Question about Craftsman Garden
Craftsman lawnmower carb pours gas
Walk  behind  mower,  they all have  the  same  carbs,  cleaned up  carb. float and spring  held  needle....got  it  to  start ,then  gas  just  started pouring  out  of carb any  hints??? thanks  , Joe  Hanner
  • fjoe1200 May 31, 2009
    say it  is  the needle & seat  leaking,  how  do I  fix  that?? Thanks.joe
  • fjoe1200 Jun 05, 2009
    Thanks for gettin` back.. the model # is917.377250 the serial # is012197m000872... the float is brass thankx again..JOE
  • 376 Answers
One of two problems. your needle and seat is leaking or the float has a hole in it
Posted on May 30, 2009
  • Dwain Pippen May 31, 2009
    What is the model and type # on the engine and I can tell you what part # you need and how to do it. First, be sure the float is good. Take it off the carb and shake it. If you can here anything inside it, that means it is leaking. Usually not a problem with plastic floats, though.
  • Dwain Pippen Jun 06, 2009
    You have to remove the carb from the engine. Remove float and needle. In the needle hole there is a rubber seat. Remove the seat with a pick. You will need Tecumseh part # 631021. Push the new seat back in the hole with a punch just large enough to fit. Be sure to put the grooved side towards the bottom of the hole, smooth side out. A drop of oil on it helps keep it on the end of the punch and slide in the hole. Put the float back on. It should not be sitting level, but slightly angled. Hope this helps. Dwain
Why does my craftsman riding lawnmower have gas coming from the exhaust?
Needle valve in the carb or problem with the float. Take the carb bowl off and look.
Jul 13, 2014 | Craftsman Garden
3.5 hp Briggs & Stratton won't run unless I pour gas into carb
This sounds like a problem with the suction. If the air filter is clean then it will need new carb gaskets. There may also be an issue with the pressure being created by the engine.
Jun 18, 2014 | Briggs & Stratton Briggs Stratton...
Craftsman gold 6.0 hp. walk behind lawnmower wont start
Back to basics, is the fuel in the tank good?( fill with fresh fuel ) does it have a spark at the plug?(remove the plug, earth against the cylinder, is there a spark,if not, replace the spark plug and try again ) does the plug wet with fue lafter pulling?( clean/service carb ) is the spark occuring in the correct place ( flywheel key sheard ) has the engine got good compression?
Aug 19, 2013 | Briggs & Stratton Briggs Stratton...
Lawnmower carburetor problem.
Remove carb float bowl. Check float operation. Float down gas flow, float up no gas flow. Clean float bowl. Observe bowl screw, see if there is a hole or holes thru the screw. Clean out with thin wire, bread wrapper works peeled back about an inch. Use wire to clean out center port of carb. Remove mounting pin of float, remove float and meter needle, clean out port up thru carb with wire. Reassemble try to start. Prime at least 3 times, ensure primer bulb is not cracked, replace if cracked. Replace air filter if dirty. Replace spark plug once a year. Fill oil. 30w. Mowers now have a low oil cutoff.
Jun 14, 2013 | Garden
3.5 TECUMSEH ENGINE CRAFTSMAN LAWN MOWER. STORED LONG TIME. WOULD NOT START-CLEANED FUEL SYSTEM -GOT FRESH GAS. LAWN MOWER STARTED-HAS A HIGH IDLE NOW AND WILL NOW IDLE AT NORMAL IDEL SPEED. HOW TO...
Float stuck in open position. When the gas evaporated in it there was a gunk left behind and then It was down and either froze up or there is trash keeping the needle valve from sealing up all the way.
So when you start it gas keeps pouring into the motor. It is suposed to shut off once it gets enough to run on.
Be real careful take the carb off and remove the bowl. And then the float. Take a q-tip and clean the needle valve port ou real good. And clean the rubber tip gently. Then put back together.
When it is upside down the float should be parallel with the carb. That would be the shut off point. You may have to adjust it.
That should do it. When you hook the gas line back up loosen the bowl and let gas in carb til it starts to run out. Then mow.
Oct 02, 2010 | Craftsman Garden
Lawnmower sat up for a season would not crank replaced sparkplugs air filter fuel filter hose fuel pump is pumping gas to carburator but still will not start unless you pour some gas into the carburator or...
If it will start when you pour gas then its a fuel problem on some of these they have a screw at the bottom of the carb remove that and see if you have bad fuel. If that does not work then remove the carb and service it may just be a stuck float or something
Aug 09, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a craftsman Lt 1000, 17.5 hp tractor. It
Check for cracked fuel lines, plugged fuel filter, if all ok, then check fuel pump.
Mar 14, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
I have an old Craftsman Lawnmower and when m husband poured gas into the gas tank, it came out of the air filter. Any suggestions on how to fix?
Your float is stuck inside the carb,remove the bowel with a 7/16 wrench remove the bowel and clean reinstall and it will run
Sep 01, 2009 | Garden
My Troy Bilt Self Prop. Z-start won't keep running. I clean All, replace Filter and Plug, have clean gas and lubed all. It Starts for 2 seconds and then cuts off. What do you think it could be? Thanks....
I had the same problem, Tilt the lawnmower on it's side air filter facing up and remove air filter cover and air filter then remove the fuel bowl underneath the carb; then clean the fuel bowl with some gas and a clean rag. For the next step be sure to aim blower tip at target then look away before pressing trigger, this will prevent gasoline form getting into your eyes.Take an air compressor and carefully clean out the carb where the flap is and the tube where the fuel float that would rest inside fuel bowl is. Leave on side install everything back except for air filter and cover. Then pour a little gas in the carb to prime it, lay the lawnmower back on all 4 wheels and try to start.
Aug 02, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
389 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
