Question about Baumatic 23 in. BDW13 Built-in Dishwasher
Dishwasher it wont drain My dishwasher is not draining properly and also there is a banging noise from below the washer. I have checked the drain pipe and connections and they are clear.
  • 332 Answers
Sounds like the pump is shot, the noise could be the bearings in the casing grinding, pull it out and get you either a new pump or a new dishwasher just a little diffrence in the price
Posted on May 30, 2009
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Aug 18, 2014 | Washing Machines
DISHWASHER WILL NOT DRAIN PLUMBER WAS CONTACTED DRAIN LINE IS FINE LOOKING FOR OTHER CAUSES? THANKS, SEAN
Can you hear the pump trying to drain it? If you can then you have a blockage. Try blowing hard down the outlet hose, what happens? Have you checked all filters?
Mar 06, 2011 | Frigidaire FDB1502RGS Built-in Dishwasher
A loud noise from the pipe that connects the dishwasher under the sink. Would that be a problem with the machine??
When the solenoid turn on to let water into the dishwasher and when it turns back off it can cause the pipe to jump. I will assume that it is banging into something. If so over time it could create a hole in the pipe or tube. I'd try and figure out what it is hitting and move one or the other things.
Sep 20, 2010 | Whirlpool Dishwashers
I have a Bosch SHE55C05UC dishwasher and it just started to not wash properly and leave water in the pan below (first time it did not drain at all.. I tried the rinse/hold cycle and got the unit to drain...
I am assuming you have checked the filter and drain sump and there are no obstructions. Have you tried taking the drain pipe out of the sink downpipe and checking if it drains directly into the sink?
I am also assuming the wash cycle is completed when you open the dishwasher.
Do you hear the drain pump running?
Post your comment after you have checked the things I mentioned.
Jun 17, 2010 | Bosch SHE55C05UC Dishwasher
Electrolux dishwasher won't drain. Not a clog in the outlet hose or drain pipe.
The drain hose on a washing machinemag-glass_10x10.gif connects the drain pump to a stand pipe, a U-pipe under the sink, or another place for draining dirty water into the sewer. If your washer won't drain properly, the problem is sometimes an object blocking the drain hose, like a pair of underpants, a child's sock, or pieces of something that broke up in the washer.
  1. Unplug the washer and put the plug on top of the machine to keep it out of any spilled water.
  2. Step 2 Take any wet clothes out of the washer and bail the water out of the drum with the bucket. The washer may be too heavy to move if it's full of water and wet clothing.
  3. Step 3 Pull the washer out from the wall enough for you to get behind it.
  4. Step 4 Remove the plate from the back of the washer by taking out all the screws. Different brands and models of washers vary in how many screws hold on the back plate, and not all models require removing the plate to get to the pump where the hose is attached.
  5. Step 5 Locate the drain hose. Of the three hoses coming out of the back of the washer, the drain hose is the largest in diameter and is attached to a drain pipe instead of a faucet.
  6. Step 6 Check the drain hose for kinks and bends. These are often the cause of a blocked or slow-running drain hose.
  7. Step 7 Remove the drain hose from the washer by detaching it from the drain pump. You will need a screwdriver or a slide-lock wrench to open the clasp that holds the hose to the pump, depending on what type of clasp it is.
  8. Step 8 Keep the bucket nearby to catch any water that comes out of the drain pump when you remove the hose.
  9. Step 9 Remove the other end of the house from the pipe it drains into.
  10. Step 10 Bend the clothes hanger open so you can use it to poke inside the hose. Push or pull out the material that's causing the blockage.
  11. Step 11 Replace the hose and run the washer to check if it's clear.
Nov 13, 2009 | Electrolux 24 in. EDW5505EPS Stainless...
My dishwasher doesnt drain and the drain button is flashing
ok if it doesnt drain properly... it means the drain hose isn't carrying it to the drain pipe, or the house's drain lines are backed up.
check these: Drain line/air gap Pump Drain valve and/or solenoid Belt Motor Timer
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain.
Air gaps are installed in the drainage system to prevent the discharge from the dish washer to enter the sewer system and the contaminated water to drain back into the dishwasher after the pump stops.
When we install a dish washer we loop the discharge hose as high up under the cabinet as we can and secure it with pipe straps.
This creates a air gap so that when the pump stops nothing from the drainage system can flow back into the dish washer.
Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line.
If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
we ll now see how to check the pump
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support. Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm.Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller.
The drain impeller pushes the water toward the drain port.
if u see any of these parts broken u wud need to replace themnow the next thing to check wud be the drain valveMany dishwashers use a drain valve with an electric solenoid.When electricity flows to the solenoid, the valve opens and diverts the water to the drain.Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly.To access the drain valve remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel.It may be necessary to first open the door to the dishwasher to reach the screws over the panel, then close the door to remove the panel. Look for a water hose running from the motor or underside of the tub. The hose should lead to the drain valve. now we need to check the motor ... now u might not be required to come uptill this iam giving u instructions just incase
If the motor isn't turning or working, the unit won't drain If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week,you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors just can't be serviced.also refer the following links http://www.acmehowto.com/howto/appliance/dishwasher/check/airgap.php
http://www.acmehowto.com/howto/appliance/dishwasher/check/timermotor.php
regardsiversh
Apr 27, 2009 | Miele 24 in. G645SC Plus Free-standing...
My dishwasher will not drain completely
I had a similar thing with ours. Found out the drainage pipe that goes from the dishwasher to the pipes under the sink was blocked. Take hold of the pipe that geos under your sink from the dishwasher (usually a flexible pipe) and give it a shake and a bang a few times. Also check the filter inside your dishwasher, take it all out and give it a good wash. Look inside the cavity where the filter came out of and make sure no food / fat or other gunk is inside that. I also found those dishwasher cleaner things work very well at unblocking. Buy from a supermarket and you put it in the dishwasher with no dishes. Ours worked like brand new after I did all of this. Good Luck.
Feb 24, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishwasher loud in beginning cycle and drains early
sounds like you have 2 problems however generally speaking (most makes) of dishwashers go into drain mode when there is a fault elsewhere, however is this set up properly, is the waste pipe end high enough to allow the water to actually fill up (only about 30cms of water aprox)so it doesn't flow straight though to the waste. the noise could just be an empty pump, it runs dry after a while, and makes a screeching noise eventually? check installation pictures to see if its set up right, you may have also a leak somewhere check all other connections and pipes
Sep 21, 2007 | Maytag MDB7100AWB Dishwasher
Whirlpool AWM6120 Front Load Washer
Cleaning depends on use. 8 years is a bit over the top! When your water does not drain, check the outlet filter first, then the pipe from below the tub to the filter. Your washer wont spin 'cause the pump/filter is blocked.
Jul 24, 2006 | Whirlpool AWM6120 Front Load Washer
Baumatic 23 in. BDW13 Built-in Dishwasher Logo
433 people viewed this question
Top Baumatic Dishwashers Experts
Greg Cann
Greg Cann
Kolbrun...
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
