TOO MUCH NOISE WHEN IT RINSES!
WHEN IT DOES THE RINSEING CYCLE IT MAKES TOO MUCH NOISE AND IT SEAMS THAT SOMETHING IS FALLING APPART INSIDE.
i CHECKED BUT i CAN NOT SEE ANY BOLT MISSING OR LOSSE. i TRYED RUNNING IT ON RINSING MODE WITHOUT CLOTHES IN AND IT WAS FINE!
ANY IDEA WHY? PLUS IT DOES NOT CLEAN THE CLOTHES IT MAKES IT EVEN DIRTIER
ANY IDEA?
PLEASE HEEEEEEELP.
INDESET WIL143S IS THE MODEL OF THIS LAUNDRY
It looks like you have a leaking bearing in your machine all the machine will have to be taken apart to replace the bearing which is a very big job the best of luck
Posted on Oct 22, 2012
  • 909 Answers
Sounds like the bearing for the drum is breaking up, if it's leaving a black/dark grey grease like marks on the clothing, then thats probably it, to check, open the door and check for play by wiggling the drum.
If there is a lot of movement, or a grinding noise if you spin the drum by hand, then thats the problem.
Posted on May 30, 2009
During spin cycle the washer makes a loud thumping noise. Not a clanging/sharp noise. When I manually turn drum it sounds like something is loose inside. Like a ball may sound inside drum as it turns.
Is it a front loader? You may have something stuck between the tubs or it may be a broken "paddle" One of the plastic baffles that move the clothes around in the tub. they should all be tightly against the tub.
May 26, 2015 | Washing Machines
My paper keeps getting jammed. It makes a loud grinding noise and even after I clear the paper jam it repeats it all over again. Is there some way I could see if theres something stuck inside my printer...
Lift the Flat Bed Scanner and Turn the Printer Upside down and Gently Shake it!!!!!
You May get something falling out of the Printer which might have been stuck there!
Good Luck!!!!!
Jun 12, 2011 | Lexmark X7170 All-In-One InkJet Printer
Wfw8300sw01 - makes loud noise sounds during spin
The bearings have collapesd due to the seal going faulty. If bearings can be accessed to from the outside, it is possible you could do the repair. If big bearing and seal is accessed from the inside, suggest tech. do it as it gets dirty and a lot more complex.
Sep 20, 2009 | Washing Machines
My kenmore HE 2 Plus washing machine makes a loud grinding noise when it enters the pre-wash/wash cycle (worse on this cycle) then continues on through the rest of the cycles. Washer fills, rinses, spins...
Unfortunately, I don't think you will be able to fix this issue, some mechanical parts are breaking. If your appliance still under warranty, you may need to contact the appliance manufacturer for assistance. This kind of repair can be expensive and is difficult enough so a service technician may need to fix it.
Aug 31, 2009 | Kenmore HE2 Plus Front Load Washer
Water does not drain, strange noise while in spin cycle
sounds like something is stuck in your drain system. Most likely just in front or even in the pump
Please check this
Apr 22, 2008 | Kenmore 94812 Top Load Stacked Washer /...
Noisy compressor
Is a Hotpoint refrig?? Ge (who makes hotpoint) is having trouble with the freezer fan howling. Check out posts on Ge SxS PSS models. Some say its the main board, i disagree.
Dec 02, 2007 | Hotpoint HSM25GFRSA
Washing Machines Logo
74 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
