Question about Sony Computers & Internet
How do I install a new hard disc
Upgrade the hard disc
  • Mandeep  Singh
    Mandeep Singh May 11, 2010
    HI,
    Kindly give us the make and model number for the computer you want to upgrade . so that the instructions could be provided
    Thanks
    Proton
  • 489 Answers
Make sure the new hard drive is using the same interface as the old drive (SATA or IDE/ATA/PATA). If you have any data you want to save, make sure you copy it to another medium (CD, DVD, flash drive, network location, another computer, etc) or you can use something like a DriveWire which will allow you to clone your existing drive onto the new (larger) hard drive before replacing it. Then just follow the upgrade instructions in your laptop manual for removing the old drive and installing the new one.
Posted on May 30, 2009
My Masterlink is 7 years old. Do I need to replace my hard drive? How many hard drives, make and models? Thank you. Bill Dorsher
Any 3.5" IDE hard drive will do, it doesn't need to be a large one, as the Alesis will only 'see' the space it needs to - google 'standard ML9600 hard drive size' to see, I can't recall offhand.
You don't HAVE to upgrade the OS if the machine is working fine. You WILL have to install it on a new HDD if you install one.
For what it's worth, I could only get the OS to install from a disc I made on a Windows XP PC. Three or four attempts from a Vista machine all failed. Win 7 and 8 are unknown territory for me.
Make certain you have an OS disc BEFORE you replace the HDD.
Mar 07, 2015 | Alesis MasterLink ML-9600
Tip
Windows Installation Disc VS Windows Upgrade Disc -NOT THE SAME-
Having Trouble Booting To Your Windows Upgrade Disc?
...Upgrade discs aren't bootable discs. To repair a windows installation, you must use either a system repair disc or, better yet, a windows installation disc (genuine Retail/OEM discs are pretty much your only option to completely reinstall your windows operating system, unless you own a previous full installation disc of a previously released Windows version (such as XP or Vista), in which case you could install that windows operating system and then upgrade to a newer windows OS like windows 7. however if you ever need to reinstall windows 7, you would either need to reinstall the older windows OS, then upgrade to the newer one.
If that isn't clear, I'll sum it up....
Let's say you bought a computer, that computer had windows xp home edition. Maybe you wanted to upgrade from Windows XP/Windows Vista or Windows 7?
Well in order to switch from Windows XP/Vista to Windows 7, (or even from Windows 7 home premium- to windows7 Pro or Ultimate), then you must either:
A) Buy an upgrade disc and upgrade to the newer desired version.
B) Or, Buy a Retail Copy of the version you want to install. (keep in mind that a retail Windows 7 disc can be used to perform an upgrade rather than to competely wipe the hard disc and perform a clean install (delete partitions, reformat, and perform a new windows installation), if you so choose.
The bottom line is, you cannot Install a fresh clean copy of windows using an upgrade disc. OEM (Original Equipment Manufacturer) and Retail Windows Operation System Installation Setup Discs are "Bootable Discs". Windows Upgrade Discs are NOT bootable. (unless one where to "modify that particular disc, which is not legal).
on Jul 06, 2010 | Computers & Internet
Operating system not found
No, you won't get the OS to automatically install on the new drive. The OS is not stored in the BIOS chip (or a similar permanent location inside the computer). You will need an OS install disc (not an upgrade disc). Windows Vista Home Premium or Basic was the original OS on most of the Acer Aspire 4530 series. Acer appears to have drivers for the system for XP through Windows 7 to get the hardware to work. You will need to have these most of these ready before you install your OS. Put them on a flash drive or optical disc using another computer.
This computer may work with Unix as well. However, driver issues may be a factor. You can try most versions of Unix from a CD (LiveCD) to test it out.
When you get a new hard drive, install it into the laptop. Then put the OS disk in the optical drive bay. Boot to the optical drive. Follow the directions for formatting the hard drive and installing the OS. (Of course you will need a drive that doesn't have a higher capacity than the BIOS supports.) The motherboard needs to recognize the drive.
If you find a member of a Windows User Group, they may have Windows install discs available. The license number on the label of your computer will probably work as your license key. (The key for a computer like this is locked to the CPU and motherboard; unless someone upgraded the OS to Windows 7 or downgraded to XP, this should be the key you need.) Use the information on the label to obtain the correct version of Vista (the Basic install disc may not work for installing Home Premium). You also need to match the 32-bit or 64-bit install disc (and the service pack you need).
I hope this helps.
(An Acer recovery disc wouldn't help you. Most of those are completely locked to the original hardware (including hard drive) and look for the recovery partition that was on that hard drive.)
Dec 05, 2012 | Computers & Internet
I want upgrade my emachines t6528 hard drive and ram.i need help
Memory Upgrade for eMachines eMachines T6528 Computer, the eMachines eMachines T6528 Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. Memory Type, and comes installed with 512 MB (removable) of Memory. You can upgrade your eMachines eMachines T6528 Computer to up to a maximum of 4.0 GB Memory, the system has 4 sockets to install Memory, already with 512 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
As for the Hard Disc.... the following address will give step by step instructions on installing a new HD. http://www.manualowl.com/m/eMachines/T6528/Manual/
Thank You for using FixYa
Tom Miller
KD4DTK
Aug 19, 2012 | E-Machines T6528 PC Desktop
Windows 7 installation problems
Do you have the full install discs or just the upgrade disc? If you have the full install discs it doesn't require a prior version of windows like XP to be on the machine, and is less susceptible to problems.
Dec 12, 2011 | Western Digital Computers & Internet
Replaced new hard drive and i donot have start up disks
If no startup or back up discs exist, then the best way to install windows is to use a full install disc set of windows 7 home premium if the computer has enough memory and processor speed.
One can purchase the full install discs off of Ebay.com or directly from Microsoft.com.
I've found that using the full install discs is less of a hassle than using the upgrade discs which require that some partial image of Windows be on the hard drive, before proceeding with the installation.
Otherwise, one could put the old disc drive in, and burn startup or backup discs using the DVD burner, if so equipped.
I wish you luck on this upgrade path.
Feb 10, 2011 | IBM ThinkPad T30 2366 Notebook
How to install windows 7 operating system
To Install the Windows 7 Operating System (Win 7 OS):
Instructions for a "Clean/New Windows 7 Installation:
AFTER BACKING ALL YOUR DATA THAT YOU DON"T WANT TO LOSE, Do the Following :
1) Insert your Genuine Windows 7 System Disc (Retail or OEM System Installation Disc).
2) Close down all programs and restart your computer.
3) As soon as the computer restarts, you should see a prompt that says something like this: "Press any key to boot from cd/dvd"
....So press any key!... This will boot to the installation disc and prepare for installation or repair (we are going to be installing windows, so ignore the repair options you see on the screen).
*If you don't press a key in time, you will see that the computer will attempt to boot from the hard disc drive instead... if that happens, restart the computer and press a key when prompted.
4) Depending on your particular Windows Version, you will see a prompt that says something about "Do you accept the license terms?" Click "Yes" or "I accept", etc.. and continue on...
5) Choos Custom or Advanced Settings (the other option is for an upgrade..)
6)Select the desired hard disc drive, (HDD aka Hard Drive), Select "Drive Options", and follow the onscreen instructions "Delete the partitions" (Do not Leave another windows installation on the same hard disc drive, unless you are experienced and know how to "dual-boot" properly!) Delete the Partitions.
7) Now choose to install windows (be sure to select the newly deleted empty (unformatted) partition. Windows 7 will automatically format the drive for you and will begin to install windows 7. Follow the onscreen instructions and within a half an hour or less (depending on your hardware) you will be finished, just be sure not to leave the computer unattended while performing a windows installation, since it requires your input quite often to proceed.
That's pretty much all there is to it!.. if you have any more trouble...
Google it or Bing it.... Search Engines are awesome!.... Enjoy!
*NOTE- If your windows 7 disc is a "Upgrade" disc, then you must perform an upgrade while running your previous/older windows version, since Windos Upgrade Discs aren't bootable, they simply patch the older version, replace system files, etc... to transform the previous windows installation into the target/newer version. If you want to perform a clean install, be sure you own a Windows 7 Installation / System Startup Disc.
Jul 06, 2010 | Intel Motherboard
Need to load xp on gateway
Do you have a full installation disc or an Upgrade version of XP? The full install should give you an option for partitioning and formatting the new hard drive as part of the installation process. From Microsoft, read this page for details:
http://support.microsoft.com/kb/313348 . You may need some additional drivers if you have a SATA hard drive. More screen shots and details are here: http://www.theeldergeek.com/hard_drives_03.htm .
An alternative way of dealing with the problem may be to use a third-party Partition Manager software (Symantec's Partition Magic, Paragon's Partition Manager). Paragon's site is
http://www.partition-manager.com/ . This site has various levels of Partition Management software (with different features available in the more expensive versions). You'll need the bootable CD version of the software (recovery disc, .iso) to do the partitioning.
I hope this helps.
(I thought the upgrade version could also be done to a new hard disc including the partitioning; all you needed was a Win OS disc from an earlier version to prove qualifying ownership.)
Feb 20, 2010 | Gateway 700 X PC Desktop
Upgrade to vista ultimate
If you have a full version of Windows Vista Ultimate, you can just insert the DVD when you logged in your laptop and go to Computer(My Computer) and lauch the installer for Windows on DVD icon (Double Click DVD icon). It will give you the main window for installing Windows and along the way, you should find an Upgrade option. Click that one and it will install windows Ultimate on your system. It Will not format the laptop but installer will just add system files and features to the laptop to run Vista Ultimate.
**If you haven't purhcase a Windows Vista Ultimate Disc, check this link to to purchase just an upgrade Disc (only) of Vista Ultimate.
http://www.microsoft.com/windows/windows-vista/get/anytime-upgrade-overview.aspx
An upgrade disc will also not format the laptop instead it will just install additional features and add additional files on the system to run Windows Vista Ultimate
Oct 28, 2008 | Sony VAIO Digital Studio VGN-AR320E...
Computers & Internet Logo
163 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
