Question about Epson Livingstation LS57P2 57" Rear Projection HDTV
Can't turn on television two red lights on television
Just changed the lamp on our Epson Livingstation television and now the T.V does not turn on. two red flashing lights appear on the television
  • 4,234 Answers
Make sure that all of the access doors are properly closed. There are interlocks there that will prevent the set from working if the door is open. Also, check to be sure that the fans turn freely and are clear of debris.
Please keep us updated on progress.
Thanks,
Dan
Posted on May 30, 2009
Can not assemble epson lamp in compartment
On the front right where it says LIVINGSTATION, that panel lifts out. Inside you will see two screws, loosen them, (they will not come out because of a retainer) gently pull the box out. Once it is out, there is a wire retainer that has to be removed. Once that is removed, then loosen the nuts from the bulb. Then reassemble. Putting it back in, takes patience, do be in a hurry when putting it back in. It will only go in one way, make sure the bulb is facing the inside when sliding it back in. Hope this helps you..I haven't yet replaced the whole unit from epson ($300) only the bulb, which didn't need it after all. If you have any questions e mail me..
Nov 16, 2012 | Epson Livingstation LS57P2 57" Rear...
Have replaced my lamp myself. TV work fine. "Replace lamp" warning still appear when tv is turned on and yellow light still flashing.
You need to reset the "Lamp Hours" in your settings. It is a timer that just runs down, and doesn't know if you changed the bulb. It just needs to be reset to 0.
Apr 19, 2011 | Epson Livingstation LS57P2 57" Rear...
Does anyone know what the resistance across the Epson lamp is approximately, when I measure my new lamp it is showing infinite resistance (basically an open circuit) and the TV is still flashing red lamp...
the resistance is irrelavant.(cuz it is infinite) if this is a dlp bulb?
they can be crossrefrenced and alot are interchangeable the numbers and wattage on the bulb itself is what you need most common bulbs i can get for 100$-150$ plus shipping,with a guarantee. e-mail the #s and wattage @ ohmega1080@yahoo.com
Jun 21, 2009 | Epson Livingstation LS57P2 57" Rear...
Temperature Error Epson LCD
It probably needs cleaning. They build up dust after a while...
Jun 06, 2009 | Epson Livingstation LS57P2 57" Rear...
Red blotches on screen
Serce this questin using the term "pink bloches" I explained it there.
Oct 10, 2008 | Epson Livingstation LS57P2 57" Rear...
47"Epson Rear Projrction TV
turn power off.
let rest for 30 mins.
take off right front panel.
open door to lamp.
unscrew lamp.
pull out and replace.
might want to unplug set also while working on it.
Aug 01, 2008 | Epson Livingstation LS57P2 57" Rear...
Epson Livingstation LS47P1 won't turn on
Hey,
Very similar problem with my LS47P1. Here is the scoop (I work for a retailer which carried these and I bought one)
- Epson has admitted that there is a flaw in the engineering of many newer bulbs (that is ones that were made after the initial release of the LS47P1)
- Apparently the 3 little metal contacts on the lamp tend to get "squashed" down over time once the lamp has been installed (this takes a little while, like 2 weeks to a month after the replacement lamp is installed).
- The contacts no longer make a connection with the inside TV side contacts and the electrical charge needed to ignite the gases in the lamp does not get through (like 9 out of 10 times)
- You can get it to work temporarily by pulling out the lamp and carefully pulling the inside contacts upward to make a better connection inside. NOTE: I did this for a while everytime it didn't work and after a while the pieces of metal became worn and would break off. So do this only if you have an extra lamp handy or you're on your last witts (as I was).
HERE'S WHAT TO DO:
1. Call Epson of America (I am in Canada, but they are the ones to talk to anyway)
2. Tell the first person who answers the phone to transfer you to the Livingstation (rear projection) department. If they start telling you that it will take like 48 hours and they will call you back tell them "NO! put me throught now!"
3. Tell the real tech expert your issue.
4. Get him to send you out a non-defective lamp (these ones have been retrofitted to not get "squashed" in the TV.
5. Put new lamp in and cross your fingers....
Hope this helps.
Mark
Jan 25, 2008 | Epson Livingstation LS57P2 57" Rear...
Epson Livingstation LS57P2 TV Power Won't Come On
tryin unplugging t.v for an hour then plug it back in it worked for me i have the same t.v just the 47 inch
Jan 30, 2007 | Epson Livingstation LS57P2 57" Rear...
Epson Livingstation LS57P2 57" Rear Projection HDTV Logo
310 people viewed this question
Top Epson Televison & Video Experts
janman
Terry Dovre
Terry Dovre
Are you an Epson Televison and Video Expert? Answer questions, earn points and help others
