Question about Kenmore Refrigerators
Where is the water outlet located
Can not find the water outlet on my kenmore
  • 11,896 Answers
In the back bottom. The drain is in the back inside and leads down to a heating pan which evaporates the water.
Posted on May 30, 2009
Keep getting ph code--per manual it says low water pressure--I recentlt moved and the home has no hot water outlet so I capped inlet on washer--still getting that code--any ideas?
Sears has online expert service. Go to the link below and they might be able to answer. You'll need your model number which you can get off of plates mounted in various locations on washer.
Repair Maintenance Questions Answers
Dec 02, 2014 | Kenmore Elite 45986 Front Load Washer
How do you install a thermostat on a 2001 suburban?
  1. Standing in front of the vehicle it's on the left front side of engine kind of low.
  2. Be sure to get a gasket as well.
  3. Drain the cooling system.
  4. Loosen the air cleaner outlet duct clamps at the following locations:
    • Throttle body
    • Mass airflow/intake air temperature (MAF/IAT) sensor
  5. Remove the radiator inlet hose clip from the outlet duct.
  6. Remove the air cleaner outlet duct.
  7. Reposition the outlet hose clamp at the water pump.
  8. Remove the outlet hose from the water pump.
  9. Remove the water pump inlet bolts.
  10. Remove the water pump inlet and thermostat from the water pump. Water pump inlet/thermostat assembly location
To install:
  1. Install the thermostat and water pump inlet to the water pump.
  2. Install the water pump inlet bolts.
  3. Tighten the water pump inlet bolts to 11 ft. lbs. (15 Nm).
  4. Install the outlet hose to the water pump.
  5. Position the outlet hose clamp at the water pump. NOTE
    Important: Align the arrow at the throttle body end of the duct with the throttle body attaching stud.
  6. Install the air cleaner outlet duct.
  7. Install the radiator inlet hose clip to the outlet duct.
  8. Tighten the air cleaner outlet duct clamps at the following locations:
    • Throttle body
  9. Tighten the air cleaner outlet duct clamp screws to 62 inch lbs. (7 Nm).
  10. Fill the cooling system and check for leaks.
Read more: http://wiki.answers.com/Q/Where_is_the_thermostat_located_on_a_2001_chevy_suburban#ixzz1TvIO3kpD
Aug 03, 2011 | 2001 Chevrolet Suburban
Water dispenser just stopped working. Ice dispenser still works and the refrigerator has a new filter
two possibilities
1) the water valve is defective it has one inlet from the house plumbing,two outlets, one for i/m one for water dispenser
2) the reservior that chills the water is frozen, it is located behind the lower crisper drawers in the ref. to see if its frozen remove crispers and shelves and tap on it , if hollow sounding it's not froze if solid sounding its froze. to thaw it turn off unit for at least a hour
Jul 21, 2011 | Kenmore Side by Side Refrigerator
Kenmore side by side: ice maker works...ice
Probably a broken plastic tube from the solenoid valve to the water outlet tube. It will stay dry until you try to get water then it may take a few days to dry out.
Good Luck,
Gilsh
Nov 27, 2009 | Kenmore 57029 Side by Side Refrigerator
The water pipes rattle violently in the beginning of the cycle.
My Kenmore 16464 dishwasher caused a buzz in the water pipes at the start of the cycle that I thought was just water hammer. It turned out to be a bad water inlet valve on the dishwasher that has water hoses (inlet and outlet) attached plus has an electrical connector. It is located near the front left underneath the tub. I pulled the dishwaher out and replaced it and all is quiet again. - Jim
Nov 13, 2009 | Kenmore 24 in. 16462 / 16464 / 16469...
The icemaker is not getting water from the line, but we are able to get water from the front of the door. what should we be looking at?
The water inlet solenoid has one inlet line and two outlets 1 for icemaker and 1 for water dispenser. Located on the back bottom of frige. Unplug frige. Follow water line to part
Nov 04, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Inlet bezel located in l/hand outer side of dishwasher is leaking can't get it off the dishwasher to see if it is it or the gasket
The inlet/outlet bezels are defective. If you run the dishwasher wthout them in place, you get water in the drawer door and all over the floor too. The plastic disintegrates. It's a problem that Kenmore/Sears needs to fix asap!
Nov 01, 2009 | Kenmore Dishwashers
2002 grand prix motor 3.8 just want to know where
Exploded view of the thermostat arrangement—3.8L engines
Oct 31, 2009 | 2002 Pontiac Grand Prix
Kenmore refrigerator: water outlet by ice outlet
HI. this will occur if the inlet valve assembly is experiencing issues, within the solenoid structure. In some cases, debris will build up, in return, not allowing the solenoid to completely close, when not in use(the solenoid can also fail as well). This will cause a slow drip, or a leaky dispenser spout.
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink). Disconnect the supply line. Remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors
Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
Oct 21, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Changed the water filter on my Kenmore 596 50692000 model but now I there is no water flow. I have changed the filter before without a problem. What could be wrong. Someone mentioned that the line might...
You have clogged the water inlet solenoid valve. It is located in the water line and will need to be taken apart and cleaned or replaced. When you change a water filter you always need to bleed it into a bucket before attaching the outlet end to the water line, to evacuate all the carbon impurities.
Jun 23, 2009 | Refrigerators
Refrigerators Logo
37 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
