Question about Epson PictureMate Photo Printer
Printer is not printing clearly even with brand new cartridge
I have an Epson PictureMate Personal Photolab PM260. All of a sudden the pictures came out with too much red and faded out the more I tried to print. I replaced the cartridge with a new one and it did the same thing. What do you recommend I do to repair the problem? Thank you, Gena Gilbert, BROKER/OWNER/REALTOR
My PM 260 has been acting up by only printing only about 1" of the paper and then it will stop feeding the paper. It will eject the paper only if I exit from the computer or turn off the power on the printer and then turn it back to on. I already updated the driver (13488). Should I have it looked at by an Epson certified repair or just buy another one?
Posted on Jul 26, 2010
How to clean printhead pm260?
Note: If you see a Print Pack low message on the photo viewer, you may not be able to clean the print head until you replace the Print Pack.
  1. Load paper in PictureMate so you can print a nozzle check pattern after cleaning the print head.
  2. Press Menu.
  3. Press the arrow buttons to select Maintenance and press OK.
  4. Press the arrow buttons to select Auto Cleaning and press OK.
  5. Press OK again to clean the print head. Cleaning takes about 60 seconds. PictureMate makes some noise and you see an Auto Cleaning message.
    When cleaning is complete, PictureMate prints a nozzle check pattern.
  6. Check the pattern to see if there are any gaps in the lines.
  7. Do one of the following:
    • If there are no gaps, Press OK.
    • If there are gaps, Press the Back button.
  8. Follow the instructions on the screen to clean the print head, check the nozzles, and repeat the process as necessary.
If you don't see any improvement after cleaning the print head up to 4 times, turn off the product and wait at least 6 hours. Then try cleaning the print head again. If quality still does not improve, one of the ink cartridges may be old or damaged and needs to be replaced.
Sep 09, 2014 | Epson PictureMate Snap - PM 240 InkJet...
My picturemate photolab is printing pictures that are green. How do I elliminate that.
Greetings,
Go to Maintenance and do the Head Cleaning.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jul 03, 2008 | Epson PictureMate (C11C556001) InkJet...
I have an Epson PM260 and it prints but with lines. I have done an auto clean at least 10-12 times and still getting lines. I have a brand new ink cartridge as well and it already says it's low? How do...
Update the printer drivers by downloading them and installing here:http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=90903&infoType=DownloadsDo an auto clean after that. Also look for "cartridge alignment" if available.If that doesn't work, check that the cartridge is installed properly.Otherwise, return to the manufacturer.Please leave a good rating!
Jul 29, 2011 | Epson PictureMate Photo Printer
Can you Help me unclog my nozzle? Epson Picturemate PM240. Head cleaning 3x not successful: no blue ink at all. Print cartridge is brand new and showing 100% full. It tells me to replace the print...
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
May 18, 2011 | Epson PictureMate (C11C556001) InkJet...
All my picture from my Epson Picturemate personal photo printer are coming out pink. I have brought a new cartridge and it is still coming out pink. Why??
Hi!
You need to run a Head Cleaning cycle so printer can get rid of the old ink from your previous cartridge. Try running it from maintenance for at least twice or try printing pictures in between cleaning cycles.
Hope this helps.
May 05, 2011 | Epson PictureMate (C11C556001) InkJet...
Ink is not dry on the picturs
the paper isnt indicated, for that kind of printing. find a proper papel for that printer.
Nov 22, 2009 | Epson PictureMate Photo Printer
My pictures are coming out rosey color looking instead of bright, I've cleaned the heads, and changed the cartridge and still don't get good pictures, help, sorry, I have a epson picture mate personal...
try to set the resolution of your epson, to picture quality or something like that.also you have to identify if the picture you are printing is same or big as the papar you are using, its possible that is in the picture it self.hope it help, :)
Oct 04, 2009 | Epson PictureMate Photo Printer
Even with a new cartridge it says empty cartridge and won't print
are you using a generic ink cartridge? and just for added information, picturemate cartridges or so some epson inks do have expiration dates, pls check because if you have them stored for quite sometime the tendency is that the inks will harden up. then it will not distribute ink to your nozzle.
another thing troubleshooting steps, have you tried to perform a cleaning cycle? try to do it for about 4 or 5 times. then try to print. pls be advised that it will take in a certain amount of inks to clear the cloggs and force it out.
or before installation of the cartridge, did you shake them? for about 5 times then insert it back
Sep 27, 2009 | Epson PictureMate 500 InkJet Photo Printer
My pictureMate 500 prints green only
Hi
Try running a head cleaning cycle from the maintenance menu, then print a nozzle check. try to run 3 head cleaning cycles then try printing again
. If all fails call epson for replacement.
Hope this helps
Nov 15, 2008 | Epson PictureMate 500 InkJet Photo Printer
Epson PictureMate Photo Printer Logo
286 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
