Question about Kenmore Ovens
Kenmore oven doesn't light, replaced igniter and may have created a 2nd problem
Kenmore oven Model number 3627391594 doesn't light, replaced ignitor and tested ok when touching leads to oven wire, then shorted (flash of light) when separating for final installation. 2nd new igniter doesn't work at all. Is there a fuse that may need replacing or could this new problem be something else?
  • darnellhl May 30, 2009
    Thank you very much for your reply. I will do just that. Is this a specialty part, or can I simply purchase one from Sears?
  • 11,896 Answers
If you follow the igniter wire harness, you will see a little relay in there that will probably need to be replaced.
Posted on May 30, 2009
Kenmore gas oven 790.7862 will not light but broiler does, igniter works does not seem to get any gas
HI,
Just because the ignitors glow doesn't mean the work. With that being said, the ignitors sold job is to ignite the gas and open the safety valve to release gas. I the ignitors are weak (common) they will not allow the gas to be released. So without a amperage meter, you will be unable to see this. With one you can detect a weak ignitor with reading of (2.8 or lower), to function properly you need readings of (3.2 - 3.6).
When the ignitor is questionable, replace them, most units have two.
Good Luck
Sep 10, 2011 | Kenmore Ovens
Kenmore gas oven will not light.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 26, 2011 | Kenmore Ovens
On a Kenmore gas oven the flame goes on and off and doesn't keep a constant temperature.
heatman101
Jul 19, 2011 | Kenmore Ovens
Kenmore gas oven model 36275578690 oven wont light
heatman101
Apr 20, 2011 | Kenmore Ovens
My sears kenmore gas oven isn't working. Maybe the pilot light is out? I can't find where to relight.
heatman101
Nov 04, 2010 | Kenmore Ovens
My Kenmore gas oven does not light.
Remove the oven Racks. Remove the oven base plate. Turn the oven on. You can then see the oven ignitor next to the oven burner. If the oven ignitor does not glow a bright orange,replace it. About a $90 part.
Oct 05, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Broiler light, oven wont
You are probably right though often the ignitor will glow, but just not hot enough for the valve to open. I would definitely try replacing the ignitor first, it is much cheaper than the gas valve and those valves rarely go bad. It is possible that the thermostat is not sending 120V to the valve, and thus the ignitor but less likely.
Jul 21, 2009 | Kenmore 30172 / 30174 / 30179 Gas Single...
Kenmore Oven
The igniter may need to be replaced again. The only way to know is to test it to see if it has enough amperage to light the gas. If it glows, but no lighting of the gas, get it tested.
Mar 21, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Kenmore 75358 -oven not lighting
heatman101
Feb 26, 2007 | Kenmore 30464 / 30465 / 30469 Gas Single...
Ovens Logo
176 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
