Question about Refrigerators
What is the grill cap on the PUR filter? I don't seem to have it.
I have the kenmore side by side refridgerator that takes the PUR water filter. the item is #04609030000 and Mfr. model # 09030. I recently got a new filter and in reading the instructions, realize I do not see the "grill cap" it talks about on the old filter. This makes me think it came with the refridgerator and I threw it away with a filter early on. Also, may be the reason why I have trouble getting the old filter to eject when it needs to be replace. My questions are : 1. What is the grill cap? 2. Can I order its replacement? 3. can the filter work without it? Thank you jillkeith100@gmail.com
  • 2 more comments
  • jillkeith100 May 30, 2009
    yes, but it is a sears kenmore, not a matag
    09030 Kenmore Elite Side by side, thanks
    hey, thank you for trying to help but I figured it out. I think I did throw it away with the first filter I had .....duh! I will order another. Have a nice day.
    yes
    President:
  • 1,136 Answers
HI, Is the filter down near the floor in the kick plate?
If I had a model # I caould look this up for you.
Thanks
VIc
Posted on May 30, 2009
  • 2 more comments
  • Victor
    Victor May 30, 2009
    Wasn't sure what brand it was but, I can still look it up with a model #.
  • Victor
    Victor May 30, 2009
    I am sorry but, I need the whole model # off the label inside the fresh food section.
  • Victor
    Victor May 30, 2009
    Ok. Was it the one down in the kick plate?
  • Victor
    Victor May 30, 2009
    Ok, Thanks. I tried to find the part# for one but I could not find it without a nodel #
    Please feel free ro rate my response so that others as well as myself can see how I am doing.
    Vic
I can't seem to remove filter the cap came off but I can't seem to get filter out
With the cap off the filer was not turned far enough for it to clear the locks. Grab the filter with a pair of pliers and turn it to the unlock position then pull it out.
Aug 14, 2014 | Whirlpool 21.8 cu. ft. Side-By-Side...
The hold light and change filter light are on constantly and nothing seems to be working
Have you changed your filter, mine came n and I did not know to reset the filter changed are on the sensor.
Sep 24, 2013 | Kenmore 21.8 cu. ft. Side-By-Side...
Where is the filter for the ice maker on whirlpool refer model number ED2CHOXK005
Removing and replacing a water filter - base grill location
Filters situated in the base grill (below the freezer compartment) of Whirlpool-built side-by-side refrigerators are relatively simple to replace. Follow these two steps:
  1. Grasp the filter's end and make a one-quarter turn to the left.
  2. Pull the filter straight out.
To replace with a new filter, repeat these two steps in the opposite order, making sure to first remove the red cap from the filter. Proceed by pushing the filter straight into the slot, and then giving it a one quarter turn to the right.
Note: Replacing this type of filter is quick - there is no need to unplug your refrigerator when replacing it. Also, this filter should be replaced every six months.
Dec 18, 2010 | Whirlpool 21.8 cu. ft. Side-By-Side...
How to replace the filter
Take the new water filter out of the box and remove the two red shipping caps on the end of the filter.
The water filter is located on the front panel down near the floor.
Push the release button located just to the left of the water filter grille cap, this will release the filter.
Remove the grille cap from the filter by twisting it counterclockwise.
Reinstall the grille cap on the new water filter.
Insert the new water filter in the refrigerator making sure the words on the filter are the correct side up.
Push the water filter in until it clicks in place.
Flush Water After Installing New Filter
Be sure you flush out the water from the new filter after you replace it! Many readers are having trouble with airlocks because they are skipping this important step. Kenmore recommends you run the water out of the water and ice maker for a few minutes to flush out the new filter. This also helps remove air bubbles from the system. If you don’t do this it’s possible that the water dispenser may not work properly due to an air lock.
This particular water filter claims to reduce:
Cysts and turbidity – linked to gastrointestinal problems
Lead
Chlorine – taste and odor for better tasting water
Sediment – for clearer water
o-Dichlorobenzene – linked to risk of liver, kidney, or circulatory system problems
Benzene – linked to increase risk of cancer and anemia.
Note continue changing the filter on a regular basis.
Hope this helpout....
Aug 01, 2010 | LG Refrigerators
Cannot locate the water filter
Look at the bottom, if not obvious, perhaps behind a grill. Ours just has a cap, turns & slides out. (Kenmore/Whirlpool)
Compare filter prices: Whirlpool filters - the same PUR filter as the Kenmore - was half the price from a parts store rather than from Sears. Either a parts store or appliance dealer can also tell you what kind of filter you need & how to access it.
Nov 18, 2009 | Refrigerators
Can't locate the water filter. water has a bad taste
The base grille water filter is located below the freezer
compartment door. Depending on your model, you may have a filter that is installed behind the base grille or a filter that is installed through the base grille.
May 23, 2009 | Kenmore Refrigerators
Refridgerator not cold
Called Sears to send a technician. Replaced the thermostat (DTS). Fridge is now working. The themostat was $21 + service/labor total $160 +/-.
Nov 30, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Can't locate the filter
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Filter is at the bottom of the fridge, in the grill, 6-8" from the left side.
Manual and parts list is available at http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=gs5shaxtl01&siteCd=WHRCOM
Regards,
MrBoo
1. Press the eject button to release the filter from the base grille.
3. Turn the cap counterclockwise to remove it from the filter.
IMPORTANT: Do not discard the cap. It is part of your
refrigerator. Keep the cap to use with the replacement filter.
4. Align the ridge on the cap with the arrow on the new filter and
turn the cap until it snaps into place.
NOTE: You can run the dispenser without a filter. Your water
will not be filtered. Simply insert the cap all of the way into the
base grille and rotate the cap until it is firmly in place.
5. Remove the protective covers from the O-rings. Be sure the
O-rings are still in place after the covers are removed.
6. Push the filter into the base grille. The eject button will pop
back out when the filter is fully engaged.
7. Flush the water system. See “Water and Ice Dispensers.”
gaskets. Do not use paper towels, scouring pads, or other harsh
cleaning tools.
Nov 11, 2008 | Whirlpool Refrigerators
Refrigerators Logo
166 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
