Question about Acer Aspire 5920-6335 Laptop
Wierd Power on Issue
Whenever laptop is powered off (hibernation, sleep, shutdown) and turned on again it turns on and off 6 times before it boots successfully. The hard disk reader smacks into the hard disk each time and a clicking sound is produced, damaging the hard disk. Does anyone have any solutions to this problem?
  • 159 Answers
Reinstall the operating system
Posted on May 30, 2009
Gateway MT6707 shutdown problem
Open the Control Panel, select Power Options, select High Performance, select Change Plan Settings, Under Plugged In, set time to Turn Off Display, set Put the Computer to Sleep to Never, select Change Advanced Power Settings, scroll through the settings , click on the + at Power buttons and Lid, set to shut down, Sleep and Hibernate to Never, adjust the rest to your preference. When you are not using the Laptop ALWAYS shut down and unplug to prevent damage due to power surges.
Apr 03, 2013 | Gateway Computers & Internet
Acer one with windows 7 ultimate fall into sleep mode
A laptop computer is typically set to conserve battery power. One of the common settings called standby, sleep mode or hibernation turns off power to the screen and the laptop itself after a preset time limit passes without any mouse or keyboard activity. It can be inconvenient for the computer to shut down while you're working on an open page or during a download. Change the setting if you don't want your laptop to going into automatic shutdowns
Turn the laptop computer on with the power button if it's not set to turn on upon opening. Allow the system to boot up. Open the panel for adjusting the sleep settings. This varies among the popular versions of Windows operating systems. To change the sleep mode setting on a laptop running Windows XP, click the "Start" button, and click the "Control Panel" selection. Choose the "Performance and Maintenance" selection, and click on "Power Options." Click the "Power Schemes" tab, and click the drop downs next to "Turn Off Monitor," "Turn Off Hard Disk," "System Standby" and "System Hibernates." Select "Never" for each drop down in both the "Plugged in" and "Running on Battery Power" columns. Click the "Hibernate" tab and click to remove the check mark in the box next to "Enable Hibernation." To change the sleep settings on a Windows Vista laptop, click "Start," "Control Panel," "Systems and Maintenance" and "Power Options." Then click "Change Plan Settings" under the currently established plan. Click on the "Advanced Settings" tab and select the "Never" option on the "Sleep," "Sleep After," "Hibernate After," "Display" and "Turn off Display After" drop downs. Click the "OK" and "Save Changes" buttons to confirm the settings. To change the sleep settings on a laptop running Windows 7, click the "Start" button, choose "All Control Panel Items," select "Power Options" and click "Edit Plan Settings." Click the drop downs for "Turn off the Display" and "Put the Computer to Sleep." Choose "Never" for both and click the "Save Changes" button.
Feb 06, 2013 | Acer Aspire One PC Notebook
Laptop Fan and Power Indicator won't turn off.
Are you sure you are turning it off completely. Sounds like you have it sleeping or hibernating. Press and hold the power button for 15 seconds or so, it should power off completely.
Mar 29, 2012 | Computers & Internet
Power button stuck down on gateway laptop
I doubt this would work twice, but a 30-min drive to the repair shop unstuck my power button. It was even in a padded case. Cheapest repair ever! (Hate me if you must but worth a try right?)
The button has been flaky for months. One day the laptop suddenly turned on by itself. When I turned it off it immediately started again from sleep/hibernate/shutdown. Pressing it 20x, spraying with compressed air and swearing didn't fix it. Instead of pulling the battery, I set Power Plan to "Power Saver" with everything set to minimum after 5 min., power button to do nothing, and NO timed shutdowns.
Jul 09, 2011 | Computers & Internet
My laptop battery/preparing to hibernate
remove the battery and adapter. press power button for 30 sec. then connect the adapter. press power button. if this didnt work. you need to ask for an help of a local tech to check for the video card and cable.
if it boots up to your operating system
control panel---->power options--->change plan setting--->
Turn off the display-never
Put the computer to sleep-never
control panel---->power options--->change plan setting--->advanced power setting
-set hard disk "turn off hard disk after" to never
-set Sleep "Sleep after" to never
-set hybrid sleep setting to off
-set hibernate after setting to never
Restart pc
Mar 07, 2010 | Samsung NC10-14ROBL Notebook
Acer 6930 freezes up
is it a problem with vista
Control panel
screensaver then power set standby to never
when you press power button turn off set when you close lid do nothing when I press sleep do nothing and then go to hibernate and remove the check in box
set your times for harddrive and monitor shutdown then press apply and restart
Jan 13, 2009 | Acer Aspire 6930-6771 Laptop
I was downloading, after ten minutes it was turned off
make sure that the computer was not on sleep mode or hibernation. word of advice, when you try to download something from the internet be sure that the ac adapter or charger is connected at all times to prevent the computer from going to hibernation. you can disable hibernation by going to toshiba power management console.
i hope this info helps.
Sep 07, 2008 | Toshiba Satellite A135-S2276 Notebook
HP Pavillion dv6000 Vista notebook crashes when entering sleep mode
This is a common problem with HP Pavilion laptops, including mine. Check and make sure there are no non-OS programs running that are trying to control power settings (like a power monitor program running in the system/task tray) and then turning of hibernation in the POWER SETTINGS and then for all "WHEN I CLOSE LID" and "WHEN I PUSH THE SLEEP BUTTON" and "WHEN I PUSH THE POWER BUTTON" select DO NOTHING, then APPLY. Then SAVE SCHEME AS and choose any new name. This will disable all sleep modes forever, but at least you can get on with normal use.
If you are geeky, try going into the BIOS and DISABLING anything marked WAKE ON, and disabling anything having to do with automatic power features, and then try hibernating and so forth normally through the OS again. Sometimes this works if there are conflicting settings in the BIOS also trying to increase power efficiency.
Good luck...
Nov 08, 2007 | Computers & Internet
Acer Aspire 5920-6335 Laptop Logo
59 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
