Video Cameras Logo
Bruno Laval Posted on Jan 18, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can canon ZR700 NTSC camcorder play Tapes recorded in PAL from another camera?
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Canon Master 102,366 Answers
  • Posted on Jan 18, 2014
Canon Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10441268
Points
622693
4 Related Answers
Anonymous
  • 473 Answers
  • Posted on Sep 06, 2005
SOURCE: NTSC AND PAL TROUBLES
What I use. My best tool is an Artec DVD+R/W recorder. I can use the resulting DVD on the PC for editing or such. For digitising on the PC, my best tool is the 49USD Hauppauge TV PCI card. As to your sound issue, if it's the same USB device I used a few years ago, it tortured me to get the latest video driver, sound card driver and directx before it would work. I also connected the audio to the line-in.
Anonymous
  • 169 Answers
  • Posted on Aug 11, 2007
SOURCE: Camcorder won't playback most Hi8 tapes
may be your camera not design to play the analog tape...there are some model that can playback a analog tape...i think your camera is for digital playback only.... check your user manual
Anonymous
  • 73 Answers
  • Posted on Mar 02, 2008
SOURCE: Canon video camer ZR700
THIS SOUNDS LIKE MAYBE A DIRTY HEAD.. OR A LOOSE CONNECTION BETWEEN THE LCD AND DAUGHTER BOARD.. MOST LIKELY A DIRTY HEAD, TRY A CLEANING CASSETTE
Anonymous
  • 259 Answers
  • Posted on Mar 23, 2009
SOURCE: My cam has a small yellow triangle flasing in the LCD.
the two formats are not compatible i will look up and see if i can find what tapes you should be using
Honestech tvr video recorder
The Color subcarrier is different on pal. NTSC tapes , cameras, VCR's will all show B/W on a NTSC TV.
Canon zr700 won't play tape
That is the pinch roller. If it does not press the tape against the capstan, then the tape will not pass the read/write heads. Replace it.
4helpful
Can I use Hi8/Digital8 NTSC tapes in my DCR_TRV250E?If so would I be able to playback recorded tapes on the UK televisions?.
DCR-TRV250E is a PAL version camera of the Digital8 format.
Yes you can use Hi8/Digital8 NTSC tapes. The camera will record a PAL digital picture on the tapes which means that you can play back the tapes in PAL and therefore you will be able to playback recorded tapes on UK televisions because they are also of the PAL format.
Sony Hi-8 plays new recorded video buy not playback
Are they PAL or NTSC tapes ? They may not be compatible with your new equipment.
When I try to play PAL tapes, there is no picture
You also need a PAL television or monitor to be able to view them. If you don't have a PAL compatible monitor or TV it will not work because the resolution and scanning is very different than an NTSC monitor. Your canon camera is probably designed only for NTSC use if it was sold in North America and can't be used for PAL use.
Pal to NTSC
try NERO software...you will be able to go back and forth (pal or ntsc)...this might be a project / but you can also make into a very fun thing....(note also the DVD regions)
Convert NTSC VHS video tapes to DVD PAL
If you do not have an adaptor to play the tapes to a standard VHS viseo player, you can use the camera as the player by connecting the AV out to a DVD recorder. There are hundreds of models in the market, and do not worry if it is NTSC or PAL because 99% of DVD recorder accepts both.
1helpful
Not reading Hi8 tapes
Fidus, I am not sure where you are located but the camcorder you're trying to use now is a PAL version of Sony's 8mm camcorder. If the tapes you recorded earlier were recorded in D8 (digital 8) or 8mm/Hi8 format NTSC, they will not play correctly in this unit. The NTSC and PAL formats are different and not compatible. Hope this helps you. Joe Weibel customelectronics.org
Pal on SC-L700
This model will play only NTSC. NTSC is the television broadcast system used in the USA (and a few other countries) Tapes of any format than NTSC will not play properly in this camcorder.
Top Canon Video Cameras Experts
NOEL
NOEL
john h
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
