-   Our printer is saying ink absorber is full. The orange light on the printer is blinking. I have tried to troubleshoot using help but didn't offer a solution.
Can anyone help us? -   Guest
Jun 25, 2008
-   my printer is teling me the ink absorver is full-   dantonio16
Apr 03, 2008
-   full ink-   Guest
Apr 01, 2008
-   canon iP1500 ink waste tank full how to remove and clean-   Guest
Dec 26, 2007
-   My Canon PIXMA ip1500 also states "Ink absorber is full" I've the checked manual but can not find any mention of it.
I disagree with the advice at printerhelp.me.uk. It is not simple to clean out the ink absorber, but it is certainly possible. First, disassemble the printer,
then remove and squeeze out the pads of the approx 60 ml (1/4 cup) of condensed ink therein, then rinse them out with water and allow them to dry. Later, reassemble printer and perform a reset as per other articles on this site and others, or use downloadable resetting tool.
As others have pointed out, Canon and other companies are doing a service to us through the error message. If we don't clean the pads, eventually the ink would overflow and leak onto our desks. However, that would probably require 150% of the actual time or ink flow that they have used to activate the alarm.
Comments:
Nov 18, 2007
- Here are some pics to help get the springs back in place. The shorter spring goes with the thin, long piece of plastic (shown from behind):
and the longer spring goes under the inkpad assembly as shown:
this is with the pad assembly sitting on end, which makes handling the spring easier.
Thanks a lot. It took me quite some time to get this done. The re assembly was the hardest part. Luckily i had two IP 1500 so I dis assemble the working one so i could see how to put it back together. Make sure you pay special attention to the parts that sits on the waste ink absorber. This was the hardest part to put back together. the pictures willnotgivup posted was of great help.
dear sir i brought a canon pixma ip 1500 from uae but while coming here in kerala i noticed that the...
(More)(More)
dear sir i brought a canon pixma ip 1500 from uae but while coming here in kerala i noticed that the ink is spread all over the printer,please suggest a way where i can show this and treat this my mail id is mlvnjoseph@yhoo.com 9562972910
Posted. Thank You!
Congrats on your 3 solution. You're helping others! Someone may even thank you with a Testimonial.
is this free support? I have a new Toshiba laptop and trying toconnect my Canon Pixma iP1500 printer...
(More)(More)
is this free support? I have a new Toshiba laptop and trying toconnect my Canon Pixma iP1500 printer to it. When I go to add printer it only shows iP 1300 and 1700 not 1500.
Posted. Thank You!
My computer crashed and it is fixed now but my printer will not work and it did before my computer...
(More)(More)
My computer crashed and it is fixed now but my printer will not work and it did before my computer crashed. I tried to re-install the driver for it but that didn't help. My computer does not recognize the printer now. I do not have the cd that came with the printer any more as I have had it for a couple years and don't know what has happened to it. Any help from you would be greatly appreciated.
Posted. Thank You!
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
