Question about Startrac Fitness Products Star Trac Pro S Treadmill
StarTrac Pro chain adjustment: After setting the adjustment for the chain as described in the maintenance manual, 1? ? 1 1/4? of play; I then rotate the pedals and the chain gets very tight and than very loose as I continue to rotate the pedals. Could the problem be bad bearings in the Bottom Bracket? Bad bearing is the Fly Wheel? I?ve tried determining for the bearings are bad, but can?t tell; all suggestion will be appreciated. Thanks, Bob
How to set timing chain on 1.8l Nissan sentra2002
The easiest way to set a timing chain or belt is to mark locations of timing gears before removal of old belt or chain. Install new belt or chain keeping gear locations the same. Tensioners shoud be adjusted with out upsetting gear locations. Gear locations can be marked with paint or scribed and etched on surface. If gear locations have been changed already, you must align cam shaft (s) position with main shaft position as far as current operation. Rotate main shaft to have cylinder # 1 piston to top of stroke. (exhaust position). Then rotate cam valves for cylinder # 1 to have exhaust valve open. Mark and maintain this position during belt or chain installation. You may still have to make minor valve adjustments after you start engine.
Nov 04, 2014 | Vehicle Parts & Accessories
Tip
StarTrac NXT Chain Tensioning & Alignment Video
About This Video
Adjusting Chain Tension and Alignment on a StarTrac NXT
  • In this video, we show how to tension and align the chain and flywheel on a StarTrac NXT bike
  • First you see an example of a chain that is way too loose
  • To correct this loosen the flywheel bolt on both sides of the flywheel
  • Loosen the tension nut on the sprocket side of the bike and tighten the tension bolt until you get the proper deflection on the chain
    • A properly tensioned chain will have roughly 3/16" of deflection
  • Tighten the tension nut and the flywheel nut on both sides as shown in the video
Check the Alignment of the Chain and Sprockets after Making a Chain Tension Adjustment
  • Misaligned chains will look like they are walking from side to side where they enter and leave the sprockets
    • This can cause noise, premature wear, as well as making the chain look to be jumping from side to side during use
  • To correct this, loosen the flywheel nut on both sides of the flywheel, then loosen the tension nut and adjust the tension bolt to move the flywheel in the proper direction needed to align the chain with the flywheel sprocket, as seen in the video
    • Note: If you have already achieved proper tension of the chain, adjusting the tension nut on the opposite side from the sprocket will help to keep the same tension on the chain
  • Don't forget to check the chain tension after making an alignment adjustment
Chain Tensioning Alignment Video for StarTrac NXT Bike
on Feb 11, 2015 | Startrac Fitness Products Star Trac 4410HR...
How to tighten chain on 4620avx poulan pro
First, RTFM- read the manual. Lost it? No problem, download it from Poulan PRO website page for PP4620avx. Pick a version you like, save and read it. Google is your friend.
Chain Adjustment Part cut and pasted as follows:
Adjusting the tension:
Chain tension is very important. Chain stretches during use. This is especially true during the first few times you use your saw. Always check chain tension each time you use and refuel your saw.
1. Lift lever on bar knob and turn counter-clockwise 1.5-2 turns to loosen clutch cover.
2. Turn adjusting wheel (downward direction) to tension chain until chain solidly contacts bottom of guide bar rail. Lift tip of guide bar while adjusting tension. Tighten chain Adjusting Wheel
3. Use a screwdriver to move chain around guide bar to ensure all links are in bar groove.
4. While lifting tip of guide bar, tighten bar knob securely (clockwise).
Hand tighten only.
Be careful not to destroy the adjustment mechanism. When it breaks, go for a clutch cover with the simple adjuster that needs a "scrench". Longer term, learn how to search this info. Saves time. Now you can work on sharpening chains- very important.
Manual page:
http://www.poulanpro.com/ddoc/PPOO/PPOO2006_USen/PPOO2006_USen_PP4620AVX_952802146.pdf
Jul 21, 2014 | Poulan Pro Chain Saw 46cc 20"
I have star trac pro treadmill,when i shifted from another place it show the error
1) Run the software calibration for diagnose, troubleshooting.
2) However adjust the reed switch, clean, and tight any wires connector see the diagram
3) adjust the speed sensor, clean, and tigh the wires connector see the diagram attached.
Jul 06, 2012 | Startrac Fitness Products Star Trac Pro S...
Chain noise
Excessive drive chain noise is caused by the following, lack of proper maintenance, keep it clean and lubed, next would be correct adjustment, most bikes about 3/4" deflection at center run of chain up and down play, next would be a worn out chain and/or drive or driven sprockets, last but not least and very noisy is the chain being stretched, if you rotate the wheel the chain gets loose then tight. Always check the sprockets for excess wear when replacing a chain, the drive sprocket on the engine is hardened steel and wears the least.
Feb 09, 2012 | Bajaj Pulsar 180 Motorcycles
Hi, I just cleaned my Poulan Pro. Changed out the gas, opened the carb and flushed it out with fresh gas, cleaned the fuel lines, the spark plug and air filter. I didn't replace the fuel filter though. ...
The fuel pick up or filter should be changed every year but if your saw will start and run good but just not idle then adjust the screw marked T counterclockwise slowly until chain starts to rotate without you depressing the throttle.At that point back it off about 1/16 of a turn until saw will idle but chain doesn't move.Thank you. P.S. If you want to you can go back to factory setting by turning H & L fully closed then open 1 to 1 1/4 turn and very slowly adjust for smoothest operation. Do not adjust H anymore then minimum off factory to avoid engine damage.
If you need further help I would suggest you have a trained tech.service it. Good luck.
Feb 14, 2011 | Poulan Pro Chain Saw 46cc 20"
Upper body workout arms on Startrac 6230 crosstrainer are locked in the ''None'' position. How do I switch to ''Pushing'' or ''Pulling''?
You May have to recalibrate Here is the procedure
Engaging Maintenance Mode 1. Press and hold the , and keys together. 2. A beep will sound and the “MAINTENANCE MODE” will display momentarily in the information window. 3. Release all keys. “SERIAL NO XXXXX” will display in the information window.
Modifying the Maintenance Mode The following keys are used to modify Maintenance Settings: Upper and Lower Data Information Window SCROLL keys: Display the next and previous settings. Increase and Decrease Level Keys: Adjust the value of the displayed setting up and down respectively, in increments of 1 unit. OK Key: Updates (saves) the value of the display setting in the Flash
Diagnostics - UB Calibration UB (Upper Body) Calibration (Elite Only) The UB Calibration will set the minimum and maximum range of the upper body arms in which they can move within. You can do a Manual Calibration or an Auto Calibration. Auto Calibration is recommended. To calibrate the Upper Body: 1. Enter the Maintenance Mode (see Settings – Maintenance Mode). 2. Press until UB Calibration is displayed in the information window. 3. Press to enter UB Calibration Mode. Manual Calibration 1. For Manual Calibration press 1. 2. Press the until the upper body arms stop moving (None Position), and then press to save. 3. Press the until the upper body actuator stops, and then press the to save. Auto Calibration For Auto Calibration press 2. The display will automatically raise the arms up, then bring them back down to calibrate the positions.
Mar 15, 2010 | Startrac Fitness Products Exercise &...
Switches to "Quick Start" before I enter all information
The Maintenance Mode allows you to query and modify the basic settings of the Star Trac Pro
Stepper.
Press and hold the0 , 2and OK keys together.
window.
previous settings.
OK Key: Updates (saves) the value of the display setting in the Flash memory, and exits
Maintenance Mode.
The Keypad Test can be used to verify that all keys are functioning on the display assembly.
To engage the Keypad Test
Press until Keypad Test is displayed in the information window.
Press to enter the Keypad Test.
Press each key on the display. Each time you press a key, the information window will display
which key has been pressed.
To exit the keypad test, press .
If any of the keys do not respond, they may not be functioning and the display keypad must be
replaced.
Jan 23, 2010 | Startrac Fitness Products Sc4130 Star Trac...
Why does my chain come off all the time
could be one of several reasons ,you could be running the chain too loose ,the bar could be excessivly worn or the drive sprocket in behind the clutch ,that drives the chain could be worn out. all i can say for certain is that , it is one of ,or a combination of those things an ex perienced eye would pick it straight away on seeing it "youdoit"
Nov 09, 2009 | Poulan Pro PP3816AV 38 Cc 16" Anti - Vib...
How to reset it
Hi it watches in my humble opinion if you talk about to erase the accumulated information only you must to maintain pressed the keys "star" "0" "enter" and "1" simultaneously and soon loose the key "1" on this mode you entering to Maintenance and with the keys adjustments UP or Down you can chance the values to cero this is for the Startrac Pro S only.
I hope that this information serves to you
Have a nice day
Jul 14, 2009 | Startrac Fitness Products Star Trac Pro S...
Startrac Fitness Products Star Trac Pro S Treadmill Logo
69 people viewed this question
Top Startrac Fitness Products Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Techmotionusa.com
Techmotionusa.com
Tim Loy
Level 1 Expert
Are you a Startrac Fitness Products Exercise and Fitnes Expert? Answer questions, earn points and help others
