Question about Whirlpool Washing Machines
Tub drains very slowly can hear water trickling down the drain
Drains very slowly
  • jwjlwhite May 30, 2009
    Found pair of underwear blocking intake tube.LOL Thanks,Jeff
Check to make sure there is any thing in drain
Posted on May 30, 2009
  • traci1avon Jun 01, 2009
    that is cool!! i changed my belt on my washer!! so proud of myself!!
Sewage backing up into laundry room when we use our dishwasher. We have a septic tank. Both toilets flush fine, and no back up in tub
The drain leaving the laundry room going to the main needs to be cleaned. The first thing you can try is what is called a product called Drain King . This is connected to a garden hose and inserted into a drain where the p-trap is removed from the wall When the garden hose is turned on full blast it will try pushing out the clog You should hear it pulsate first slowly then more quickly as the clog is washed away.he water flowing with Finally you should hear water flowing freely. it helps to use warm water if possible. If that won't work the drain will need to be snaked , Turn off the hose and remove the Drain King by loosening the hose connection Then follow that pipe downhill toward the main drain, and look for a clean-out plug. You can loosen the plug SLOWLY, have a bucket, mop, and rags ready and wear old clothes. Place the bucket under the clean-out plug if possible while slowly removing it Water will come out unless the clog is between the laundry sink and the clean-out. If water comes out when the clean-out plug is removed place your snake drain cleaning device into the clean-out and run until the clog is cleared. then run water through it for a while to wash away any residual residue. Put everything back together and test for leaks.
Jul 30, 2014 | Home
Whirlpool Duet washer shuts off when tub fills with water
First, does your unit attempt to clear the water from the drum at all? That is, do you HEAR the drain motor engage and attempt to pull water out of the drum? I had to do a little more than clear the drain filter to fix mine. The drain filter was clear, but my Duet still wouldn't clear the water from the drum. When I pulled off the drain filter cap, I got a trickle (not a GUSH as you normally would) of water, indicating that the problem was further up in the line. However, first confirm there's nothing obstructing the exterior line clear thru to the drain filter. And I have to ask, does ANYTHING drain from the tub-- that is, is NOTHING coming out (in which case it is probably your drain motor), or is it just coming out slowly (indicating an obstruction prior to the motor)? Slowly means you should backtrack from the drain filter to the tub basin. On my unit, there is a black rubber hose that comes off the drain filter and leads to the tub collection basin. This hose attaches with a hose clamp that is easily removed with a set of pliers (in all honesty, in fact, it is considerably more difficult to put it back ON). When you remove it, you'll notice a float at the beginning of the black rubber hose. Clean out around it. Then, (and probably a more likely cause of an obstruction) reach your hand up into the tub basin and feel around. Mine yielded about 5 cups (no kidding) worth of yuck that was causing my drain issue that, when removed, completely solved the problem.
Mar 03, 2013 | Whirlpool Clothes Washer Rotor Position...
Whirlpool neptune mah3000 wont drain , I can hear it and see small trickle of water. My wife thinks she lost a small nylon stocking. Eventually I get nd code. Even when I lay the hose down I only get a...
You are going to have to open up the machine and check you drain pump. If there is something blocking the intake of the drain pump it should be easy to get out, but if it has shredded in the pump, replace the pump.
Jul 17, 2011 | Washing Machines
Water will not drain out
Check the drain filter located at the bottom of the wash tub. Clean if clogged. The pump noise could be due to non availability of the washed water continuously due to clog.
Clean the drain filter. Check the final drain output after the pump(hose) for free flow if you have connected it to a drain system.
Aug 03, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
The water will not drain from the tub. it will go
if it drained before...then you might have problem with drain pump something stuck..piston nut
try slowly advancing timer...if it drains in different cycle you timer is gone bad
if not then piston nut or drain pump
Nov 10, 2009 | GE Nautilus 24" Built-in Dishwasher
He2 front loading washing machine leak at the soap dispenser regi
If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here’s the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
1. Unplug the washer while servicing inside the unit.
2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
9. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 27, 2009 | Kenmore HE2 Plus Front Load Washer
Dishwasher will not run after filled with water
The float switch in the tank is bad,also if water only trickles in your fill valve is going bad which will not let it fill all the way to start wash cycle. Fill tub with pot of water to raise float, if wash cycle starts,replace fill valve,if not,replace float switch.
Jan 21, 2009 | Dishwashers
Automatic Trickle Questions
o you multitask while you wait for the shower to get hot? Brush your teeth? Make the bed? Maybe even pick out your clothes or iron a collar? Many of us do—and don’t know that while we’re feeding the dog or grabbing that second cup of coffee, two-and-a-half gallons of hot water per minute are funneling down the drain. The automatic trickle reduces the flow of the water as soon as it reaches a comfortable 95 degrees. This way your hot water is no longer running down the drain while you’re away from the shower. The automatic trickle allows your showerhead to warm your shower without wasting hot water and tell you (hear) the when your shower is ready. Evolve is the leading manufacturer of this kind of products.
Aug 27, 2008 | Baldwin Hardware 3755 Estate Collection...
Washer Is Dribbling Water Into Tub
you have a bad inlet waer valve stuck in open position, youll need to replace the valve. easy enough to do, its the valve your hoses are screwed into, in the mean time until repair is made, you can simply turn offf water supply between loads ( not a bad thing to do anyway)
Apr 27, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
