Question about Amana Comfort Zone 12M32PBEH Air Conditioner
Rheem Criterion II air conditioner runs but it does not cool
It runs and blows air but it is not cooling the house.
  • 14 Answers
Check air temp out vent should be approx 20 degrees colder than room temp if it is your unit is too small for the amount of space you are cooling.Rule of thumb 1 ton(12,000btu's) for every 400 sq ft of uninsulated space
Posted on Jun 03, 2009
I have a rheem criterion ii plus 2 lxe, the blower fan will not run
Check for a low voltage relay that may be used to power the blower, see if operates. To check a blower motor directly, connect it directly to 120volts. (it might be a 3 speed blower with 4 wires connecting it, so check the wiring diagram)
Aug 18, 2014 | Heating & Cooling
Rheem criterion ii a/c problems
Not a scam but you can get 2 opinions. Moisture removal is a process of closed circuit HVAC. It appears that you have a lot of moisture. IS there a leak in the building structure? Outside air or a swamp cooler can cause this. Sounds like the evaporator coil on the inside unit needs cleaning badly. IT is dropping debris in the pan and causing the flood. The installation of the switches was an attempt to fix the issue by a guessing. I doubt the final diagnosis unless it was a direct result of something the repairman did. He added so many additional switches that it could be his modification that caused the issue.
Jul 16, 2013 | Water Heaters
I have a rheem hvac unit that is not cooling the air that is blowing into my house. The air feels like it is the same temperature as the air outside.
the compressor isnt running you would need to check capacitor maybe not enuff freon how does your filter look
Sep 11, 2010 | Heating & Cooling
Air Handler Blower
if you have a meat thermometer, place it in the vent when the air is on, it should be cooling somewhere around 15-18 degrees F lower than what actually temp is, so if its 84 degrees, your unit should blow around 67 degree air out of the vent. if it is not call a tech. your system could be under or over charged.
Jun 21, 2009 | Goodman CLQ36AR49 Air Conditioner
Rheem criterion gas furnace
Check freon, you will need guages on the condensor, also make sure the cond, outside unit is operating
Jun 14, 2009 | Amana Comfort Zone 12M32PBEH Air...
Weather King blows fuse in Criterion II furnace
You probably have a shorted wire between the heater and the a/c. There are two wires that conncet the control power to the outdoor a/c from the heater they should be on terminal c & y in the heater. disconect those two wires and try it again if the fuse doesnt blow you have a short in the wire between the a/c & heater
Jun 01, 2009 | Weather King 10AJA2501AH Air Conditioner
Rheem criterion II flame stays lit for a few seconds then only cold air blows through the house
Your furnace needs a tune-up. MODERN FURNACES REQUIRE REGULAR MAINTENANCE!
Mar 10, 2009 | Goodman GMS90703BXA Heater
Rheem Criterion II Furane would not ignite
what you need to do is take and inspect the hose that goes to the pressure switch and make sure that it is not dry rotted. if it is and the combustion blower is running then firsat try to cut the hose down and slip on a better piece of rubber. If not then replace the hose,
Dec 25, 2008 | Heating & Cooling
Amana Comfort Zone 12M32PBEH Air Conditioner Logo
694 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
