Question about Dryers
HAVE A HOTPOINT CTD80 HTUMBLE DRIER AND THE CODE F10 HAS COME UP. HOW CAN I REPAIR THE PROBLEM PLEASE.
    Sergeant:
  • 296 Answers
HI
chek this forum to ve an indepth knowledge about your prob
http://www.fixed4free.com/answers.php?id=21356
OR
chek this link which shows specifically bout ur prob
http://www.fixed4free.com/answers.php?id=206176
OR
here is a link that has all hotpoint error codes:-.
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
OR
chek this link:-
http://www.justanswer.com/questions/1s54h-hotpoint-ctd80-f10-error-code
F10 - Common of heater open or one shot open
The issue can be sorted if you are handy else a repair man might be needed.
For a tech visit AND for details from Hotpoint(GE customer care)
CHEK HERE:-
http://www.geappliances.com/service_and_support/contact/
OR
chek this one;-
https://www.ukwhitegoods.co.uk/modules.php?name=Forums&file=viewforum&f=34&topicdays=0&start=5450
I ve tried to give all the usefull links ,tht will sure solve your prob
do let me kno
all the best
regards
Posted on May 30, 2009
Pressed reset button on left hand therm0stat dryer runs but still error code f10 elements not getting warm
I found this, an answer already posted on Fixya.....
If you remove the back cover of the drier with the appliance un pluged, you will see the heater bracket.
un screw this from the back panel, and at the top you will see three thermostats. There is a brown one with a small hole in the middle, if you use a pin and press in, you should hear a click. This resets the thermostat and you should be able to use the drier again.
Dec 12, 2013 | Hotpoint Dryers
Hotpoint ctd80 tumble drier drum not moving but still heating up
yes it will b the drive belt and its a easy repair.
Jan 17, 2012 | Dryers
How do you remove top from a Hotpoint CTD80 tumble drier. 2 Screws holding at back. Does it slide forward or back or lift vertically, or are there other screws to remove?
2 screws at the back and then push the top towards the back of the machine...you might need to give it a bit of a wack, if it's too tight just take the 3 screws from the back of the side panels and things will loosen up a little
Dec 10, 2010 | Hotpoint TDL15 Electric Dryer
Ctd80 hotpoint condenser dryer not heating up at all showing error message f 14 think its thermastat
Error code 14 indicates dryer element fault.
Checkelement-connections-and control module.
Please leave feedback.
Thanks.
Nov 15, 2009 | Hotpoint Dryers
No heat F-10 F-08 HOTPOINT ULTIMA CTD80
When you take the large metal plate off the back of the drier you will see the 4 elements (bars/coils with fins!). separate the plate from the element bracket by removing the 2 screws. there are 3 round cylinder type electrical connectors, there will be a black one with a hole (approx 2mm) poke a small pin into it and you will hear a click. This is the Bi-Metallic thermo cut out device. as it has tripped once it will have slightly weakened the "sprung contact", This may cause it to trip again a little while later. A new thermostat will be required if it keeps returning. dont forgot to clean the condensor unit on a monthly basis.
Jul 24, 2009 | Hotpoint Dryers
F10 error code on Hotpoint ctd80. How do I fix ? Thanks
remove 2nd largest panel on back of dryer then remove the heater unit (two small screws) from inside panel,on the top of this you will see two small units with wires going in and out both sides looking closer one of these units has a small hole using a pin push it down into hole this resets thermal cut out,you should hear a small click.
Feb 02, 2009 | Hotpoint TDL15 Electric Dryer
Dont know what the fault codes are for my Hptpoint Dryer CTD80
Hi.
F10 indicates that the heater is open circuit, or the thermostat is faulty, more likely to be open circuit thermostat, you should replace both thermostats.
Also make sure that you clean the filters regularly
This should solve your problem.
Nov 20, 2008 | Hotpoint Dryers
Condensor hotpoint ctd80 drier WON'T GET HOT
Check vent from dryer to outside.
May 09, 2008 | Dryers
Hotpoint ultima tumble dryer error code f-03
i have a hotpoint ultima ctd80 which i have had the last 2 years, it has shown error codes f11, f10 and f15, every time i fix this problem by first switching off and unplugging appliance then removing small cover from back (middle with 2 screws) then larger panel that the smaller panel overlapped. once you remove these you will see the heating elements, remove the 2 screws at the back off this, remove cover carefully then at the top you will see two things (not very technical lol i am a woman), with a pin press the pin in the one with a hole, mine makes a clicking sound when i do it, not sure if it meant to but works for me. put all parts back together and thats the job done. make sure both fillters and water emptied regular, hope this helps and saves you a fortune on call outs
Jan 26, 2008 | Hotpoint Ultima WF860 Front Load Washer
Ctd80 hotpoint dryer error code f10
Apparently a common fault on these indicit based driers.
it worked on mine
Oct 08, 2007 | Dryers
Dryers Logo
81 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
