 28, 2011 | John Deere Pto Clutch For Stx38 And Stx46...
Electric pto will not engage the mowing deck. stopped working while mowing.
had a similar problem. The engine mount bolt that grounded the PTO black ground wire was loose- causing the pto to work erratically. To see this bolt (13mm i think) you will have to lie on your back and look under the machine. It is above the front steering arm of the right tire. If the wire is dangling you will need a new bolt. Thanks for the previous posts ;)
Aug 01, 2010 | John Deere Pto Clutch For Stx38 And Stx46...
I have a john deere stx38, has no spark. Engine turns over fine but will not fire. JW
Check the HT lead for cuts or breaks and then replace it anyway then check the on/of switch for rest
Jul 09, 2010 | John Deere Pto Clutch For Stx38 And Stx46...
Garden Logo
495 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
