Question about Kenwood DV-605 Multi-disc DVD Player
DVD tray makes noise when it rotates
I have a Kenwood DVD player with a tray that holds 5 DVDs or CDs. The tray opens and closes fine. The DVDs and CDs play. But the tray started making a loud vibrating noise every time it rotates. How can I fix this? Is there a DVD stuck somewhere?
  • 4,234 Answers
This noise can be casued by two things:
1) The tray is not completely in the loaded position and the "clamper" is rubbing. Replace the loading belt and the loading sequence will complete and the noise should stop.
2) The "CD table" that is part of the spindle motor assembly has slipped a bit. This will make the CD/DVD ride too low and strike the lower tray support. This will require that the table be "re-aligned" to the proper height which may not be possible on your model without special measurement equipment. The height is critical to proper operation of the unit.
Try replacing the load belt first and report your results.
Thanks,
Dan
Posted on May 30, 2009
My DVD tray on my Yamaha DV C6480 (it holds 5 DVDs) got stuck in the half open half closed position. It may have come off the track. I opened the case and reinstalled the DVD Tray. Now the tray...
This happens to us all the time. Here is the note I keep on how to fix it quickly:
When tray gets messed up, the drive wheel (with pegs that interlock with pegs on the tray) needs to be such that the tray slides in and out freely. Push tray all the way in. Turn on.
Hope that gives a hint.
Nov 04, 2010 | Yamaha DV-C6480 Multi-disc DVD Player
Have panasonic dmr-ez485v error message -NO READ- changed disks used prerecorded movie same as my recorded disks, hit reset - still no change
I just saw the date on this message and realize that it was awhile ago. I assume that you have dealt with it by now... So for others who are trying to fix their DVD player:
I have a DMR-EZ485V DVD player and just started getting the error message "No Read." I couldn't find an answer on the internet and finally called Panasonic's customer service, (there is no charge 1.800.211.7262). Since it says "No Read" to everything--store-bought DVDs, burned DVDs, CDs; AND when there is nothing in there (it acts like it is trying to read when the tray is empty), the customer service rep thinks that I am having a lens issue. It either needs to be cleaned (can pick-up a product at Best Buy or Radio Shack) or, if that doesn't work, the lens needs to be replaced.
Aug 09, 2010 | Panasonic DMR-EZ485VK DVD Recorder/VCR
How do I unlock my Pioneer DV-310-s so it will accept all dvds, thanks.
Here is how to Make your Pioneer DV-310 regionfree.
Use this link and go there.
http://www.pioneerfaq.info/index.php?question=Firmwares
Search for file YJA8703A almost in the bottom under DV-310.
Download and burn on CD with nero,make sure the CD is being closed after burning.
The just mount the CD in your DVD player and press play.
#1. Press upgrade.
#2. Wait,don´t touch anything now.
#3. The tray will open after about 5-10 sec,take out CD.
#4. Player will uppgrade under about 1-2 minut,then the tray will close by it self,and the player says "CLEAR".
#5. And now here is the secret. When player says "CLEAR" ,push and HOLD the "enter button on THE PLAYER until it turns off(about 5 sec).
And there you go,standing infront of your brand new Multi regional Pioneer DV-310.
At least this worked great for me.
Good Luck!
/Jiinsen
Aug 08, 2009 | Pioneer DV-310 DVD Player
REGION 2 DVDS ON REGION 1 PLAYER
1) Turn on the player with no disc in the tray
Wait till the unit is at the Samsung logo screen.
2) Open then close the tray, wait to see the No-Disc Message in the top Left Corner
3) Now press the REPEAT button on the remote, followed by a five digit code.
In this case Repeat 29334
4) When it works a 1 will appear in the top left corner
5) Press 9 to make it regionless.
6) Press Eject to OPEN to open the disc tray.
7) Press Eject to CLOSE to close the disc tray.
8) Power the unit off
9) Now power the unit on again, it should now read all regions of DVD Disc.
Enjoy
Jul 18, 2009 | Samsung DVD-1080P9 DVD Player
Jamo, DMR 61 keeps rejecting DVD and CD; player not reading disks
The dvd mech assy is defective and needs to be replaced.
Mar 30, 2009 | Jamo DMR 60 DVD Player/Receiver
Other Region codes for Samsung DVD 1080PK
Region code hack posted by anindo_roy, January 09 2009:
I bought a Samsung DVD player 1080PK in Bangalore recently (Jan 2009) and initially it was coded only for region 5 (India). I went through the following steps (which were told to me by a Samsung technician) to make it region free. This steps match closely to the one posed by another viewer so I have retained the same format.
2) Press the Open/Close button to open the tray
3) Press the info button, the firmware version shows up
4) After the version info disappears, close the tray again by pressing the Open/Close button
5) At this point, it will show "no disc" at the top. Press the Info button again, and this will disappear.
6) Locate the Repeat A-B button on the remote, which in my case was ‘9’
6) Now type the code that applies for your region (R5 (India) is 53814) followed by 9 (Repeat A-B button) and then press the Enter button. So enter 538149 and then Enter. A last few digits ‘4’ and '9' may briefly show up at the top left corner.
8) Power off the player, and turn it on again. You'll have a multi region player
Region Code for the 1080PK hack:
R1 - 29334
R2 - 57538
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
This worked for me after a couple of tries.
Dec 21, 2008 | Televison & Video
DVD stopped playing all DVDs
Reset you player by doing the following:
With the player on, hooked properly to your television, and on the correct station:
Open the tray
Close the tray (with no DVD inserted)
Hold the stop button down for a full 5 seconds
The CyberHome screen should appear. You should be able to play your dvd's now.
Feb 20, 2008 | Cyberhome CH-DVD 300 DVD Player
Error message when reading DVD
Try changing the region setting to region free.
1. Make sure there is no Disc in the tray.
2. Shut off the unit and unplug it from the AC outlet.
3. Press and Hold the "Play" and "Open/Close" keys,
simultaneously on the player and not the remote control.
4. While holding these keys, plug the AC cord back into the outlet. (TEST and CPU ver# will appear on the display)
5. Release the "Play" and "Open/Close" keys.
6. Press DVD Menu twice on the remote.
7. When the display reads s000 5858 use the up and down buttons to change the 000 to 02E.
8. Using the Left and Right arrow buttons, change the last four digits until they read 0000 for Region Free, 0101 for Region 1, 0202 for Region 2 or 0404 for Region 4.
9. Press Enter on the player.
10. Press Standby and wait 5 seconds.
11. Press Standby again. Your player is now set to the region you requested. If you find some titles do not play on the region 0 setting, you may have to hard select the appropriate region.
Good Luck. Let me know if it works
Jan 09, 2008 | JVC XV-S300 DVD Player
Sony DVP-NC600 Powers down during CD playback
The tray won't open. I took top off and dvd top side holder, but the laser mechanism won't disengage so the tray will open, even with no dvd in it. How do
I reset it. I power on, hit open key, it makes hum noise then goes by to
standby mode.
Jan 06, 2008 | Sony DVP-NC600 Multi-disc DVD Player
Tempremental playing dvds
In response to your jvc-a75r DVD player, sometimes the solution might be less complex than it may appear. Had the same problem with my Samsung s321,the machine refused to read DVD's but would play CD's no problem. Simply opened up the cover(usually)4-6 small screws, and found my dog's hair inside of the player covering the laser eye.Electrostatic ionization attracts dust,etc. into the player remarkably well sometimes. Carefully used a cotton swap to remove debri. PLayerworked fine afterwards ...Good luck!
Feb 27, 2007 | JVC TH-A75R System
Kenwood DV-605 Multi-disc DVD Player Logo
332 people viewed this question
Top Kenwood Televison & Video Experts
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Kenwood Televison and Video Expert? Answer questions, earn points and help others
