Question about EliteGroup Computers & Internet
I just upgraded to a Elitegroup A780GM-A motherboard, AMD 64 X2 cpu, and 4GB RAM kit. I kept my 250GB Seagate HDD that has XP Pro on it with all my important data. The problem is all devices show ok after POST Test, then the system will not boot. I clear the cmos, try again and get the message that the clock is not set and cmos settings are wrong. I hit F1 and run cmos setup, correct all items I see that may be wrong and try to boot.It gets stuck in the same loop again after the Windows XP logo screen flash. What should I check next.
  • 489 Answers
It is still trying to load the drivers for your old system board which apparently are not compatible with your new board. You need to boot from the XP CD and repair your existing Windows installation. It should redetect all components and install the proper drivers for the motherboard components.
Posted on May 30, 2009
    Novelist:
  • 152 Answers
The easiest solution is to put in your windows XP disk, let the system boot from the CD-Rom, select Install, then select the Recovery option. This will force windows to fix teh HAL settings for your new hardware.
RECAP:
Boot from XP CD
When prompted, select INSTALL
windows will search for previous installs then ask if you want to recover, or re-install...
Select RECOVER.. it will act like it is installing, but it is just re-writing the HAL files (HAL = Hardware Access Layer)
Once completed, your data and programs, and program settings should all still be intact..
Cpu Models to upgrade Compaq Presario sr1920nx
CPU/Processor
  • Socket: 939
  • Supports the following processors:
    • AMD Athlon 64 X2 up to 4800+
    • AMD Athlon 64
    • AMD Sempron
CPU/Processor
  • Socket: 939
    • AMD Athlon 64
    • AMD Sempron
CPU/Processor
  • Socket: 939
    • AMD Athlon 64
    • AMD Sempron
Cpu/Processor Type
Socket: 939
    • AMD Athlon 64
    • AMD Sempron
Dec 22, 2009 | HP Compaq Presario SR1920NX PC Desktop
Green lines in black/grey screen (only vista, xp runs normal)
It's the onboard video try removing the CMOS battery and placing it back in after serveral hours, if that doen;t work it's the onboard Video replace it with a PCI Express Video Card.
Jul 27, 2009 | EliteGroup ECS A780GM-A Motherboard - AMD...
Hardware upgrade required for autocad 2009
Your existing CPU will not work with that motherboard. The AM2+/AM2 processor slot is for AMD processors only. For this motherboard, you will need one of the following processors: Phenom FX / Phenom / Athlon 64 FX / Athlon 64 X2
Jul 06, 2009 | Dell Dimension 8250 PC Desktop
Can anyone configure a system(cpu only) suit for
use amd 7600+ pro.
with duel chanel momery motherboard of msi + 4gb ram 1-1gb 4 moduel
and seagate cheeta hdd of any capicity
Jun 25, 2009 | ASUS K8S-MX Motherboard
I wish to upgarde to the fasted CPU possible for my motherboard
More importantly RAM will give you better performance, if your computer is low on ram it doesn't matter much what the cpu is.
you can put up to 4GB of ram into it
4 x 184-pin DDR SDRAM DIMM socket support up to 4 GB
Support DDR400/333/266 unbuffered DDR SDRAM
here is a list of supported CPU's
http://www.ecsusa.com/ECSWebSite/Support/CPU_Support_Model.aspx?detailid=493&MenuID=69&LanID=0
I think any of the dual cores on that page will be a OK upgrade.
So if you upgrade your ram to 2GB and a Dual core 4800+ that should be good. but in the long run it might be smarter to upgrade to a new motherboard and even faster cpu, with DDR 2 memory, the memory ddr2 is really cheap these days.
May 21, 2009 | EliteGroup nFORCE4-A939 Motherboard
Ram Upgrade
Max speed supported for your mobo is: DDR2-533
You will have to buy (4) 1gb sticks (2gb sticks not supported)
To use all four gigs of ram you need a 64 bit os.32 bit only supports 3gb of ram. Hope this helps!
Here is the specs :
ASUS A8M2N-LA (NODUS-GL8E) (DDR2-533MHz) Memory Maximum Memory 4GB Memory Slots 4 (4 banks of 1) non-removable base memory 0MB Machine name: ASUS A8M2N-LA (Nodus-GL8E) Motherboard
CPU options: Supports AMD Athlon 64, Athlon 64 X2 and Sempron processors.
Chipset: Nvidia GeForce 6150 LE Chipset
HD Bus:
Front Side Bus options:
Memory Speed options: PC2-4200 DDR2-533 240pin SDRAM DIMM
Special notes:
- Motherboard manufacturer's name: ASUS A8M2N-LA
- HP/Compaq name: Nodus-GL8E
NOTE: *Actual available memory may be less w/o 64 bit os
Dec 24, 2008 | Computers & Internet
Processor upgrade
Need to look at the motherboard specs along with the processor "Socket". It will usually be a 754 or 939 depending on what your motherboard says. I wouldn't try too fast and set yourself up for disappointment. I would upgrade the RAM before the processor.
Mar 22, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Unaible to upgrade RAM
It will only support up to 2GB Ram and the same memory specification
Nov 23, 2007 | ASUS M2N-MX Motherboard
Computers & Internet Logo
127 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
