Question about Mantis Tiller
Motor won't rev up
I have done everything I can think of to fix this problem
It will start but won't rev up changed plug no different changed gas same bought a new carburetor same I've had mechanics look at it and they can't figure it out. I've come to the point that I just don't know
Can you help me out Thanks JohnB
  • 1 more comment
  • johnpegs May 30, 2009
    I used exaclty the same carb that came with the tiller. I have drained out the gas and checked inside of tank nothing wrong Gas flows out of tube full stream changed plug still the same I just don't know JohnB
    It won't start unless the throttle is tied wide open but it won't rev up. Now there are 2 lines coming from the gas tank one is for gas what is the other line with the white screen thing on the end of the hose? Thanks JohnB
    If you can think of anything else it would be helpful Thanks JohnB
    My email is johnpegs@comcast.net
  • 11,896 Answers
When you bought the carb, did you buy the same one or did you get a bigger one? You can always get some bigger jets than the ones it came with. Also wondering if your screen in your gas tank is plugged. How much fuel is getting to carb? I would empty out gas, take out the screens and make sure pitcock is wide open. Also you can always adjust air/fuel ratio screw on carb which may help a little.
One or all of these should help a little.
Posted on May 30, 2009
What does it sound like to u when the car starts up (picky sometimes) Revs good (sounds strong) rough idle with foot on gas at lower rpms and dies without applying gas?
i'd try a fuel addative to clear through fuel,cylinder/valves and the cat converter may have a carbon/sludge build up ,cheaper than getting iac and the idle may be the blockage symptom give it a go nothing to loose,must have quite a few miles on it
Apr 28, 2014 | Hyundai Motor 1995 Accent
John deere 111 dies when go to move it
I just got done with real similar prob my at first would start not rev up very well could drive it fine try to engage pto it die i checked everything carb back fire prevention was good cleaned carb seat switch checked out fine ignition switch had little corrosion changed it nope then it started to die after i started it and let out on foot pedal thought that was it checked with wires hooked up still get different readings each time unhooked switch it checked out fine then the seat switch would give me different readings on meter took it off test again fine was ready to have a fire sale on this pos i started to go through every electric con. Clean and make sure contact were good noticed a small crack on ignition switch female plug then found same on pto female plug got new plugs put wires in fixed everything
Jul 02, 2013 | Garden
Hello. My 1997 Chevy Tahoe refuses to start. The problems began with a bad fuel pump. I changed. It worked. The fuel pump died again. I changed it again and it has been working. I parked it for two weeks....
Now you have a good battery & a starter that turns over the motor
Have you cycled the key on & off with a fuel pressure gauge on the
fuel rail?
Do you have a fuel filter that isn't over 3 or 4 years old?
Have you checked for spark while cranking ? Use an old plug on the wires,
if you have ignition wires,don't ground the wire without resistance
If you removed the ducting & MAF Sensor it won't start
Tell us what you checked & exactly how that was done.
Jun 09, 2011 | 1997 Chevrolet Tahoe
2000 pontiac grand am 3.4 motor auto trans 4 door.Car starts and drives okay motor seems to stumble slightly between 3000-4000 rpms. with car stopped in park try to rev motor will only go between 3200-4000...
Hi Tom your vehicle is equipped with a Rev limiter it will not allow you to rev the engine above 4000 with the trans in park; as for the first problem you may have one of two things, one of the spark plugs or spark plug wires is bad or you have a flat spot on the throttle positioning sensor in which case have be replaced. Good luck?
Mar 10, 2011 | 2001 Pontiac Grand Am SE
'90 3.1 lumina euro idles ok but tries to stall when accelerated.
If the cat is red then it is probably plugged if the motor can't exhale it wont run at high rpm
Apr 11, 2009 | 1990 Chevrolet Lumina
Engine is cutting out below 5000rpm and missfiring
hi mate change the airfilter black smoke is a sign of a dirty air filter
Mar 28, 2009 | 2005 Yamaha YZF-R1
'92 dodge caravan dies at operating temperature
With the difference in years, there maybe a difference in alot of things. I'd start with mking sure every sensor, injector, everything links up properly to the 99 caravan pcm. If it's seeing the wrong info it will be a no go. Sounds like it's thinking it's -40 outside(foot to the floor to start) this indicates the coolant temp sensor maybe screwy. Let me know what you find, and about any other changes or issues.
Dec 05, 2008 | 1999 Dodge Ram
My lawn mower doesn't start and when it does, smoke comes out of exhaust
you may need to change the oil and/or empty the old gas and replace it with new.
This thing happens when you don't take care of your lawn mower for too long.
Sep 01, 2008 | Troy Bilt 5.5hp Self Propelled Mower
Mantis Tiller Logo
144 people viewed this question
Top Mantis Garden Experts
paulfvincent
Jim Parker
Jim Parker
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
