Question about Panasonic DMR-ES40V DVD-Video Recorder
VHS play back
During VHS playback the image is a double image in black and white.  I have tried this playback on 2 tv sets with the same results.
Re: VHS play back
There is solution of paticular troule, ask service dept, Hidden function of procedure can be fix , get sequence steps from them.
Posted on Apr 29, 2008
  • 4 Answers
Re: VHS play back
I am having the same split screen black and white problem. I don't think anything simple will fix this. I have looked into the unit and almost all the video processing happens on one little PC board under the DVD. I think that the capacitors on the bottom of this board are at fault, as there have been MANY noted failures of Panasonic Professional DVC decks due to these type capacitors failing.
Posted on Dec 12, 2007
0 characters
3 Points
The VHS tapes will not playback on the Samsung TV (flat screen)..the Samsung TV is a Syncmaster 2333 HD...the Samsung dvd/vhs unit is a DVD-V9800 The DVD discs will play just fine. How should I be...
On these combo units, the VCR will not play using component cables but the dvd's will play just fine.
What you need to do is run a pair of composite (Yellow, red and white) cables and use that for VCR and component (Green, blue, red, white and red) for the dvd player.
Make sure you switch the tv to the corresponding input.
Dec 30, 2009 | Samsung DVD-V9800 DVD Player/VCR
NV-VP60GC-S How do I get the color?
really? that's a settings up the menu(got a manual with this item?) and reset for defaults.
May 23, 2008 | Panasonic Multi-System Region-free...
VHS plays in colour and DVD plays in black and white.
there is a circuit in the color section to put the tv to black and white if the color subcarrier is missing from the broadcast signal.
it is called a color killer and needs to be adjusted.
it is for a technician to do.
it operates off the 3.58mhz color subcarrier.
Aug 18, 2009 | Jwin Electronics JD-VD138 DVD Player
Plays vhs tape in only black and white (no color).
my old series of ROOTS is playing in black and white and says on cover that they are in color
Jul 03, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Black and White menus and playback
If you are connected on av2,make sure it is not on av2s,as this will give a b/w pic
Mar 07, 2009 | Panasonic DVD & Blu-Ray Players
I need playback channel for tv to be ch.4 -
Solution 1
How to set the DVD Recorder+VCR’s RF output channel
Turn off the DVD Recorder+VCR, then press and hold
CH (v/V) on the front panel for about five
seconds to change the RF output channel (CH 03 or
CH 04). “RF 03” or “RF 04” appears on the front panel display.
Solution 2
Cable Service With Cable Box
If a cable box is required in your cable system, follow the
instructions shown below. This hookup permits both TV and
DVD Recorder+VCR operation.
To view or record a CATV channel:
1 Tune the TV to the correct video input channel.
2 Set the DVD Recorder+VCR to the output channel of the
cable box using the CH (v / V) or the 0-9 keys on your DVD
Recorder+VCR (e.g., CH3).
3 Select the channel you wish to view on the cable box.
Please rate this a fixya
Jan 30, 2009 | GoVideo Go Video DVD/VCR Combo
DVD in, have sound but no picture???
Initially, a couple of ideas:
  • check the cables from the DVD to the VHS to the TV (I am assuming that the sound is likewise connected to the TV and not to a home receiver system or an amplifier);
  • I am assuming again that you are using RCA and not RF, if yes pls pay special attention to the yellow RCA on both the DVD to VHS and VHS to TV;
  • diagonal roll often indicates a loose ground or a defective cable/RCA connector;
  • verify settings/configurations in all three; DVD, VHS, TV. TV should be set to AV or Video, VHS likewise to A/V INput;
  • try playing a known good VHS tape, if normal playback, problem is between DVD and VHS, if likewise no video, problem is between VHS and TV.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 13, 2008 | KLH DVD8350 DVD Player
1}DVDR 3480 playback on many Dvds widescreen insteadof 4.3 as set. 2) my Vcr. has 3pin phono. Dvdr scart to Phono .Xt2 says nosignal. Phono tophono (cam socket) no signal .cannot copt tape to DVD. 3)B W...
1) The 4:3 / 16:9 option only optimises playback for that particular type of TV. The 4:3 setting also allows you to set the output between:
  • 4:3 PS - expands the picture vertically and horizontally which gets rid of the black bars, but you also lose the left and right edges of the picture.
  • 4:3 LB - Letterbox format, displays the full picture from the disc, with black bars top and bottom.
The PS option loses the bars on 16:9 widescreen DVDs, but may still leave bars on true cinema widescreen DVDs, which are 21.7:9
This is normal.
  • 16:9 - Optimises the picture for a widescreen TV. Again True cinema widescreen DVDs will still have black bars.
2) All of the external inputs will show "No signal" until there is actually a signal playing into them.
EG to copy VHS to DVD, you will need to select the relevant scart or phono input, and press play before the recorder will register a signal and allow recording.
Some bought VHS videos have copy protection, and may cause problems when copying to DVD.
3) Greenish playback maybe caused by colour setting on TV being too high. Also check Hue or Tint settings on the TV, if it has them.
4) For some reason, in their infinite wisdom, Philips omitted the Video Plus facility from this model.
Apr 28, 2008 | DVD & Blu-Ray Players
VHS tapes are black and white
The tapes are B/W or one of the playback video heads is not making contact with the tape. The video head may need to be adjusted. You can take it in to get it fixed or buy a new one. The unit today is worth around $25-$30.
Jun 25, 2007 | Emerson EWD2202 DVD Player/VCR
check in your menus to see if your can change your scart output settings, i.e. rgb
Feb 26, 2007 | Panasonic DMR-E50 DVD Recorder
DVD & Blu-Ray Players Logo
171 people viewed this question
Top Panasonic DVD & Blu-Ray Players Experts
Are you a Panasonic DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
