Question about Maytag MTB1504A Top Freezer Refrigerator
Freezer is thawing - water dripping -
My freezer stopped working - it clicks like something wants to come on but the freezer is dripping and everything has thawed.
    President:
  • 1,136 Answers
Hi, if the clicking noise is coming from the back, it is the relay on the compressor. It os possible that the compressor is bad but, most common it is the relay.
Is this under 5 years old? (warranty)
Please let me know if I can assist you further.
Vic
Posted on May 30, 2009
MY ROPER FRIGE IS LEAKING WATER FROM THE FREEZER TO THE TOP SHELF IN THE FRIGE
the drain tube from the freezer to the lower compressor area is plugged with ice or debris,and when it defrosts the water in the drip pan behind the evaporator back cover inside the freezer thaws and cant drain down and overflows down thru the damper vent door to the refrigerator,remove the rear panel inside the freezer shut off unit and let thaw,then take a wire and work it down this drain hole till water comes out at the bottom of this drain tube located in the rear
Mar 19, 2011 | Roper RT21AKXKQ Top Freezer Refrigerator
Water dripping from freezer into refrigerator
Just fixed my refrigerator last week that was doing the same thing. Water was dripping from the back top of the refrigerator and it was the drainage line in the freezer had frozen up and was plugged. Emptied the freezer and removed the bottom panel from the freezer and found large layer of ice. Turned freezer off and let everything melt. Then the hole in the back bottom of the freezer on the metal tray became visable. Contined to thaw until warm water would drain into the tray under the freezer. Was not hard at all and much better not cleaning up the water dripping all the time.
Jun 07, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
In-door water dispenser not working. tried lowering temp in frig to thaw line. Worked, but now line seems frozen again. ice in icemaker holder seems to be thawing and freezer is accumulating frost/frozen...
Defrost the freezer completely. Make sure the doors are sealed completely when shut. After defrosting plug back in and make sure the fan and the self defroster is functioning (your owner's manual should tell you how to reset the defrost timer). the problem may lay within the defrost system, and/or door seals and/or interior circulating fan.
Apr 30, 2010 | Refrigerators
GSH22SXA & several problems
For some reason my post has disappeared. I left you with a lot of information and now All I have is a clarification request. Something is going on with the server here today.Sea Breeze
Oct 03, 2009 | GE GSS25JFM Side by Side Refrigerator
Water dripping from bottom of freezer casing
Your drain line is frozen. Ice thawed by the heater in the freezer normally drains down a tube into a pan on top of the compressor, where it evaporates from compressor heat. If the drain freezes the water runs into the freezer bottom instead of the tube then into your fridge. To solve this remove everything from your freezer and remove the access panel in the back or bottom depending on your model of fridge. Turn off or unplug the appliance. Upon removing the panel(s). you will likely see that the bottom of the freezer is full of ice. Use a hair dryer or heat gun to thaw ice and remove. In the very back bottom you will uncover the drainhole. I usually use very hot water and a shop vac to thaw the drain hole. When you finally clear it you will hear water running into the pan on top of the compressor. Somethimes it takes a lot of hot water to clear the drain. Hope this helps!
Jul 08, 2009 | GE Refrigerators
Water dripping into refrigerator from freezer
DRAIN TROUGH IS PLUGGED OR FROZEN. EMPTY FREEZER AND REMOVE LOWER TRAY TO SEE A HOLE ALL THE WAY IN THE BACK USUALLY IN THE CENTER. CHECK TO SEE IF WATER CAN DRAIN THROUGH BY POURING A CUP OF IT INTO HOLE. IF IT IS FROZEN POUR HOT WATER UNTIL IT THAWS, IF PLUGGED REMOVE THE OBJECT.
Jan 28, 2009 | Estate TT21AKXKQ / TT21AKXKT Top Freezer...
Bottom freezer door dripping water on kitchen floor
you can take a ook into the freezer sect its possible that the line has frozen, nad no longer is defrost water going into the drain but rather falling on to the floor of freezer and evnetually out the door
Jan 11, 2009 | Freezers
Layer of water on bottom of freezer,causing problem opening bottom drawer, having to use hair dryer to thaw.
If it is a frostless your drain tube is plugged. The water cannot go through the whole to the drip pan so it flows over into the freezer. Unplug the freezer and leave the door open all day to thaw. Or take the back wall out of the freezer and unthaw the drain tube with hot water and a hair dryer.
Nov 17, 2008 | Freezers
Frige has water dripping in from freezer
Hi, Check the door seal.
Ice is often caused by warm, moist air getting into the freezer and condensating, then freezing.
Jun 25, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Maytag MTB1504A Top Freezer Refrigerator Logo
209 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
